    Pycoproc function TypeError: function takes 2 positional arguments but 1 were given in PySense board i am trying to use accelerometer wake up interrupt example from pycom webpage
    pysensedeepsleeppycoprocaccelerometer
    2 Posts 2 Posters 77 Views 2 Watching
      Chandan Verma
      I am trying to use accelerometer movement as interrupt to wake the pysense board, but when creating an object for pycoproc() function and uploading it to board, there is a typeError show as it require 2 positional argument but only 1 were given.
      i am run the same code given in the pycom examples.
      Here is the code:
      # This script demonstrates two examples:
      # * go to ultra low power mode (~10uA @3.75V) with all sensors, incl accelerometer and also pycom module (Fipy, Gpy, etc) off - tap the MCLR button for this
      # * go to low power mode (~165uA @3.75V) with accelerometer on, pycom module in deepsleep and wake from accelerometer interrupt - hold the MCLR button down for this
      # See https://docs.pycom.io for more information regarding library specifics
      import struct
      from machine import Pin
      from pycoproc import Pycoproc
      from LIS2HH12 import LIS2HH12
      from SI7006A20 import SI7006A20
      from LTR329ALS01 import LTR329ALS01
      from MPL3115A2 import MPL3115A2,ALTITUDE,PRESSURE
      def accelerometer():
          print("ACCELEROMETER:", "accel:", accelerometer_sensor.acceleration(), "roll:", accelerometer_sensor.roll(), "pitch:", accelerometer_sensor.pitch(), "x/y/z:", accelerometer_sensor.x, accelerometer_sensor.y, accelerometer_sensor.z )
      def activity_int_handler(pin_o):
          if pin_o():
              print('[Activity]')
              pycom.rgbled(0x00000A) # blue
              print('[Inactivity]')
              pycom.rgbled(0x0A0A00) # yellow
      def activity_int_handler_none(pin_o):
          pass
      sleep_time_s = 300 # 5 min
      pycom.rgbled(0x0a0a0a) # white
      print("pycoproc init")
      py = Pycoproc()
      print("battery {:.2f} V".format(py.read_battery_voltage()))
      py.setup_sleep(sleep_time_s)
      # init accelerometer
      accelerometer_sensor = LIS2HH12()
      # read accelerometer sensor values
      accelerometer()
      print("enable accelerometer interrupt")
      # enable_activity_interrupt( [mG], [ms], callback)
      # accelerometer_sensor.enable_activity_interrupt(8000, 200, activity_int_handler) # low sensitivty
      # accelerometer_sensor.enable_activity_interrupt(2000, 200, activity_int_handler) # medium sensitivity
      accelerometer_sensor.enable_activity_interrupt( 100, 200, activity_int_handler) # high sensitivity
      # accelerometer_sensor.enable_activity_interrupt(63, 160, activity_int_handler) # ultra sensitivty
      print("enable pycom module to wake up from accelerometer interrupt")
      wake_pins = [Pin('P13', mode=Pin.IN, pull=Pin.PULL_DOWN)]
      machine.pin_sleep_wakeup(wake_pins, machine.WAKEUP_ANY_HIGH, True)
      print("put pycoproc to sleep and pycom module to deepsleep")
      py.go_to_sleep(pycom_module_off=False, accelerometer_off=False, wake_interrupt=True)
      machine.deepsleep(sleep_time_s * 1000)
      print("we never reach here!")
      and here is the output error:
      Smart Provisioning started in the background
      See https://docs.pycom.io/smart for details
      pycoproc init
        File "Chandan_deepsleep_code.py", line 39, in <module>
      Pycom MicroPython 1.20.2.r1 [v1.11-09d3ee1] on 2020-02-09; FiPy with ESP32
      Pybytes Version: 1.3.1
      Plese help me in resolving these error as i am new to these topics.
        Depending on which hardware version of the Pysense you're using, you should load the correct pycoproc file. You can find the latest versions of the file here: https://github.com/pycom/pycom-libraries/tree/master/shields/lib
        pycoproc_2.py is for Pysense v2.0 X, where pycoproc_1.py is for Pysense 1. This also changes the initialisation argument. For Pysense 1, you should put py = Pycoproc(Pycoproc.PYSENSE), whereas Pycoproc 2 does not require an argument
        To get a working example, you can load one of the zip files from here: https://github.com/pycom/pycom-libraries/releases/tag/v2.0.0 for the correct board version
