    Encoding and Decoding with Helium
    2 Posts 2 Posters 86 Views 4 Watching
      Anders H
      I am wondering how i could decode the data i send with lorawan to Helium. I am not sure how to decode it with Helium but i have done it with TTN. I send the data like this (2 integers).
      # create a LoRa socket
      # set the LoRaWAN data rate
      # make the socket blocking
      # (waits for the data to be sent and for the 2 receive windows to expire)
      s.setblocking(True)
      # send some data (2 integers)
      test = result.temperature
      s.send(bytes([test, int(t2)]))
      How could i integrate this with Helium?
        goldfishalpha
        I don't use Helium or TTN, but a quick look at their decoder library suggests you may be able to use a straight drop in replacement.
        Depends on whether you're using TTN V2 or V3. Helium decoder structure appears to be exactly the same as V2.
