Atom Pymakr Installation Error
I am getting the following error when attempting to install Pymakr for Atom:
npm WARN deprecated parser-readline@1.0.2: reanmed to @serialport/parser-readline npm WARN deprecated parser-ready@1.0.2: reanmed to @serialport/parser-ready npm WARN deprecated parser-regex@1.0.2: reanmed to @serialport/parser-regex npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. prebuild-install WARN install No prebuilt binaries found (target=9.4.4 runtime=electron arch=x64 libc= platform=win32) gyp ERR! find Python gyp ERR! find Python Python is not set from command line or npm configuration gyp ERR! find Python Python is not set from environment variable PYTHON gyp ERR! find Python checking if "python" can be used gyp ERR! find Python - "python" is not in PATH or produced an error gyp ERR! find Python checking if "python2" can be used gyp ERR! find Python - "python2" is not in PATH or produced an error gyp ERR! find Python checking if "python3" can be used gyp ERR! find Python - "python3" is not in PATH or produced an error gyp ERR! find Python checking if the py launcher can be used to find Python 2 gyp ERR! find Python - "py.exe" is not in PATH or produced an error gyp ERR! find Python checking if Python is C:\Python27\python.exe gyp ERR! find Python - "C:\Python27\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Python37\python.exe gyp ERR! find Python - "C:\Python37\python.exe" could not be run gyp ERR! find Python gyp ERR! find Python ********************************************************** gyp ERR! find Python You need to install the latest version of Python. gyp ERR! find Python Node-gyp should be able to find and use Python. If not, gyp ERR! find Python you can try one of the following options: gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe" gyp ERR! find Python (accepted by both node-gyp and npm) gyp ERR! find Python - Set the environment variable PYTHON gyp ERR! find Python - Set the npm configuration variable python: gyp ERR! find Python npm config set python "C:\Path\To\python.exe" gyp ERR! find Python For more information consult the documentation at: gyp ERR! find Python https://github.com/nodejs/node-gyp#installation gyp ERR! find Python ********************************************************** gyp ERR! find Python gyp ERR! configure error gyp ERR! stack Error: Could not find any Python installation to use gyp ERR! stack at PythonFinder.fail (C:\Users\xxxx\AppData\Local\atom\app-1.58.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47) gyp ERR! stack at PythonFinder.runChecks (C:\Users\xxxx\AppData\Local\atom\app-1.58.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21) gyp ERR! stack at PythonFinder.<anonymous> (C:\Users\xxxx\AppData\Local\atom\app-1.58.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16) gyp ERR! stack at PythonFinder.execFileCallback (C:\Users\xxxx\AppData\Local\atom\app-1.58.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16) gyp ERR! stack at exithandler (child_process.js:302:5) gyp ERR! stack at ChildProcess.errorhandler (child_process.js:314:5) gyp ERR! stack at ChildProcess.emit (events.js:223:5) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:270:12) gyp ERR! stack at onErrorNT (internal/child_process.js:456:16) gyp ERR! stack at processTicksAndRejections (internal/process/task_queues.js:81:21) gyp ERR! System Windows_NT 10.0.19042 gyp ERR! command "C:\\Users\\xxxx\\AppData\\Local\\atom\\app-1.58.0\\resources\\app\\apm\\bin\\node.exe" "C:\\Users\\xxxx\\AppData\\Local\\atom\\app-1.58.0\\resources\\app\\apm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" gyp ERR! cwd C:\Users\xxxx\AppData\Local\Temp\apm-install-dir-2021719-3308-1r9l4yd.700o\node_modules\pymakr\node_modules\@serialport\bindings gyp ERR! node -v v12.14.1 gyp ERR! node-gyp -v v5.1.0 gyp ERR! not ok npm WARN notsup Unsupported engine for pymakr@2.1.13: wanted: {"atom":">=1.41.0","node":">=6.3.0 <=7.0.0"} (current: {"node":"12.14.1","npm":"6.14.13"}) npm WARN notsup Not compatible with your version of node/npm: pymakr@2.1.13 npm WARN enoent ENOENT: no such file or directory, open 'C:\Users\xxxx\AppData\Local\Temp\apm-install-dir-2021719-3308-1r9l4yd.700o\package.json' npm WARN apm-install-dir-2021719-3308-1r9l4yd.700o No description npm WARN apm-install-dir-2021719-3308-1r9l4yd.700o No repository field. npm WARN apm-install-dir-2021719-3308-1r9l4yd.700o No README data npm WARN apm-install-dir-2021719-3308-1r9l4yd.700o No license field. npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! @serialport/bindings@8.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the @serialport/bindings@8.0.8 install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! C:\Users\xxxx\.atom\.apm\_logs\2021-08-20T03_58_35_039Z-debug.logAny suggestions?
I get this same issue on multiple machines. Any fix yet from pycom?
