    pygate, wipy & TTN no data
    5 Posts 2 Posters 35 Views 2 Watching
      Gregor Leban
      I think I did everything ok, as on the manuals, but gateway is still disconected on TTN
      On my pygate I have:
      boot. py
      # boot.py -- run on boot-up
      from _pybytes import Pybytes
      from _pybytes_config import PybytesConfig
      # We want to save a little bit power
      # Disable Heartbeat LED
      pycom.heartbeat_on_boot(False)
      # Enable Pybytes
      pybytes_conf = PybytesConfig().read_config()
      pybytes = Pybytes(pybytes_conf)
      pybytes.start()
      # disable debug messages
      machine.pygate_debug_level(1)
      # Proceed with main.py
      machine.main('main.py')
      global_conf.json (downloaded from TTN);
        "SX1301_conf": {
          "lorawan_public": true,
          "clksrc": 1,
          "antenna_gain": 0,
          "radio_0": {
            "enable": true,
            "type": "SX1257",
            "freq": 867500000,
            "rssi_offset": -166,
            "tx_enable": true,
            "tx_freq_min": 863000000,
            "tx_freq_max": 870000000
          "radio_1": {
            "enable": true,
            "type": "SX1257",
            "freq": 868500000,
            "tx_enable": false
          "chan_multiSF_0": {
            "enable": true,
            "radio": 1,
            "if": -400000
          "chan_multiSF_1": {
            "enable": true,
            "radio": 1,
            "if": -200000
          "chan_multiSF_2": {
            "enable": true,
            "radio": 1,
            "if": 0
          "chan_multiSF_3": {
            "enable": true,
            "radio": 0,
            "if": -400000
          "chan_multiSF_4": {
            "enable": true,
            "radio": 0,
            "if": -200000
          "chan_multiSF_5": {
            "enable": true,
            "radio": 0,
            "if": 0
          "chan_multiSF_6": {
            "enable": true,
            "radio": 0,
            "if": 200000
          "chan_multiSF_7": {
            "enable": true,
            "radio": 0,
            "if": 400000
          "chan_Lora_std": {
            "enable": true,
            "radio": 1,
            "if": -200000,
            "bandwidth": 250000,
            "spread_factor": 7
          "chan_FSK": {
            "enable": true,
            "radio": 1,
            "if": 300000,
            "bandwidth": 125000,
            "datarate": 50000
          "tx_lut_0": {
            "pa_gain": 0,
            "mix_gain": 8,
            "rf_power": -6,
            "dig_gain": 0
          "tx_lut_1": {
            "pa_gain": 0,
            "mix_gain": 10,
            "rf_power": -3,
            "dig_gain": 0
          "tx_lut_2": {
            "pa_gain": 0,
            "mix_gain": 12,
            "rf_power": 0,
            "dig_gain": 0
          "tx_lut_3": {
            "pa_gain": 1,
            "mix_gain": 8,
            "rf_power": 3,
            "dig_gain": 0
          "tx_lut_4": {
            "pa_gain": 1,
            "mix_gain": 10,
            "rf_power": 6,
            "dig_gain": 0
          "tx_lut_5": {
            "pa_gain": 1,
            "mix_gain": 12,
            "rf_power": 10,
            "dig_gain": 0
          "tx_lut_6": {
            "pa_gain": 1,
            "mix_gain": 13,
            "rf_power": 11,
            "dig_gain": 0
          "tx_lut_7": {
            "pa_gain": 2,
            "mix_gain": 9,
            "rf_power": 12,
            "dig_gain": 0
          "tx_lut_8": {
            "pa_gain": 1,
            "mix_gain": 15,
            "rf_power": 13,
            "dig_gain": 0
          "tx_lut_9": {
            "pa_gain": 2,
            "mix_gain": 10,
            "rf_power": 14,
            "dig_gain": 0
          "tx_lut_10": {
            "pa_gain": 2,
            "mix_gain": 11,
            "rf_power": 16,
            "dig_gain": 0
          "tx_lut_11": {
            "pa_gain": 3,
            "mix_gain": 9,
            "rf_power": 20,
            "dig_gain": 0
          "tx_lut_12": {
            "pa_gain": 3,
            "mix_gain": 10,
            "rf_power": 23,
            "dig_gain": 0
          "tx_lut_13": {
            "pa_gain": 3,
            "mix_gain": 11,
            "rf_power": 25,
            "dig_gain": 0
          "tx_lut_14": {
            "pa_gain": 3,
            "mix_gain": 12,
            "rf_power": 26,
            "dig_gain": 0
          "tx_lut_15": {
            "pa_gain": 3,
            "mix_gain": 14,
            "rf_power": 27,
            "dig_gain": 0
        "gateway_conf": {
          "gateway_ID": "2462ABFFFEF4Dxxx",
          "server_address": "eu1.cloud.thethings.network",
          "serv_port_up": 1700,
          "serv_port_down": 1700,
          "servers": [
              "serv_enabled": true
      main. py
      from network import WLAN
      from machine import RTC
      print('\nStarting LoRaWAN concentrator')
      # Disable Hearbeat
      # Define callback function for Pygate events
      def machine_cb (arg):
          evt = machine.events()
          if (evt & machine.PYGATE_START_EVT):
              # Green
              pycom.rgbled(0x103300)
          elif (evt & machine.PYGATE_ERROR_EVT):
              # Red
              pycom.rgbled(0x331000)
          elif (evt & machine.PYGATE_STOP_EVT):
              # RGB off
              pycom.rgbled(0x000000)
      # register callback function
      machine.callback(trigger = (machine.PYGATE_START_EVT | machine.PYGATE_STOP_EVT | machine.PYGATE_ERROR_EVT), handler=machine_cb)
      print('Connecting to WiFi...',  end='')
      # Connect to a Wifi Network
      wlan = WLAN(mode=WLAN.STA)
      wlan.connect(ssid='<SSID>', auth=(WLAN.WPA2, "<PASSWORD>"))
      while not wlan.isconnected():
          print('.', end='')
      print(" OK")
      # Sync time via NTP server for GW timestamps on Events
      print('Syncing RTC via ntp...', end='')
      rtc = RTC()
      rtc.ntp_sync(server="pool.ntp.org")
      while not rtc.synced():
          print('.', end='')
          time.sleep(.5)
      print(" OK\n")
      # Read the GW config file from Filesystem
      with open('/flash/global_config.json','r') as fp:
          buf = fp.read()
      # Start the Pygate
      machine.pygate_init(buf)
      # disable degub messages
      # machine.pygate_debug_level(1)
      pybytes_config.json
      I folow manuals and create in TTN Aplication and gateway:
      and to mention, when I restart pygate I get this:
      >>> WMAC: 2462ABF4Dxxx
      Firmware: 1.20.2.r6
      Pybytes: 1.7.1
      WMAC: 2462ABF4Dxxx
      Firmware: 1.20.2.r6
      Pybytes: 1.7.1
      Initialized watchdog for WiFi and LTE connection with timeout 1260000 ms
      WiFi connection established
      Connected to MQTT mqtt.pybytes.pycom.io
      Pybytes connected successfully (using the built-in pybytes library)
        File "boot.py", line 16, in <module>
      AttributeError: 'module' object has no attribute 'pygate_debug_level'
        File "main.py", line 25, in <module>
      AttributeError: 'module' object has no attribute 'callback'
      Pycom MicroPython 1.20.2.r6 [v1.11-c5a0a97] on 2021-10-28; WiPy with ESP32
      Pybytes Version: 1.7.1
      What did I do wrong?
        jcaron @Gregor Leban
        @Gregor-Leban did you flash the WiPy with the Pygate version of the firmware? Use the firmware upgrade tool and make sure you pick the right version.
          Gregor Leban
          Now I did it again. But I'm still disconected on TTN gateway
          Connecting to COM3...
          WMAC: 2462ABF4Dxxx
          Firmware: 1.20.2.r6
          Pybytes: 1.7.1
          Connecting to WiFi... OK
          Syncing RTC via ntp...... OK
            File "main.py", line 48, in <module>
          OSError: [Errno 2] ENOENT
            @Gregor-Leban it does look better now. You must be missing the global_config.json (not global_conf.json).
            G 1 Reply Last reply Reply Quote 1
              Gregor Leban @jcaron
              @jcaron
              wii that was it.
              I can’t tell you how happy I am that after many days of trying it finally works! : D
