    machine.idle usage
    machine.idleinterruptpower saving
    6 Posts 2 Posters 3.2k Views 2 Watching
      jubbs
      I have a rain gauge hanging off two gpio pins and transmitting via Lora every 15 minutes. Using the expansion board.
      Because I need to count on the interrupt I can't put the device in deep sleep but I want to save as much power as possible. From the docs I understand that the maachine.idle() function is what I need to use.
      Ignoring the interrupts for now I wrote the following test code to put the device to sleep using the machine.idle() function and putting it to sleep without the idle function.
      I was using 36mA using idle and 38mA without. The difference would most likely be the led. This is way too much for my project to last on a battery for any reasonable amount of time.
      What do you suggest?
      Am I using the wrong technique?
      Will there be more power savings in an upcoming firmware?
      Is what I want not realistic?
      boot.py
      from network import WLAN
      from network import Bluetooth
      from machine import UART
      import os
      uart = UART(0, 115200)
      os.dupterm(uart)
      wlan = WLAN()
      wlan.init(mode=WLAN.STA)
      wlan.deinit()
      bt = Bluetooth()
      bt.deinit()
      main.py
      pycom.rgbled(0x000000)
      pycom.rgbled(0x330000)
      time.sleep(10)
      machine.idle()
      time.sleep(20)
      Any help is appreciated?
      Justin
        livius @jubbs
        @jubbs
        As i understand correctly idle it only affect CPU cycles. this can be comparable to:
        while true:
             i+=1
        can eat 100% CPU - and much power
        while true:
             i+=1
             machine.idle()
        should use only a little CPU and little power
        but if you already have inside loop commands which do wait - then you do not see much difference
        Quesiton is what interrupt?
        Because it will be possible to wake up by pin interrupt from deep sleep and i suppose this is your task?
          jubbs
          For the Rain Gauge to be accurate I need to maintain a counter variable. So if I put the unit into deep sleep I can't maintain a count.
          Below is my class for the rain gauge. The main loop collects the drip count every 15mins and transmits to the server.
          from machine import Pin
          class Drips:
              def __init__(self, pin='P11', gnd='P12'): #G20 G22
                  gauge = Pin(pin, mode=Pin.IN, pull=Pin.PULL_UP)
                  Pin(gnd, mode=Pin.IN, pull=Pin.PULL_DOWN)
                  gauge.callback(trigger=Pin.IRQ_RISING, handler=self.drip)
                  self.count = 0
                  self.debounce_timer = 0
              def reset(self):
                  self.count = 0
              def drip(self,p):
                  if(time.time() - self.debounce_timer > 1):
                      self.count += 1
                      self.debounce_timer = time.time()
                  machine.idle()
              def get_count(self):
                  return self.count
            livius @jubbs
            @jubbs
            you can save that counter to file on flash or sd card
              jubbs
              Then I would need a clock to timestamp the drip / count to get accurate rainfall. My understanding is that deepsleep will stop the RTC as well. Any ideas how would I measure time?
                livius @jubbs
                @jubbs
                if you look into table from esp32 documentation
                0_1491285537651_upload-e5f474e5-b58a-4c4b-8081-535cc17f0a86
                than you will see that it depend of exact sleep mode
                but i do not suppose that all modes are now avaiable on current firmware
                but RTC is avaiable in almost all modes
