    Visual Studio Code and Pymakr
    gpygps pytrackvscvscode pymakr
    7 Posts 4 Posters 157 Views 4 Watching
      DEFRAINE.JM
      Hello All,
      Question 1: what are the latest versions of VSC and Pymakr that work together?
      At this time I'm using VSC 1.43 and Pymakr 1.1.6
      Question 2: I cannot connect to the GPY module on (Pytrack2)
      When I do a hardware reset I just start the connection and then I can do nothing!
      Thanks in advance for help
      Best regards
      Jiemde
        Question 1) We're working on getting Pymakr up to date with the latest version of VSCode
        Question 2) You can use the firmware updater tool to reflash the device with the latest firmware. I believe that could solve the problem: https://docs.pycom.io/updatefirmware/device/
        Another solution in some cases is to press CTRL+C in the REPL to stop any running code
        Don-iotD 1 Reply Last reply Reply Quote 0
          d.alvrzx @DEFRAINE.JM
          @DEFRAINE-JM VSC 1.58.2 and Pymakr 1.1.12 work well together.
            DEFRAINE.JM @d.alvrzx
            Hello,@d-alvrzx Thanks for your help it's work well ;)
            Jiemde
            • Don-iotD Offline
              Don-iot @Gijs
              @Gijs Having the same problem with VScode and Pymakr 1.1.13. Trying to find a source and instruction to download 1.1.12, any help here is highly appreciated. And letting me in on the 1.1.13 bug fix with VS code would be a nice bonus :)
                DEFRAINE.JM @Don-iot
                @Don-iot Just go to installed extensions, click on the "manage" pymakr, go to " install another version" and select the version you want!
                • Don-iotD Offline
                  Don-iot @DEFRAINE.JM
                  @DEFRAINE-JM Many thanks. I did find a stable combination after all, although not the latest version of the plugin or VSCODE, but I am happy that it works.
