    "Error connecting Helium Hotspot Miner with application"
    Scheduled Pinned Locked Moved Helium Hotspot
    1 Posts 1 Posters 20 Views 1 Watching
    • K Offline
      Kanar Al Sammak
      Hello:
      We have two devices (Helium Hotspot Miner), and we have done the following:
      1- The SD card that came installed with the device was removed.
      2- The firmware was flashed on a new SD card (https://software.pycom.io/downloads/pycom-miner.bin.zip).
      3- The new SD card is inserted into the device after the flash.
      4- The booting process indicated that the device was functioning correctly (first a solid green color for the state-led, the one above the power led, then blinking, waiting to be paired)
      5- The pairing process was retried both with the Apple version of the Pymaker app and the Android version.
      The error that we faced:
      • On the Apple devices side, The same error appeared when we tried with the original SD that came with the device: “Could not read firmware version.”
      • The devices could not even be found on the Android version side.
      What are the suggested solutions to solve this problem?
