    MAC OSX Sierra - Pymakr not starting
    macosxsierrapymakr
    6 Posts 2 Posters 228 Views 2 Watching
    • M Offline
      markl
      Hi all
      Finally managed to get thru all the various dependencies and steps at https://github.com/pycom/Pymakr/blob/master/README-MacOSX.rst
      As per other threads on simaler topic I have upgraded MacPorts and all ports are fully up to date
      If I run from command line I get
      pymakr
      /Applications/pymakr.app/Contents/MacOS/pymakr: line 5: /Applications/pymakr.app/Contents/MacOS/pymakr: Argument list too long
      /Applications/pymakr.app/Contents/MacOS/pymakr: line 5: /Applications/pymakr.app/Contents/MacOS/pymakr: Undefined error: 0
      I'm assuming its not happy about something on the below line in the script
      exec "/Applications/pymakr.app/Contents/MacOS/pymakr" "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pymakr/pymakr.py" "$@"
      My limited skills run out of steam at this point sorry
      • M Offline
        markl
        No one seen this issue before?
        I'm evaluating Pycom as a key component in an IoT offering. Not off to a great start it would seem.
          jmarcelino
          I guess not many here tried building Pymakr themselves.
          Does the pre-built version available at https://www.pycom.io/resources/ work?
          Also note Pymakr is no longer recommended as a development tool, instead Pycom is now focused on creating plugins for editors like Atom etc.
          Until the plugins are ready you can just write your Python code in any editor and upload to the board via FTP. For access to Python prompt (REPL) either telnet or screen /dev/your_serial_device_here 115200.
          • M Offline
            markl @jmarcelino
            @jmarcelino Thanks for the reply
            To be 100% clear I did not build Pymakr. This issue is with the pre-built version
              jmarcelino @markl
              @markl
              Oh? I thought the package provided by Pycom for OSX was self contained, I didn't do any of those steps.
              Maybe MacPorts installed conflicting versions of something?
              I definitely don't have Macports, deleted it several months ago and now just use Homebrew.
              • M Offline
                markl @jmarcelino
                @jmarcelino Thanks
                Will check Homebrew info you provided out. Worked out of box on a Linux box that one of the dev's uses and he owns that project for now so the heat is off for a while ;)
                With your input, this post could be even better πŸ’—
