    FiPy - SMS sending.
    2 Posts 2 Posters 96 Views 2 Watching
      Sunt Beat
      Hello guys,
      I need to send SMS from my FiPy, but cannot attach with lte, does anyone know how to do that?
      thats what im trying
        Pieter Messely
        Hey, adding some code that should get you there and that includes a lot of useful debugging stuff. You'll need to change the apn / band .
        from network import LTE
        # Connect to Mobile
        def connect_mobile(settings):
            lte = LTE()
            connected = False
            display.set_mode("Trying: LTE")
            try:
                lte.init()
                print("LTE init success")
            except:
                print("LTE init failed")
            print(lte.ue_coverage()) # Check network coverage (True, is yes)
            print(lte.send_at_cmd('AT!="fsm"'))
            print(lte.send_at_cmd("AT"))
            print(lte.send_at_cmd("ATI1"))
            print(lte.send_at_cmd("AT+CSMINS?"))
            print(lte.send_at_cmd("AT+CFUN?"))
            print(lte.send_at_cmd('ATI+CIMI')) # Request IMSI
            print(lte.send_at_cmd('ATI+SQNCTM=?'))
            print("Add band, will be much faster")
            #lte.attach(band=None, apn="iot.1nce.net") #band : to scan for networks. If no band (or None) is specified, all bands will be scanned. The possible values for the band are: 3, 4, 5, 8, 12, 13, 20 and 28.
            lte.attach(band=20, apn="iot.1nce.net") # works
            print("attaching..",end='')
            while not lte.isattached():
                time.sleep(0.25)
                print('.',end='')
                print(lte.send_at_cmd('AT!="fsm"'))         # get the System FSM
            print("attached!")
            # once attached
            print(lte.send_at_cmd("AT+CSQ")) # Signal quality, returns <ssid> (), <ber>
            # SSID (received signal strength indication)
            ## 0: -113dBm or less
            ## 1: -111 dBm
            ## 2..30: -109..-53 dBm
            ## 31: -51 dBm or greater (best)
            ## 99: not known or not detectable
            # ber : channel bit error rate in percent
            ## 0..7: see table
            ## 9: not known or not detectable
            lte.connect()
            print("connecting [##",end='')
            while not lte.isconnected():
                time.sleep(0.25)
                print('#',end='')
            print("] connected!")
            print(socket.getaddrinfo('pybytes.pycom.io', 80))
            lte.deinit() # Disables LTE modem completely
            return connected
