    Can I use a 5V Solar panel on the USB Input to Charge
    lopybattery
    3 Posts 2 Posters 1.5k Views 2 Watching
      Paul_Stewart
      I am aiming for complete autonomy of a LoPy in an expansion board and just wondering if it is possible to use a 5V solar panel to either the USB port or VIN?
      The issue I see is that a 5 volt panel will rush to 7 volts in full sun. Some figure I found says Vmax at 5.5V for the expansion board.
      While the charge controller (BQ24040) seems to be able to handle up to 30V can the rest of the board handle it?
      cheers
      Paul
      • B Offline
        bombledq
        @Paul_Stewart
        Hi Paul,
        Do you succeed with your setup? I also had the same idea but i'm still waitinv my solar panel... thanks for your feedback
          Paul_Stewart
          Yes I have done this with this board and others that need a 5V input.
          It was as simple as putting in a zener diode in between the panel and board as a cheap, simple voltage limiter
          cheers
          Paul
