    LoPy 4 - Deep Sleep high current consumption? 412uA
    2 Posts 1 Posters 27 Views 2 Watching
    • R Offline
      Rasmus Persson 0
      I'm having trouble with getting my LoPy 4 down to the specified 50uA during deep sleep. As of now I get an average of 412uA. I don't know why.
      from machine import Pin
      from network import LoRa
      from network import WLAN
      from network import Bluetooth
      from network import Server
      # from network import MDNS
      import ubinascii
      from machine import Timer
      from network import Sigfox
      intervalforlora = 10 # in seconds
      # MDNS.deinit()
      wlan = WLAN()
      wlan.deinit()
      bt = Bluetooth()
      bt.deinit()
      server = Server()
      server.deinit() # disable the server
      buttonPin = Pin('P8', mode=Pin.IN, pull=True)
      buttonPin2 = Pin('P9', mode=Pin.IN, pull=True)
      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868, tx_power=14, sf=12, power_mode=LoRa.TX_ONLY)
      app_eui = ubinascii.unhexlify('XXXXXXXXXXXXXX')
      app_key = ubinascii.unhexlify('XXXXXXXXXXXXXXXXXXXXXXXXXXXXX')
      dev_eui = ubinascii.unhexlify('XXXXXXXXXXXXXX')
      lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0)
      chrono = Timer.Chrono()
      chrono.start()
      lora.nvram_restore()
      while not lora.has_joined() or chrono.read() <= intervalforlora:
          pycom.heartbeat(True)
          starttime = time.time()
          time.sleep(2.5)
          print('Not yet joined...')
      if chrono.read() >= intervalforlora and not lora.has_joined():
      	machine.reset()
      print('Joined')
          s.setblocking(True)
          print()
          s.send(bytes([buttonPin()]))
          s.setblocking(False)
          time.sleep(10)
          print(buttonPin(),buttonPin2())
          # deepsleep
          if buttonPin() == 1:
              machine.pin_sleep_wakeup(["P9"], mode=machine.WAKEUP_ANY_HIGH, enable_pull=True)
              machine.deepsleep(1000*3600*24)  # 24 hours
              machine.pin_sleep_wakeup(["P8"], mode=machine.WAKEUP_ANY_HIGH, enable_pull=True)
      alt text
      Any help with solving this mystery would be greatly appreciated!
      • R Offline
        Rasmus Persson 0
        Could this be caused by having 2x 10k resistors connected to 3v3?
