W01 boot issue in environment with electromagnetic disturbance
  • Hi Everyone,
    I have a problem with my own device based on Pycom W01 SoC.
    Starting my device placed in a certain environment (A), it does not start.
    If, on the other hand, I move it to another location (B), the device starts up correctly and continues to work properly.
    Furthermore if once started in position B, I move it again to position A without turning it off or resetting it, the device continues to work correctly.
    Probably the problem is due to an electromagnetic disturbance in position A which doesn’t allow to load the firmware in the right way.
    The device has passed all the EMC tests, and it is CE marked.
    Could you please help me to solve this problem?
    Thank you in advance
    Best regards
    Angelo
  • @Angelo-Di-Franco The following code will help you:
    pyexec_frozen_module("_boot.py");
        if (!soft_reset) {
        #if defined(GPY) || defined (FIPY)
            if(config_get_lte_modem_enable_on_boot())
                //modlte_init0();
                // Notify the LTE thread to start
                //modlte_start_modem();
        #endif
        if (!safeboot) {
            // run boot.py
            int ret = pyexec_file("boot.py");
            if (ret & PYEXEC_FORCED_EXIT) {
                goto soft_reset_exit;
            if (!ret) {
    #ifndef RGB_LED_DISABLE
                // flash the system led
                mperror_signal_error();
    #endif
        if (!safeboot) {
            // execute the frozen main first
    #if (VARIANT == PYBYTES)
            if (config_get_pybytes_autostart()) {
                pyexec_frozen_module("_main_pybytes.py");
            } else {
            	pyexec_frozen_module("_main.py");
    #else
    #endif
    So the order is BOOT -> PYBYTES (if used) -> MAIN
  • @Andrea-Picillo Unfortunately, we cannot check the integrity of the power signals as the device is located at a customer.
    We haven’t issued any problem on all the other devices in our laboratories, even on the power supply lines.
    The crystal is inside the module W01 and therefore it should be shielded from EMC interferences by its own metal enclosure.
    Is it possible that the interferences are picked up by the PIFA antenna printed on the PCB?
    We are thinking as a possible solution to disable the WLAN in boot.py. What do you think about this?
    Do you know which is the loading sequence of the three modules: pybytes, main.py and boot.py?
  • @Angelo-Di-Franco I mean that maybe there aren't the best conditions to crystal/oscillators starting and you might not reach the needed frequency. That's only an idea. As I said before try to have a look to signals integrity, in particular way to power supply lines
  • @Andrea-Picillo Hi Andrea, thanks for your quick reply. What do you mean exactly with crystal trigger?
  • This post is deleted!
  • Hi Angelo. Have you tried to have a look to signals using an oscilloscope, paying more attention to power supply?
    In my opinion there could be some problem in crystal trigger
