    Connect Lopy to Windows over BLE
    1 Posts 1 Posters 34 Views 1 Watching
      Anja Keller
      Hey, i could use some help.
      I am traying to send pysense data to my Windows Pc from BLE.
      My first problem is i see the Lopy and i can connect him. But a few second later the Lopy disconnected.
      And the secouns Problem is the GATT service what is to do with the uuid and the characteristic?
      This is my code:
      from network import Bluetooth
      pycom.rgbled(0x00008b) # blue
      #Bluetooth initialisierung
      bluetooth = Bluetooth()
      bluetooth.set_advertisement(name='LoPy', service_uuid=b'1234567890123456')
      def conn_cb (bt_o):
      events = bt_o.events() # this method returns the flags and clears the internal registry
      if events & Bluetooth.CLIENT_CONNECTED:
      print("Client connected")
      pycom.rgbled(0x00ff00)
      print("Client disconnected")
      pycom.rgbled(0xFF0000)
      bluetooth.advertise(True)
      srv1 = bluetooth.service(uuid=b'1223190123456', isprimary=True)
      chr1 = srv1.characteristic(uuid=b'ab3451230123456', value=5)
      print("Send Data")
      chr1.value("here is the data need to be send it should be a very very long string")
      time.sleep(3.050)
      def char1_cb_handler(chr, data):
      # The data is a tuple containing the triggering event and the value if the event is a WRITE event.
      # We recommend fetching the event and value from the input parameter, and not via characteristic.event() and characteristic.value()
      events, value = data
      if  events & Bluetooth.CHAR_WRITE_EVENT:
          print("Write request with value = {}".format(value))
          print('Read request on char 1')
