    Cannot connect to PyGate & GPy
    2 Posts 1 Posters 82 Views 2 Watching
      aimeeraymond
      I am building a second PyGate + GPy system. I am unable to communicate via USB to the new GPy with the new PyGate. I am able to communicate via USB, if I separate the new parts and use them individually with different older parts.
      The issue "> Failed to connect (Error: Port is not open). Click here to try again.
      Connecting to COM3..."
      I cannot connect to the GPy using PyBytes, Atom, VSCode, or PuTTY.
      I can see COM3 in the Device Manager.
      I have 2 PyGate, 3 GPy, 1 LoPy4, and 1 ExpansionBoardV3.
      Both PyGate are V1R6-915MHz. PyGate#1 with GPy#1 has been running successfully on TTNv3 for 9 months. PyGate#2 with GPy#2 (and GPy#3) was received last week.
      I think PyGate#2 is bad, but am looking for help to see if I can get it running. My troubleshooting so far.
      PyGate#2 & GPy#2 - cannot connect tried 2 computers, numerous reboots, several cables
      PyGate#1 & GPy#1 - connects (hence USB cable good, VSC software good, Pymakr extension good)
      PyGate#2 & LoPy4 - connects (PyGate#2 is good?)
      ExpansionBoard & GPy#2 - connects (GPy#2 is good?)
      Using the ExpansionBoard, I am able to update GPy#2 firmware (with PyGate) I am also able to upload the PyGate software onto the GPy#2. While on the ExpansionBoard, the main.py starts, but is unable to connect to LTE.
      Remove programmed GPy#2 from ExpansionBoard (with firmware update & application software installed) and install on PyGate#2 - cannot connect
      Install programmed GPy#2 and install on PyGate#1 - can connect to COM, opens REPL, main.py starts, but unable to connect to LTE.
      Given the LTE is not connecting, upgraded the LTE modem firmware from version -47510 to -48829 with no effect.
      Am noticing the GPy#2 LED doesn't seem to ever flash or flicker like the GPy#1.
      Any suggestions?
        aimeeraymond
        Status Update (12 May 2022) - I was never able to get PyGate#2 to communicate on it's serial port. The supplier (PiShop.us) was very prompt in responding to my issue. Their technical support team stayed in touch and sent me a replacement unit.
