    Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled.
    6 Posts 2 Posters 135 Views 2 Watching
    • B Offline
      BONPART Nans
      Hello everyone!
      I have a little problem, I follow this tuto: https://core-electronics.com.au/guides/internet-of-things-with-pycom-and-adafruit-io/
      Instead of a Pycom expansion board 2.0 I have a pysense 1.1
      My problem is the following:
      When I want to connect to my adafruit account and make measurements, when I launch the program I have this problem: Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled.
      I have searched for a long time on the internet but nothing could help me, thank you in advance for your help.
        robert-hh @BONPART Nans
        @BONPART-Nans Which code do you run on the board?
        • B Offline
          BONPART Nans
          @robert-hh said in Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled.:
          it is with this code that I get the error
            @BONPART-Nans I see that the firmware is quite old. Maybe as a first step you should update the firmware.
            • B Offline
              BONPART Nans @robert-hh
              @robert-hh hello !
              Where do you see it? I updated the firmware with Zadig v2.7 and DFU v0.9, did I forget or did I do something wrong?
                @BONPART-Nans In your first post at the bottom. For firmware update, better use the Pycom Updater. It will pick the most recent firmware. If you want to download the firmware files separately, use this page: https://docs.pycom.io/advance/downgrade/
