Guru meditation error
  • Hi Pycom team,
    *Note : We are using Pycom board (Fipy) and with Expansion board v3.1.
    We are exploring LoRa Technology on Fipy board. We created LoRa nanogateway using following this link below :-
    link
    The Gateway is working fine, and we are able to see updates on TTN .
    Issue : After running Nanogateway firmware sometime on Fipy board, the board gets hanged with a error named Guru meditation error. And after the error board doesn't start, we have to reset manually to get the board up and running.
    Attachment : I have attached the error log.
    Gateway_System_reboot_log.pdf
    Thank you!
  • What firmware are you using?
