    Pymakr 1.1.13 does not work with VSCode 1.60.0
    24 Posts 11 Posters 245 Views 11 Watching
      Stephan Elsner
      There is no terminal window opening.
      List serial ports command leads to an error:
      what can I do?
        d.alvrzx @Stephan Elsner
        @Stephan-Elsner wait for Pycom to fix this or downgrade to VSCode 1.58.2 and Pymakr 1.1.12
          sdfg sdfg
          A little rant about my first experience with trying a PyCom module. Hopefully it can serve as constructive feedback to the devs. Sorry if it's a bit emotional, I guess I'm a bit emotional right now :P
          There's something contradictory about this product: as far as I understand it was designed to be as easy to use as possible, yet in my experience it is way harder to get started than with a standard crappy microcontroller IDE using C++ from a whatever manufacturer.
          Steps I'm going through right now after hours of trying to get the tool-chain to work:
          1. Decrypt my Bitlocker drive, so that I can:
          2. Disable secure boot (without having to enter a Bitlocker recovery key), so that I can:
          3. Enable installing an unsigned driver,
          4. Install the unsigned COMport .inf driver,
          5. Install NodeJS,
          6. Find out there's a bug between PyCom and the current VScode version,
          7. Downgrade VScode,
          Can I start coding at some point or does the list go on? :P
            sdfg sdfg
            Since I can't edit my post due to the way this forum is configured, I'll just continue in a new post. This is probably useful to people who run into the same problems as me.
            So continuing from the steps above:
            1. Downgrade PyMark from 1.1.13 to 1.1.12 (yes really, you have to downgrade both VScode AND Pymakr),
            2. Find out that the .inf driver that I installed (according to the tutorial) is actually not working (PyMakr doesn't see the Comport after installing the .inf driver) and I needed the standard Windows driver all along,
            3. Pymakr doesn't find the correct serial port. solution from the tutorial "If not please manually copy the correct serial port." Uhm? Copy? And then? To where? Not siuor wut do now, pls finnush sentence. k thnx bye.
              sdfg sdfg
              edit: I got around the last problem below by editting the Pymakr > Global Settings file and removing one of the manufacturer strings (my fypi extension board happens to have Microsoft as Manufacturer string).
              Victory! It took a bunch of hours, but it's fun now that I can start coding :P
              • R Offline
                Razvan Grigore
                Same problem here, macbook pro:
                Version: 1.60.2
                Commit: 7f6ab5485bbc008386c4386d08766667e155244e
                Date: 2021-09-22T11:59:27.195Z (1 wk ago)
                Electron: 13.1.8
                Chrome: 91.0.4472.164
                Node.js: 14.16.0
                V8: 9.1.269.39-electron.0
                OS: Darwin x64 19.6.0
                Tried both 1.1.12 and 1.1.13 versions of the plugin, no luck, it does not appear in terminal and when trying to run console commands it says: command 'pymakr.connect' not found
                Thank you!
                  somervda
                  I think I have run into this the last few releases on VSCode and Pymakr. I have finally bitten the bullet and have turned off automatic updates in VSCode so I can hold them at the versions you called out. I'm not sure why VSCode and Pymakr keep having this problems on new releases, however I love how well they work when they do work, and didn't need to pay for either so can't complain :)
                  • Jakob RosenbergJ Offline
                    Jakob Rosenberg
                    Hi everyone. We've released v1.1.14, which should fix all issues directly related to v1.1.13.
                    For questions and feedback regarding v.1.1.14, please see the thread below.
                    PyMakr v.1.1.14 thread.
                    • M Offline
                      Meric NESSANGE
                      Same Issue here : "command not found" in VSCode
                      I use pymakr v2.22.4 and VSCode 1.70.0
                      Any workaround to share ?
                      Thanks.
                        robert-hh @Meric NESSANGE
                        @Meric-NESSANGE Roll back VSCode.
                        • M Offline
                          Meric NESSANGE @robert-hh
                          Hi @robert-hh.
                          till 1.1.12 ?
                            @Meric-NESSANGE If it ever worked, roll back to these versions. If you never used it, my personal opinion would be to stay away from it. According to the complaints in the forum, Pymakr has problems with almost every update of VSCode.
                            G M 2 Replies Last reply Reply Quote 0
                              g0hww @robert-hh
                              @robert-hh It seems to be permanently broken with Atom, which was when I last checked, apparently considered to be abandoned. Everything is falling apart around here.
                              • M Offline
                                @robert-hh
                                Thanks for answer.
                                Yes, it barrely worked, but I update VSCode in order to solve some connexion issues.
                                Noob error : I don't notice my previous version of VSCode.
                                ok, rolled back to a supposed functionnal version :
                                šŸ¤¦ā€ā™‚ļø
                                ok, let's do it without the preview module :
                                šŸ¤¦ā€ā™‚ļø
                                @g0hww It seems to be permanently broken with Atom
                                šŸ¤¦ā€ā™‚ļø It was my B-plan.
                                Anybody for a C-plan to be able to flash a board ?
                                Same sensation.
                                And it's worrying.
                                Really.
                                  @Meric-NESSANGE To upload the firmware you can always use the Pycom updater tool. And to upload code to the device you can use:
                                  • ftp (by WiFi)
                                  • mpremote by USB
                                  As terminal emulator you can use putty (windows), screen (mac), screen or picocom (Linux)
                                  As IDE you can as well try Thonny.
                                  • M Offline
                                    Hi @robert-hh,
                                    OK, I'd some unsuccesful try.
                                    Please, can you crosscheck my parameters :
                                    • ftp (by WiFi)
                                      • connect the PC to the micro wifi
                                        • ssid : sipy-wlan-xxxx
                                        • pw : www.pycom.io
                                      • host name : 192.168.4.1
                                      • port : 23
                                      • user : micro
                                      • pw : python
                                      • protocol : FTP (w/o encryption)
                                    • mpremote
                                      • succesfully installed with pip
                                      • got a "no device found" in the cmd panel. Seems not recognized as an application. Any idea ?
                                    Thanks.
                                      @Meric-NESSANGE Ftp must be unencrypted and limited to 1 connection.
                                      for mpremote you have to specify e.g. /dev/ttyUSB0 as interface. Shortcut is u0. E.g.
                                      mpremote connect /dev/ttyUSB0 ls
                                      or
                                      mpremote u0 ls
                                      For a windows machine, you have to specifiy the com port.
                                      mpremote connect com3 ls
                                      See also mpremote --help.
                                      • M Offline
                                        @robert-hh
                                        connected !!!
                                        --help was the enabler ^^
                                        Thanks.
                                        Unfortunately, not any ">>>" in the prompt. So no way to do anything...
                                        M robert-hhR 2 Replies Last reply Reply Quote 0
                                        • M Offline
                                          Meric NESSANGE @Meric NESSANGE
                                          EDIT : OK, wiring issue !
                                          I'M CONNECTED ON A MICROPYTHON ^^
                                            @Meric-NESSANGE looks like the wrong com port.
                                            With your input, this post could be even better šŸ’—
                                            • 1
                                            • 2
                                            • 1 / 2
