pybytes.activate(activationstring)
I'm trying to use the pybytes.activate(activationstring) method.
I have tried it with the activation token that you are supposed to use in the offline firmware updater tool but that doesn't work:>>> pybytes.activate('a4b3f5f3-28aa-4b58-aacd-0872b718987c') Disconnecting current connection! Error decoding activation string! syntax error in JSON Activation failed! Please try again...I noticed in another post that people use a much longer activation string than what I'm using above. So I guess I'm not using the correct activation string.
Where can I get a working activation string?
thanks
Did you use the activation string from 'with pymakr plugin' section?
@PB123 said in pybytes.activate(activationstring):
I have tried it with the activation token that you are supposed to use in the offline firmware updater tool but that doesn't work:as @Alexander-Pilhar said, you should use the activation string for Pymakr when using the pybytes.activate() method, not the token for the offline updater
@Alexander-Pilhar It's a bit hard for me when there is no such thing
@Nils-Erlands this might be browser related... What browser are you using and what version? I'm using current Microsoft Edge (Version 95.0.1020.44) withouth any issues.
