Sleep mode
How can I activate sleep mode, disable when input to GP1 and then go back into sleep mode?
This is my script:
import machine import urequests from machine import Pin pressed = 0 def pincb(pin): global pressed pressed += 1 p_out = Pin('GP2', mode=Pin.OUT) p_out.value(1) pin_int = Pin('GP1', mode=Pin.IN, pull=Pin.PULL_UP) pin_int.irq(trigger=Pin.IRQ_RISING, handler=pincb) while True: if pressed > 0: url = "(my url)" params = { "test": "true" } urequests.urlopen(url, "GET", params) pressed = 0Thank you very much!
