    LTE-M with Magenta Austria does not attach
    lte-mmagentagsmfipygpy
    5 Posts 4 Posters 95 Views 4 Watching
    • Z Offline
      Zoe Pfister
      Dear all,
      I have tried to connect to the internet using LTE-M. For that, I received an LTE-M SIM from Magenta Austria.
      I have followed the example shown in https://development.pycom.io/tutorials/networks/lte/ (using the correct APN and band information) without success. The network won't attach.
      Using the lte.send_at_cmd('AT!="fsm"') command shows that the TOP FSM is changing between SCANNING, SYNCING, etc.
      On the other hand, lte.send_at_cmd('AT!="showphy"') always shows an RSRP of -21474836.00, similar to a previous post (https://forum.pycom.io/search?term=rsrp&in=titlesposts).
      Does someone have any idea on how I could manage to attach to the network? Any previous experiences with Magenta Austria in this regard?
      Thank you very much!
      J J A 3 Replies Last reply Reply Quote 1
        jcaron @Zoe Pfister
        @Zoe-Pfister what version of the firmware and of the modem firmware are you using? I suppose you checked for coverage at your location?
          Jorge Romero @Zoe Pfister
          Hi @Zoe-Pfister, I want to know if you could fix this issue, I have the same problem, Is not possible to attach the cellular Network, in my case Vodafone and Telecom Italia. The version of the firmware is LR5.1.1.0-47510. Thank you in advance
            Alexander Pilhar @Zoe Pfister
            @Zoe-Pfister I have some experience with Magenta Austria! Had the same issue too :D
            See the following topic for more: FiPy unable to connect to T-Mobile NL (LTE-M)
            Unfortunatly, I still don't really know if it just takes forever when trying to attach the first time or if you really have to do a lte.factory_reset() and let if scan for itself without specifying a particular band.
            Give it a try - hope it helps!
              Alexander Pilhar
              I think I finally found an answer on how to properly reset the modem in case it just won't attach to a network.
              Reset the modem by sending following AT-command:
              lte.send_at_cmd('AT+SQNSFACTORYRESET=?')
              Unlike lte.factory_reset() - which seems to use AT-command AT+SQNSFACTORYRESET - this command will successfully reset the modem to factory state.
              A reboot of the device is necessary to finalize the reset!
              After this process the modem should attach to the network without any issues!
              Also, for further information see: AT Commands Reference Manual, 15.1 Device Reset to Factory State
