    WiFi Manager LoPy4
    4 Posts 2 Posters 42 Views 2 Watching
    • H Offline
      hamza charhour
      I am running wifi manager on LoPy4 I need to made changes to make it work with LoPy 4 but it doesn't work for me pleas if someone can help me .
      https://github.com/tayfunulu/WiFiManager
        jcaron @hamza charhour
        @hamza-charhour Unless you state what doesn't work (what you expect it to do, what it actually does, what errors and logs you get...) or what changes you need to make, it's going to be quite difficult for anyone to help you...
        • H Offline
          hamza charhour
          import network
          import ure
          from network import WLAN
          wlan = WLAN()
          NETWORK_PROFILES = 'wifi.dat'
          wlan_sta = network.WLAN(mode=network.WLAN.STA)
          server_socket = None
          def get_connection():
              """return a working WLAN(STA_IF) instance or None"""
              # First check if there already is any connection:
              if wlan_sta.isconnected():
                  return wlan_sta
              connected = False
              try:
                  # ESP connecting to WiFi takes time, wait a bit and try again:
                  time.sleep(3)
                      return wlan_sta
                  # Read known network profiles from file
                  profiles = read_profiles()
                  # Search WiFis in range
                  wlan_sta.active(True)
                  networks = wlan_sta.scan()
                  AUTHMODE = {0: "open", 1: "WEP", 2: "WPA2", 3: "WPA2-PSK", 4: "WPA/WPA2-PSK"}
                  for ssid, bssid, channel, rssi, authmode, hidden in sorted(networks, key=lambda x: x[3], reverse=True):
                      ssid = ssid.decode('utf-8')
                      encrypted = authmode > 0
                      print("ssid: %s chan: %d rssi: %d authmode: %s" % (ssid, channel, rssi, AUTHMODE.get(authmode, '?')))
                      if encrypted:
                          if ssid in profiles:
                              password = profiles[ssid]
                              connected = do_connect(ssid, password)
                              print("skipping unknown encrypted network")
                      else:  # open
                          connected = do_connect(ssid, None)
                      if connected:
                          break
              except OSError as e:
                  print("exception", str(e))
              # start web server for connection manager:
              if not connected:
                  connected = start()
              return wlan_sta if connected else None
          def read_profiles():
              with open(NETWORK_PROFILES) as f:
                  lines = f.readlines()
              profiles = {}
              for line in lines:
                  ssid, password = line.strip("\n").split(";")
                  profiles[ssid] = password
              return profiles
          def write_profiles(profiles):
              lines = []
              for ssid, password in profiles.items():
                  lines.append("%s;%s\n" % (ssid, password))
              with open(NETWORK_PROFILES, "w") as f:
                  f.write(''.join(lines))
          def send_header(client, status_code=200, content_length=None ):
              client.sendall("HTTP/1.0 {} OK\r\n".format(status_code))
              client.sendall("Content-Type: text/html\r\n")
              if content_length is not None:
                client.sendall("Content-Length: {}\r\n".format(content_length))
              client.sendall("\r\n")
          def send_response(client, payload, status_code=200):
              content_length = len(payload)
              send_header(client, status_code, content_length)
              if content_length > 0:
                  client.sendall(payload)
              client.close()
          def handle_root(client):
              ssids = sorted(ssid.decode('utf-8') for ssid, *_ in wlan_sta.scan())
              send_header(client)
              client.sendall("""\
                  <html>
                      <h1 style="color: #5e9ca0; text-align: center;">
                          <span style="color: #ff0000;">
                              Wi-Fi Client Setup
                          </span>
                      </h1>
                      <form action="configure" method="post">
                          <table style="margin-left: auto; margin-right: auto;">
                              <tbody>
              while len(ssids):
                  ssid = ssids.pop(0)
                  client.sendall("""\
                                  <tr>
                                      <td colspan="2">
                                          <input type="radio" name="ssid" value="{0}" />{0}
                                      </td>
                                  </tr>
                  """.format(ssid))
              client.sendall("""\
                                  <tr>
                                      <td>Password:</td>
                                      <td><input name="password" type="password" /></td>
                                  </tr>
                              </tbody>
                          </table>
                          <p style="text-align: center;">
                              <input type="submit" value="Submit" />
                          </p>
                      </form>
                      <p>&nbsp;</p>
                      <hr />
                      <h5>
                              Your ssid and password information will be saved into the
                              "%(filename)s" file in your ESP module for future usage.
                              Be careful about security!
                          </span>
                      </h5>
                      <hr />
                      <h2 style="color: #2e6c80;">
                          Some useful infos:
                      </h2>
                      <ul>
                          <li>
                              Original code from <a href="https://github.com/cpopp/MicroPythonSamples"
                                  target="_blank" rel="noopener">cpopp/MicroPythonSamples</a>.
                          </li>
                          <li>
                              This code available at <a href="https://github.com/tayfunulu/WiFiManager"
                                  target="_blank" rel="noopener">tayfunulu/WiFiManager</a>.
                          </li>
                      </ul>
                  </html>
              """ % dict(filename=NETWORK_PROFILES))
              client.close()
          def handle_configure(client, request):
              match = ure.search("ssid=([^&]*)&password=(.*)", request)
              if match is None:
                  send_response(client, "Parameters not found", status_code=400)
                  return False
              # version 1.9 compatibility
              try:
                  ssid = match.group(1).decode("utf-8").replace("%3F", "?").replace("%21", "!")
                  password = match.group(2).decode("utf-8").replace("%3F", "?").replace("%21", "!")
              except Exception:
                  ssid = match.group(1).replace("%3F", "?").replace("%21", "!")
                  password = match.group(2).replace("%3F", "?").replace("%21", "!")
              if len(ssid) == 0:
                  send_response(client, "SSID must be provided", status_code=400)
                  return False
              if do_connect(ssid, password):
                  response = """\
                      <html>
                          <center>
                              <br><br>
                                      ESP successfully connected to WiFi network %(ssid)s.
                                  </span>
                              </h1>
                              <br><br>
                          </center>
                      </html>
                  """ % dict(ssid=ssid)
                  send_response(client, response)
                  try:
                  except OSError:
                      profiles = {}
                  time.sleep(5)
                  return True
                  response = """\
                      <html>
                          <center>
                                      ESP could not connect to WiFi network %(ssid)s.
                                  </span>
                              </h1>
                              <br><br>
                              <form>
                                  <input type="button" value="Go back!" onclick="history.back()"></input>
                              </form>
                          </center>
                      </html>
                  return False
          def handle_not_found(client, url):
              send_response(client, "Path not found: {}".format(url), status_code=404)
          def stop():
              global server_socket
              if server_socket:
                  server_socket.close()
          def start(port=80):
              addr = socket.getaddrinfo('0.0.0.0', port)[0][-1]
              stop()
              wlan.init(mode=WLAN.AP, ssid='hello world')
              server_socket = socket.socket()
              server_socket.bind(addr)
              server_socket.listen(1)
              print('Connect to WiFi ssid ' + ssid  )
              print('and access the ESP via your favorite web browser at 192.168.4.1.')
              print('Listening on:', addr)
                      return True
                  client, addr = server_socket.accept()
                  print('client connected from', addr)
                  try:
                      client.settimeout(5.0)
                      request = b""
                      try:
                          while "\r\n\r\n" not in request:
                              request += client.recv(512)
                      except OSError:
                          pass
                      print("Request is: {}".format(request))
                      if "HTTP" not in request:  # skip invalid requests
                          continue
                      try:
                          url = ure.search("(?:GET|POST) /(.*?)(?:\\?.*?)? HTTP", request).group(1).decode("utf-8").rstrip("/")
                      except Exception:
                          url = ure.search("(?:GET|POST) /(.*?)(?:\\?.*?)? HTTP", request).group(1).rstrip("/")
                      print("URL is {}".format(url))
                      if url == "":
                          handle_root(client)
                      elif url == "configure":
                  finally:
                      client.close()
          THIS IS MY CODE NO ERROR BUT IT IS NOT WORKING
            @hamza-charhour how is it not working? What do you expect it to do, and what does it actually do? What are you trying to connect with? How? What happens?
