    LTE not attaching anymore
    1 Posts 1 Posters 34 Views 1 Watching
    • B Offline
      bouchard.claude
      I have a couple of older GPY working wiht no issues in LTE CAT-M. Since I received a new batch ( with the new firmware), im not able to attach to LTE, using the exact same code and sim card batch ( tested on multiple gpy).
      Can I roll-back the modem firmware to the 'working version', or is there anything I can do to troubleshoot?
      What I did so far :
      <<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
      >>> GPy with firmware version 1.20.2.r6
      UE5.4.0.2
      LR5.4.1.0-50523
      DL SYNCHRO STATISTICS
          Synchro state                         : DRX_SLEEP
          PPU SIB1 ACQ watchdog                 : 0
          Frequency Hypothesis RF  (Hz)         : 1000
          RSRP (dBm)                            : -104.85
          RSRQ  (dB)                            : -12.36
          Channel estimation state (Cell-spec.) : LOW CINR
          Channel estimation state (UE-spec.)   : LOW CINR
          Channel estimation state (MBSFN)      : LOW CINR
          Channel estimation CINR               : 4.99
          Channel length                        : SHORT
        AGC
          AGC RX gain (dB)                      : 59.74
          RX PSD BO (dBFs)                      : -18.59
          RX PSD (dBm)                          : -106.24
          Noise level RS (dBm)                  : -108.12
          Digital gain (dB)                     : 9.91
          CINR RS (dB)                          : 3.27
        NARROWBANDS
          Last DL NB                            : Central
          Last UL NB                            : 3
        AFC
          Frequency offset RF  (Hz)             : -470
          Frequency offset BB  (Hz)             : 0
        PBCH
          MIB received quantity                 : 435
          MIB timeout quantity                  : 0
        RLF
          RLF idle qty                          : 1
          RLF connected qty                     : 0
      OK
      Sent to modem: 'AT!="fsm"'
      SYSTEM FSM
          |            FSM           |        STATE       |
          | RRC TOP FSM              |CAMPED              |
          | RRC SEARCH FSM           |CAMPED              |
          | RRC ACTIVE FSM           |IDLE                |
          | PMM PLMN FSM             |NORM_CAMPED         |
          | EMM MAIN FSM             |NULL                |
          | EMM AUTH FSM             |NULL                |
          | EMM CONN FSM             |NULL                |
          | EMM TAU FSM              |NULL                |
          | EMM TEST FSM             |NULL                |
          | ESM BEARER FSM           |BEARER_NULL         |
          | SMS MT FSM               |IDLE                |
          | SMS MO FSM               |IDLE                |
          | HP MAIN FSM              |IDLE                |
          | HP USIM FSM              |READY               |
          | HP SMS MO FSM            |IDLE                |
          | HP SMS MT FSM            |IDLE                |
          | HP CAT FSM               |IDLE                |
      OK
      .Sent to modem: 'AT!="showphy"'
          RSRP (dBm)                            : -105.53
          RSRQ  (dB)                            : -12.47
          Channel estimation CINR               : 4.61
        AGC
          RX PSD BO (dBFs)                      : -20.91
          RX PSD (dBm)                          : -106.39
          Noise level RS (dBm)                  : -107.83
          Digital gain (dB)                     : 10.06
          CINR RS (dB)                          : 2.30
        NARROWBANDS
          Last UL NB                            : 3
        AFC
        PBCH
        RLF
          RLF idle qty                          : 1
      OK
      SYSTEM FSM
          |            FSM           |        STATE       |
          | EMM TAU FSM              |NULL                |
          | SMS MT FSM               |IDLE                |
          | SMS MO FSM               |IDLE                |
          | HP MAIN FSM              |IDLE                |
          | HP CAT FSM               |IDLE                |
      OK
          RSRP (dBm)                            : -105.18
          RSRQ  (dB)                            : -11.20
          Channel estimation CINR               : 5.31
        AGC
          RX PSD BO (dBFs)                      : -18.17
          RX PSD (dBm)                          : -106.55
          Noise level RS (dBm)                  : -108.10
          Digital gain (dB)                     : 10.22
          CINR RS (dB)                          : 2.92
        NARROWBANDS
          Last UL NB                            : 3
        AFC
          Frequency offset RF  (Hz)             : -465
        PBCH
        RLF
          RLF idle qty                          : 1
      OK
      SYSTEM FSM
          |            FSM           |        STATE       |
          | EMM TAU FSM              |NULL                |
          | SMS MT FSM               |IDLE                |
          | SMS MO FSM               |IDLE                |
          | HP MAIN FSM              |IDLE                |
          | HP CAT FSM               |IDLE                |
      OK
      And it wont attach any time ( tried with different code)
      The cell provider see the device offline so Im thinking its not even trying?
      thanks!
