    Cannot install Pymakr 2.3.7 package in Atom 1.60.0 x64
    1 Posts 1 Posters 65 Views 1 Watching
    • H Offline
      Henry Sharpe
      Error message visible in the Atom Install Package dialog box looks like this:
      Re: Pymakr not compatible with Atom 1.56?
      (Please help: Cannot install pymakr plugin to Atom when using the normal Install Package >>> Pymakr
      Error:
      Installing “pymakr@2.3.7” failed.Hide output…
      npm ERR! code E500
      npm ERR! 500 Internal Server Error - GET https://www.atom.io/api/packages/pymakr/versions/2.3.7/tarball
      npm ERR! A complete log of this run can be found in:
      npm ERR! C:\Users\HShar.atom.apm_logs\2022-04-24T23_07_54_548Z-debug.log
      Win 10
      Atom 1.60.0 x64
      Pymakr version 2.3.7
      Debug log follows:
      0 info it worked if it ends with ok
      1 verbose cli [
      1 verbose cli 'C:\Users\HShar\AppData\Local\atom\app-1.60.0\resources\app\apm\bin\node.exe',
      1 verbose cli 'C:\Users\HShar\AppData\Local\atom\app-1.60.0\resources\app\apm\node_modules\npm\bin\npm-cli.js',
      1 verbose cli '--globalconfig',
      1 verbose cli 'C:\Users\HShar\.atom\.apm\.apmrc',
      1 verbose cli '--userconfig',
      1 verbose cli 'C:\Users\HShar\.atom\.apmrc',
      1 verbose cli 'install',
      1 verbose cli 'https://www.atom.io/api/packages/kite/versions/0.206.0/tarball',
      1 verbose cli '--target=9.4.4',
      1 verbose cli '--disturl=https://atom.io/download/electron',
      1 verbose cli '--arch=x64',
      1 verbose cli '--global-style'
      1 verbose cli ]
      2 info using npm@6.14.13
      3 info using node@v12.14.1
      4 verbose npm-session e512827352b5b326
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 http fetch GET 500 https://www.atom.io/api/packages/kite/versions/0.206.0/tarball 71459ms attempt #3
      8 silly fetchPackageMetaData error for https://www.atom.io/api/packages/kite/versions/0.206.0/tarball 500 Internal Server Error - GET https://www.atom.io/api/packages/kite/versions/0.206.0/tarball
      9 timing stage:rollbackFailedOptional Completed in 0ms
      10 timing stage:runTopLevelLifecycles Completed in 71502ms
      11 verbose stack Error: 500 Internal Server Error - GET https://www.atom.io/api/packages/kite/versions/0.206.0/tarball
      11 verbose stack at C:\Users\HShar\AppData\Local\atom\app-1.60.0\resources\app\apm\node_modules\npm\node_modules\npm-registry-fetch\check-response.js:117:15
      11 verbose stack at processTicksAndRejections (internal/process/task_queues.js:94:5)
      12 verbose statusCode 500
      13 verbose pkgid https://www.atom.io/api/packages/kite/versions/0.206.0/tarball
      14 verbose cwd C:\Users\HShar\AppData\Local\Temp\apm-install-dir-2022324-4016-if3q99.v1vvn
      15 verbose Windows_NT 10.0.19044
      16 verbose argv "C:\Users\HShar\AppData\Local\atom\app-1.60.0\resources\app\apm\bin\node.exe" "C:\Users\HShar\AppData\Local\atom\app-1.60.0\resources\app\apm\node_modules\npm\bin\npm-cli.js" "--globalconfig" "C:\Users\HShar\.atom\.apm\.apmrc" "--userconfig" "C:\Users\HShar\.atom\.apmrc" "install" "https://www.atom.io/api/packages/kite/versions/0.206.0/tarball" "--target=9.4.4" "--disturl=https://atom.io/download/electron" "--arch=x64" "--global-style"
      17 verbose node v12.14.1
      18 verbose npm v6.14.13
      19 error code E500
      20 error 500 Internal Server Error - GET https://www.atom.io/api/packages/kite/versions/0.206.0/tarball
      21 verbose exit [ 1, true ]
