0.0.8
  • Hi There,
    My miner recently updated to v0.0.8. What's new? (I'm glad to see updates coming down the line, I was worried for a while.)
    Cheers
    Jason.
  • can you access the dashboard? I can't seems to get in.
  • @Razvan-Ciltea you could conntect to your miner using ssh but you can also download the current update script using
    wget https://software.pycom.io/downloads/update-hotspot.sh
    and then after having a look at line 11 you know which update package is the current one
    REMOTE_VERSION="0.0.8"
    With this information you can now download it using the URL in line 19:
    wget https://software.pycom.io/downloads/miner-0.0.8.tar.gz
    The miner downloads and runs the update-hotspot.sh script every 5 minutes and installs the update if needed.
  • @Jason-Timmins said in 0.0.8:
    Hi There,
    Cheers
    Jason.
    Any help on how we can access and see this information
    Thx
  • This is what's in the zip file...
    total 20
    -rw-r--r-- 1 root root    0 Nov 15 11:55 HS-0.0.8-Files.txt
    drwxrwxr-x 6 root root 4096 Nov  9 16:44 etc
    drwxrwxr-x 3 root root 4096 Jul  5 20:28 home
    drwxrwxr-x 3 root root 4096 Jul  6 08:10 opt
    drwxrwxr-x 2 root root 4096 Jul  6 09:04 root
    drwxrwxr-x 3 root root 4096 Jul  5 20:28 usr
    ./etc:
    total 20
    drwxr-xr-x 2 root root 4096 Aug  2 18:36 bluetooth
    drwxr-xr-x 2 root root 4096 Aug  6 10:38 cron.daily
    drwxrwxr-x 3 root root 4096 Jul  5 20:29 dbus-1
    -rwxr-xr-x 1 root root   53 Jul  6 08:11 rc.local
    drwxr-xr-x 3 root root 4096 Nov  9 16:44 systemd
    ./etc/bluetooth:
    total 4
    -rw-r--r-- 1 root root 3870 Aug  2 18:36 main.conf
    ./etc/cron.daily:
    total 4
    -rwxr-xr-x 1 root root 59 Aug  6 10:38 upnp
    ./etc/dbus-1:
    total 4
    drwxrwxr-x 2 root root 4096 Jul  5 20:29 system.d
    ./etc/dbus-1/system.d:
    total 8
    -rw-r--r-- 1 root root 382 Jul  5 20:29 com.helium.Config.conf
    -rw-r--r-- 1 root root 381 Jul  5 20:29 com.helium.Miner.conf
    ./etc/systemd:
    total 4
    drwxr-xr-x 2 root root 4096 Nov  9 16:45 system
    ./etc/systemd/system:
    total 4
    -rwxr-xr-x 1 root root 241 Nov  9 16:45 region-monitor.service
    ./home:
    total 4
    drwxrwxr-x 3 ubuntu ubuntu 4096 Nov  9 16:57 ubuntu
    ./home/ubuntu:
    total 8
    -rw-rw-r-- 1 ubuntu ubuntu 1395 Nov  9 16:56 docker-compose.yml
    drwxr-xr-x 2 ubuntu ubuntu 4096 Jul 19 12:21 overlay
    ./home/ubuntu/overlay:
    total 4
    -rw-rw-r-- 1 ubuntu ubuntu 463 Jul 19 12:21 docker.config
    ./opt:
    total 4
    drwxr-xr-x 7 root root 4096 Jun 22 09:21 gateway_config
    ./opt/gateway_config:
    total 20
    drwxr-xr-x  3 root root 4096 Jun 22 10:17 bin
    drwxr-xr-x  2 root root 4096 Jun 22 10:17 config
    drwxr-xr-x 12 root root 4096 Jun 22 10:17 lib
    drwxr-xr-x  2 root root 4096 Jun 22 09:21 log
    drwxr-xr-x  3 root root 4096 Jun 22 10:17 releases
    ./opt/gateway_config/bin:
    total 108
    drwxr-xr-x 2 root root  4096 Jun 22 10:17 extensions
    -rwxr-xr-x 1 root root 34162 Jun 22 10:17 gateway_config
    -rwxr-xr-x 1 root root 34162 Jun 22 10:17 gateway_config-0.1.0
    -rw-r--r-- 1 root root 14214 Jun 22 10:17 install_upgrade.escript
    -rw-r--r-- 1 root root  6968 Jun 22 10:17 no_dot_erlang.boot
    -rw-r--r-- 1 root root  7508 Jun 22 10:17 nodetool
    ./opt/gateway_config/bin/extensions:
    total 16
    -rwxr-xr-x 1 root root 321 Jun 22 10:17 advertise
    -rwxr-xr-x 1 root root 315 Jun 22 10:17 ble
    -rwxr-xr-x 1 root root 318 Jun 22 10:17 lights
    -rwxr-xr-x 1 root root 316 Jun 22 10:17 wifi
    ./opt/gateway_config/config:
    total 4
    -rw-r--r-- 1 root root 382 Jun 22 10:17 com.helium.Config.conf
    ./opt/gateway_config/lib:
    total 40
    drwxr-xr-x 4 root root 4096 Jun 22 10:17 clique-0.3.12+build.200.refe4be0da
    drwxr-xr-x 4 root root 4096 Jun 22 10:17 connman-0.0.0+build.29.ref0e41b52
    drwxr-xr-x 4 root root 4096 Jun 22 10:17 cuttlefish-2.1.4+build.556.ref8672838
    drwxr-xr-x 5 root root 4096 Jun 22 10:17 ebus-0.0.0+build.71.refe49d784
    drwxr-xr-x 4 root root 4096 Jun 22 10:17 erlang_ale-0.1.0
    drwxr-xr-x 4 root root 4096 Jun 22 10:17 gateway_config-2022.06.20.0+build.188.ref50a86f7
    drwxr-xr-x 4 root root 4096 Jun 22 10:17 gatt-0.0.0+build.33.ref92732d7
    drwxr-xr-x 4 root root 4096 Jun 22 10:17 goldrush-0.1.9
    drwxr-xr-x 4 root root 4096 Jun 22 10:17 h3-3.6.4+build.101.ref7ff30d0
    drwxr-xr-x 5 root root 4096 Jun 22 10:17 lager-3.9.2
    ./opt/gateway_config/lib/clique-0.3.12+build.200.refe4be0da:
    total 8
    drwxr-xr-x 2 root root 4096 Jun 22 10:17 ebin
    drwxr-xr-x 2 root root 4096 Jun 22 10:17 include
    ./opt/gateway_config/lib/clique-0.3.12+build.200.refe4be0da/ebin:
    total 160
    -rw-r--r-- 1 root root   885 Jun 22 10:17 clique.app
    -rw-r--r-- 1 root root  5828 Jun 22 10:17 clique.beam
    -rw-r--r-- 1 root root  2076 Jun 22 10:17 clique_app.beam
    -rw-r--r-- 1 root root  8448 Jun 22 10:17 clique_command.beam
    -rw-r--r-- 1 root root 20172 Jun 22 10:17 clique_config.beam
    -rw-r--r-- 1 root root  6484 Jun 22 10:17 clique_csv_writer.beam
    -rw-r--r-- 1 root root  7512 Jun 22 10:17 clique_error.beam
    -rw-r--r-- 1 root root  1884 Jun 22 10:17 clique_handler.beam
    -rw-r--r-- 1 root root  5788 Jun 22 10:17 clique_human_writer.beam
    -rw-r--r-- 1 root root  6868 Jun 22 10:17 clique_json_writer.beam
    -rw-r--r-- 1 root root  3096 Jun 22 10:17 clique_manager.beam
    -rw-r--r-- 1 root root  3000 Jun 22 10:17 clique_nodes.beam
    -rw-r--r-- 1 root root 13084 Jun 22 10:17 clique_parser.beam
    -rw-r--r-- 1 root root  3376 Jun 22 10:17 clique_spec.beam
    -rw-r--r-- 1 root root  3812 Jun 22 10:17 clique_status.beam
    -rw-r--r-- 1 root root  2360 Jun 22 10:17 clique_sup.beam
    -rw-r--r-- 1 root root 18396 Jun 22 10:17 clique_table.beam
    -rw-r--r-- 1 root root  7004 Jun 22 10:17 clique_test_group_leader.beam
    -rw-r--r-- 1 root root  2432 Jun 22 10:17 clique_typecast.beam
    -rw-r--r-- 1 root root  4088 Jun 22 10:17 clique_usage.beam
    -rw-r--r-- 1 root root  3948 Jun 22 10:17 clique_writer.beam
    ./opt/gateway_config/lib/clique-0.3.12+build.200.refe4be0da/include:
    total 8
    -rw-r--r-- 1 root root 491 Jun 22 10:17 clique_specs.hrl
    -rw-r--r-- 1 root root 730 Jun 22 10:17 clique_status_types.hrl
    ./opt/gateway_config/lib/connman-0.0.0+build.29.ref0e41b52:
    total 8
    ./opt/gateway_config/lib/connman-0.0.0+build.29.ref0e41b52/ebin:
    total 72
    -rw-r--r-- 1 root root   572 Jun 22 10:17 connman.app
    -rw-r--r-- 1 root root 24176 Jun 22 10:17 connman.beam
    -rw-r--r-- 1 root root  8844 Jun 22 10:17 connman_agent.beam
    -rw-r--r-- 1 root root  1388 Jun 22 10:17 connman_app.beam
    -rw-r--r-- 1 root root  7552 Jun 22 10:17 connman_connect.beam
    -rw-r--r-- 1 root root 13748 Jun 22 10:17 connman_services.beam
    -rw-r--r-- 1 root root  2252 Jun 22 10:17 connman_sup.beam
    ./opt/gateway_config/lib/connman-0.0.0+build.29.ref0e41b52/include:
    total 4
    -rw-r--r-- 1 root root 180 Jun 22 10:17 connman.hrl
    ./opt/gateway_config/lib/cuttlefish-2.1.4+build.556.ref8672838:
    total 8
    drwxr-xr-x 2 root root 4096 Jun 22 10:17 priv
    ./opt/gateway_config/lib/cuttlefish-2.1.4+build.556.ref8672838/ebin:
    total 276
    -rw-r--r-- 1 root root 19448 Jun 22 10:17 conf_parse.beam
    -rw-r--r-- 1 root root  1122 Jun 22 10:17 cuttlefish.app
    -rw-r--r-- 1 root root  4428 Jun 22 10:17 cuttlefish.beam
    -rw-r--r-- 1 root root  2100 Jun 22 10:17 cuttlefish_advanced.beam
    -rw-r--r-- 1 root root  3120 Jun 22 10:17 cuttlefish_bytesize.beam
    -rw-r--r-- 1 root root 12144 Jun 22 10:17 cuttlefish_conf.beam
    -rw-r--r-- 1 root root 12028 Jun 22 10:17 cuttlefish_datatypes.beam
    -rw-r--r-- 1 root root  4280 Jun 22 10:17 cuttlefish_duration.beam
    -rw-r--r-- 1 root root 14028 Jun 22 10:17 cuttlefish_duration_parse.beam
    -rw-r--r-- 1 root root  6240 Jun 22 10:17 cuttlefish_effective.beam
    -rw-r--r-- 1 root root  5056 Jun 22 10:17 cuttlefish_enum.beam
    -rw-r--r-- 1 root root 10376 Jun 22 10:17 cuttlefish_error.beam
    -rw-r--r-- 1 root root 36596 Jun 22 10:17 cuttlefish_escript.beam
    -rw-r--r-- 1 root root  2084 Jun 22 10:17 cuttlefish_flag.beam
    -rw-r--r-- 1 root root 33152 Jun 22 10:17 cuttlefish_generator.beam
    -rw-r--r-- 1 root root 10156 Jun 22 10:17 cuttlefish_mapping.beam
    -rw-r--r-- 1 root root  4056 Jun 22 10:17 cuttlefish_rebar_plugin.beam
    -rw-r--r-- 1 root root 14512 Jun 22 10:17 cuttlefish_schema.beam
    -rw-r--r-- 1 root root  3548 Jun 22 10:17 cuttlefish_translation.beam
    -rw-r--r-- 1 root root 13412 Jun 22 10:17 cuttlefish_unit.beam
    -rw-r--r-- 1 root root  7804 Jun 22 10:17 cuttlefish_util.beam
    -rw-r--r-- 1 root root  3464 Jun 22 10:17 cuttlefish_validator.beam
    -rw-r--r-- 1 root root  6460 Jun 22 10:17 cuttlefish_variable.beam
    -rw-r--r-- 1 root root  1972 Jun 22 10:17 cuttlefish_vmargs.beam
    -rw-r--r-- 1 root root  7588 Jun 22 10:17 lager_stderr_backend.beam
    ./opt/gateway_config/lib/cuttlefish-2.1.4+build.556.ref8672838/priv:
    total 16
    -rw-r--r-- 1 root root 12457 Jun 22 10:17 erlang_vm.schema
    ./opt/gateway_config/lib/ebus-0.0.0+build.71.refe49d784:
    total 12
    ./opt/gateway_config/lib/ebus-0.0.0+build.71.refe49d784/ebin:
    total 84
    -rw-r--r-- 1 root root   543 Jun 22 10:17 ebus.app
    -rw-r--r-- 1 root root 19472 Jun 22 10:17 ebus.beam
    -rw-r--r-- 1 root root  1364 Jun 22 10:17 ebus_app.beam
    -rw-r--r-- 1 root root 11120 Jun 22 10:17 ebus_message.beam
    -rw-r--r-- 1 root root  7432 Jun 22 10:17 ebus_nif.beam
    -rw-r--r-- 1 root root 10700 Jun 22 10:17 ebus_object.beam
    -rw-r--r-- 1 root root 17832 Jun 22 10:17 ebus_proxy.beam
    -rw-r--r-- 1 root root  2476 Jun 22 10:17 ebus_sup.beam
    ./opt/gateway_config/lib/ebus-0.0.0+build.71.refe49d784/include:
    total 4
    -rw-r--r-- 1 root root 430 Jun 22 10:17 ebus.hrl
    ./opt/gateway_config/lib/ebus-0.0.0+build.71.refe49d784/priv:
    total 196
    -rwxr-xr-x 1 root root 197448 Jun 22 10:17 ebus.so
    ./opt/gateway_config/lib/erlang_ale-0.1.0:
    total 8
    ./opt/gateway_config/lib/erlang_ale-0.1.0/ebin:
    total 40
    -rw-r--r-- 1 root root 1624 Jun 22 10:17 ale_util.beam
    -rw-r--r-- 1 root root  339 Jun 22 10:17 erlang_ale.app
    -rw-r--r-- 1 root root 1352 Jun 22 10:17 erlang_ale_app.beam
    -rw-r--r-- 1 root root 1524 Jun 22 10:17 erlang_ale_sup.beam
    -rw-r--r-- 1 root root 6724 Jun 22 10:17 gpio.beam
    -rw-r--r-- 1 root root 4664 Jun 22 10:17 i2c.beam
    -rw-r--r-- 1 root root 4340 Jun 22 10:17 spi.beam
    ./opt/gateway_config/lib/erlang_ale-0.1.0/priv:
    total 44
    -rwxr-xr-x 1 root root 44960 Jun 22 10:17 erlang-ale
    ./opt/gateway_config/lib/gateway_config-2022.06.20.0+build.188.ref50a86f7:
    total 8
    ./opt/gateway_config/lib/gateway_config-2022.06.20.0+build.188.ref50a86f7/ebin:
    total 424
    -rw-r--r-- 1 root root  2216 Jun 22 10:17 gateway_ble_advertisement.beam
    -rw-r--r-- 1 root root  1940 Jun 22 10:17 gateway_config.app
    -rw-r--r-- 1 root root 17116 Jun 22 10:17 gateway_config.beam
    -rw-r--r-- 1 root root  1660 Jun 22 10:17 gateway_config_app.beam
    -rw-r--r-- 1 root root  5216 Jun 22 10:17 gateway_config_cli_advertise.beam
    -rw-r--r-- 1 root root  5128 Jun 22 10:17 gateway_config_cli_ble.beam
    -rw-r--r-- 1 root root  4660 Jun 22 10:17 gateway_config_cli_lights.beam
    -rw-r--r-- 1 root root  2440 Jun 22 10:17 gateway_config_cli_registry.beam
    -rw-r--r-- 1 root root  5756 Jun 22 10:17 gateway_config_cli_wifi.beam
    -rw-r--r-- 1 root root 12836 Jun 22 10:17 gateway_config_led.beam
    -rw-r--r-- 1 root root  2344 Jun 22 10:17 gateway_config_sup.beam
    -rw-r--r-- 1 root root 12972 Jun 22 10:17 gateway_config_worker.beam
    -rw-r--r-- 1 root root  2320 Jun 22 10:17 gateway_gatt_application.beam
    -rw-r--r-- 1 root root  7664 Jun 22 10:17 gateway_gatt_char_add_gateway.beam
    -rw-r--r-- 1 root root 32972 Jun 22 10:17 gateway_gatt_char_add_gateway_pb.beam
    -rw-r--r-- 1 root root  8192 Jun 22 10:17 gateway_gatt_char_assert_loc.beam
    -rw-r--r-- 1 root root 39532 Jun 22 10:17 gateway_gatt_char_assert_loc_pb.beam
    -rw-r--r-- 1 root root  4652 Jun 22 10:17 gateway_gatt_char_diagnostics.beam
    -rw-r--r-- 1 root root 35000 Jun 22 10:17 gateway_gatt_char_diagnostics_pb.beam
    -rw-r--r-- 1 root root  2404 Jun 22 10:17 gateway_gatt_char_eth_online.beam
    -rw-r--r-- 1 root root  3588 Jun 22 10:17 gateway_gatt_char_lights.beam
    -rw-r--r-- 1 root root  2612 Jun 22 10:17 gateway_gatt_char_onboarding_key.beam
    -rw-r--r-- 1 root root  2568 Jun 22 10:17 gateway_gatt_char_pubkey.beam
    -rw-r--r-- 1 root root  3248 Jun 22 10:17 gateway_gatt_char_wifi_configured_services.beam
    -rw-r--r-- 1 root root  6468 Jun 22 10:17 gateway_gatt_char_wifi_connect.beam
    -rw-r--r-- 1 root root 28964 Jun 22 10:17 gateway_gatt_char_wifi_connect_pb.beam
    -rw-r--r-- 1 root root  4388 Jun 22 10:17 gateway_gatt_char_wifi_remove.beam
    -rw-r--r-- 1 root root 27032 Jun 22 10:17 gateway_gatt_char_wifi_remove_pb.beam
    -rw-r--r-- 1 root root  4736 Jun 22 10:17 gateway_gatt_char_wifi_services.beam
    -rw-r--r-- 1 root root 27132 Jun 22 10:17 gateway_gatt_char_wifi_services_pb.beam
    -rw-r--r-- 1 root root 10964 Jun 22 10:17 gateway_gatt_char_wifi_ssid.beam
    -rw-r--r-- 1 root root 12772 Jun 22 10:17 gateway_gatt_service.beam
    -rw-r--r-- 1 root root  6256 Jun 22 10:17 gpio_button.beam
    -rw-r--r-- 1 root root 10100 Jun 22 10:17 lp5562.beam
    ./opt/gateway_config/lib/gateway_config-2022.06.20.0+build.188.ref50a86f7/include:
    total 4
    -rw-r--r-- 1 root root 748 Jun 22 10:17 gateway_config.hrl
    ./opt/gateway_config/lib/gatt-0.0.0+build.33.ref92732d7:
    total 8
    ./opt/gateway_config/lib/gatt-0.0.0+build.33.ref92732d7/ebin:
    total 116
    -rw-r--r-- 1 root root 12684 Jun 22 10:17 ble_advertisement.beam
    -rw-r--r-- 1 root root   842 Jun 22 10:17 gatt.app
    -rw-r--r-- 1 root root  1600 Jun 22 10:17 gatt.beam
    -rw-r--r-- 1 root root  1364 Jun 22 10:17 gatt_app.beam
    -rw-r--r-- 1 root root 10872 Jun 22 10:17 gatt_application.beam
    -rw-r--r-- 1 root root  2336 Jun 22 10:17 gatt_application_sup.beam
    -rw-r--r-- 1 root root 16384 Jun 22 10:17 gatt_characteristic.beam
    -rw-r--r-- 1 root root  2452 Jun 22 10:17 gatt_characteristic_string.beam
    -rw-r--r-- 1 root root  7852 Jun 22 10:17 gatt_descriptor.beam
    -rw-r--r-- 1 root root  1844 Jun 22 10:17 gatt_descriptor_cud.beam
    -rw-r--r-- 1 root root  3752 Jun 22 10:17 gatt_descriptor_pf.beam
    -rw-r--r-- 1 root root  1332 Jun 22 10:17 gatt_object.beam
    -rw-r--r-- 1 root root 18532 Jun 22 10:17 gatt_service.beam
    -rw-r--r-- 1 root root  2560 Jun 22 10:17 gatt_service_device_information.beam
    -rw-r--r-- 1 root root  2584 Jun 22 10:17 gatt_service_sup.beam
    -rw-r--r-- 1 root root  1988 Jun 22 10:17 gatt_sup.beam
    ./opt/gateway_config/lib/gatt-0.0.0+build.33.ref92732d7/include:
    total 4
    -rw-r--r-- 1 root root 1004 Jun 22 10:17 gatt.hrl
    ./opt/gateway_config/lib/goldrush-0.1.9:
    total 8
    ./opt/gateway_config/lib/goldrush-0.1.9/ebin:
    total 120
    -rw-r--r-- 1 root root 10004 Jun 22 10:17 glc.beam
    -rw-r--r-- 1 root root 31444 Jun 22 10:17 glc_code.beam
    -rw-r--r-- 1 root root 11184 Jun 22 10:17 glc_lib.beam
    -rw-r--r-- 1 root root  4400 Jun 22 10:17 glc_ops.beam
    -rw-r--r-- 1 root root  1804 Jun 22 10:17 glc_run.beam
    -rw-r--r-- 1 root root   637 Jun 22 10:17 goldrush.app
    -rw-r--r-- 1 root root  1340 Jun 22 10:17 gr_app.beam
    -rw-r--r-- 1 root root  2728 Jun 22 10:17 gr_context.beam
    -rw-r--r-- 1 root root  8104 Jun 22 10:17 gr_counter.beam
    -rw-r--r-- 1 root root  1804 Jun 22 10:17 gr_counter_sup.beam
    -rw-r--r-- 1 root root  4084 Jun 22 10:17 gr_manager.beam
    -rw-r--r-- 1 root root  1804 Jun 22 10:17 gr_manager_sup.beam
    -rw-r--r-- 1 root root  7412 Jun 22 10:17 gr_param.beam
    -rw-r--r-- 1 root root  1796 Jun 22 10:17 gr_param_sup.beam
    -rw-r--r-- 1 root root  2116 Jun 22 10:17 gr_sup.beam
    -rw-r--r-- 1 root root  3132 Jun 22 10:17 gre.beam
    ./opt/gateway_config/lib/goldrush-0.1.9/priv:
    total 4
    -rw-r--r-- 1 root root 2192 Jun 22 10:17 edoc.css
    ./opt/gateway_config/lib/h3-3.6.4+build.101.ref7ff30d0:
    total 8
    ./opt/gateway_config/lib/h3-3.6.4+build.101.ref7ff30d0/ebin:
    total 12
    -rw-r--r-- 1 root root  407 Jun 22 10:17 h3.app
    -rw-r--r-- 1 root root 6136 Jun 22 10:17 h3.beam
    ./opt/gateway_config/lib/h3-3.6.4+build.101.ref7ff30d0/priv:
    total 140
    -rw-r--r-- 1 root root 140904 Jun 22 10:17 libh3.so
    ./opt/gateway_config/lib/lager-3.9.2:
    total 12
    ./opt/gateway_config/lib/lager-3.9.2/ebin:
    total 360
    -rw-r--r-- 1 root root 38684 Jun 22 10:17 error_logger_lager_h.beam
    -rw-r--r-- 1 root root  1996 Jun 22 10:17 lager.app
    -rw-r--r-- 1 root root 32100 Jun 22 10:17 lager.beam
    -rw-r--r-- 1 root root 16244 Jun 22 10:17 lager_app.beam
    -rw-r--r-- 1 root root  4016 Jun 22 10:17 lager_backend_throttle.beam
    -rw-r--r-- 1 root root  6520 Jun 22 10:17 lager_common_test_backend.beam
    -rw-r--r-- 1 root root  4312 Jun 22 10:17 lager_config.beam
    -rw-r--r-- 1 root root 11128 Jun 22 10:17 lager_console_backend.beam
    -rw-r--r-- 1 root root 14152 Jun 22 10:17 lager_crash_log.beam
    -rw-r--r-- 1 root root 12360 Jun 22 10:17 lager_default_formatter.beam
    -rw-r--r-- 1 root root 28584 Jun 22 10:17 lager_file_backend.beam
    -rw-r--r-- 1 root root 27444 Jun 22 10:17 lager_format.beam
    -rw-r--r-- 1 root root  9764 Jun 22 10:17 lager_handler_watcher.beam
    -rw-r--r-- 1 root root  2040 Jun 22 10:17 lager_handler_watcher_sup.beam
    -rw-r--r-- 1 root root  3900 Jun 22 10:17 lager_manager_killer.beam
    -rw-r--r-- 1 root root  3584 Jun 22 10:17 lager_msg.beam
    -rw-r--r-- 1 root root  2076 Jun 22 10:17 lager_rotator_behaviour.beam
    -rw-r--r-- 1 root root  6180 Jun 22 10:17 lager_rotator_default.beam
    -rw-r--r-- 1 root root 25704 Jun 22 10:17 lager_stdlib.beam
    -rw-r--r-- 1 root root  4344 Jun 22 10:17 lager_sup.beam
    -rw-r--r-- 1 root root 17332 Jun 22 10:17 lager_transform.beam
    -rw-r--r-- 1 root root 23276 Jun 22 10:17 lager_trunc_io.beam
    -rw-r--r-- 1 root root 31152 Jun 22 10:17 lager_util.beam
    ./opt/gateway_config/lib/lager-3.9.2/include:
    total 8
    -rw-r--r-- 1 root root 7223 Jun 22 10:17 lager.hrl
    ./opt/gateway_config/lib/lager-3.9.2/priv:
    total 4
    ./opt/gateway_config/log:
    total 12
    -rw-r--r-- 1 root root 7524 Jun 23 00:29 erlang.log.1
    -rw-r--r-- 1 root root  304 Jun 22 16:03 run_erl.log
    ./opt/gateway_config/releases:
    total 8
    drwxr-xr-x 2 root root 4096 Jun 22 10:17 0.1.0
    -rw-r--r-- 1 root root   12 Jun 22 10:17 start_erl.data
    ./opt/gateway_config/releases/0.1.0:
    total 92
    -rw-r--r-- 1 root root   656 Jun 22 10:17 gateway_config.rel
    -rw-r--r-- 1 root root 22738 Jun 22 10:17 start.boot
    -rw-r--r-- 1 root root 29383 Jun 22 10:17 start.script
    -rw-r--r-- 1 root root 12615 Jun 22 10:17 start_clean.boot
    -rw-r--r-- 1 root root   819 Jun 22 10:17 sys.config
    -rw-r--r-- 1 root root   111 Jun 22 10:17 vm.args
    ./root:
    total 4
    -rw-rw-r-- 1 root root 95 Jul  6 09:04 crontab
    ./usr:
    total 4
    drwxrwxr-x 3 root root 4096 Jul  5 20:28 local
    ./usr/local:
    total 4
    drwxrwxr-x 2 root root 4096 Nov  9 17:02 bin
    ./usr/local/bin:
    total 12
    -rwxr-xr-x 1 root root 290 Jul  5 20:28 docker-wait.sh
    -rwxr-xr-x 1 root root 690 Nov  9 17:02 region-monitor.sh
    -rwxr-xr-x 1 root root 789 Nov  9 16:50 start-gwconfig.sh
