LoPy lost access, main.py might still run, no more wifi or serial
Updated to latest Firmware 1.6.7b1, uploaded (over wifi/ftp) a Lora main.py which also turned led Red.
After this, Led turns red but also lost all wifi, USB or serial contact.
Tried 3 safe boot options, no change: led will trun red & nothing further.
serial (P0/P1) gives:
ets Jun 8 2016 00:22:57rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0x00
mode:QIO, clock div:2
load:0x3fff9010,len:8
load:0x3fff9018,len:248
load:0x40078000,len:4056
load:0x4009fc00,len:920
entry 0x4009fde4and that's it.
Any idea how to continue or be able to get other boot.py . main.py uploaded?
Rgds,
Frank.
Probably socket is set to blocking?
Usually a safe boot should work in these cases.
Could you explain the steps that you have tried so far in detail? -
Try flashing it again. Also the latest firmware should be 1.6.10.b1 not 1.6.7
Solution was to flash the new firmware, then I could upload again.
Thanks for the tip.Rgds,
Frank
