    I2C sensor with WiPy2
    wipy2.0i2csensor
    28 Posts 8 Posters 11.7k Views 8 Watching
    • E Offline
      Eric24
      @SesamProductions said in I2C sensor with WiPy2:
      VL6180x
      Yes, this is a fairly complex device that requires a lot of initialization (although I would think reading back the model ID could be done without init, but who knows). We used this driver: https://github.com/luciengaitskell/python-adafruit-vl6180x/blob/master/i2c/vl6180x.py
      We've since moved on from using this sensor (it's a very interesting device, but it did not work well in our particular application), but I had no problem communicating with it. In fact, the only problems I've ever had with I2C on any pycom device was with the lack of clock stretching support on the software-based I2C (and now that hardware-based I2C is supported, that's no longer a problem).
        robert-hh @SesamProductions
        @SesamProductions From the spec, I assume that the sequence should be:
        i2c.writeto(0x29, b'\x00\x00')
        i2c.readfrom(0x29, 1)
        The address for a read is a two byte value.
        • I Offline
          iotmaker
          I have it working like this
          VL53L0X_REG_IDENTIFICATION_MODEL_ID=0xc0
          VL53L0X_REG_IDENTIFICATION_REVISION_ID=0xc2
          VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD=  0x50
          VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD=0x70
          VL53L0X_REG_SYSRANGE_START=0x00
          VL53L0X_REG_RESULT_INTERRUPT_STATUS=0x13
          VL53L0X_REG_RESULT_RANGE_STATUS=0x14
          sensor= 0x29#I2C Address
          print("Revision ID ")
          print(i2c.readfrom_mem(sensor,VL53L0X_REG_IDENTIFICATION_REVISION_ID,1))
          print("")
          print("Device ID ")
          print(i2c.readfrom_mem(sensor,VL53L0X_REG_IDENTIFICATION_MODEL_ID,1))
          print("")
          print("Pre Range config Period")
          print(i2c.readfrom_mem(sensor,VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD,1))
          print("")
          print("Final  Period")
          print(i2c.readfrom_mem(sensor,VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD,1))
          #To read first check the status
          val=i2c.readfrom_mem(sensor,VL53L0X_REG_RESULT_RANGE_STATUS,1)
          #if val is equal to 64 then it read the distance
          #read the value
           datasensor=i2c.readfrom_mem(sensor,0x14,12)#Read sensor data
              distance=datasensor[10]*256+datasensor[11]#combine integers
          I have it working on the VL53L0X hope it helps
          C J 3 Replies Last reply Reply Quote 0
            SesamProductions @Eric24
            Thanks for the suggestions!
            YES! That is working! Thank you! I can now read data from registers in a controller way.
            Unfortunately I'm now very confused about this. If the writeto function is used to tell the device what register I want to read, how do I write things to the registers? For instance to tell the device I want it to start measuring range.
            @iotmaker
            To me it looks like you're doing the exakt same thing I'm doing, and according to the short datasheet I found for your sensor, it should work similar to mine.
            So why yours is working and mine is not is definitely beyond me.
            @Eric24
            When I've tried the sensor on the Arduino I've used the Adafruit library your linked code seem to be a python port of. I had myself not found that python version, so what I've done is my own python port of the Adafruit Arduino library. The problem is that in order to deal with all the complexities of the sensor and initialize it, I need to be able to read and write to registers, which is the part that isn't working.
            The python-version you're linking to is using a module called smbus to deal with everything I'm having problems with. Where do I get that from? I didn't find any links for that on the github page, and import smbus is not working on my WiPy. Where you using it on a WiPy, or some other Pycom device?
            I had not heard about smbus before and a quick google for it seem to indicate it's a different, but fairly similar, protocol than i2c. Was there a reason for using smbus instead of the builtin i2c?
            robert-hhR E 2 Replies Last reply Reply Quote 0
              @SesamProductions For writing to a register, just append the data for the register to the address in a single write.
              About @iotmaker's comment. The VL53L0X device he uses requires just an 1 byte address just like the memory devices.
              • E Offline
                Eric24 @SesamProductions
                @SesamProductions I'm afraid I don't have any more information on that library. But smbus is just the I2C library for whatever hardware platform it was written for. You should be able to substitute pycom's I2C functions readfrom_mem and writeto_mem for b.read_byte_data and b.write_byte_data, respectively. But note, I've never actually tried to access 16-bit addresses using pycom's I2C functions. If they don't work, please do submit a bug report, and in that case, you should be able to accomplish the same thing using the writeto and readfrom method that @robert-hh suggested earlier.
                  SesamProductions
                  Great! Now I'm starting to understand this a bit!
                  I can read and write stuff using @robert-hh's suggestions, and the sensor seem to output correct data. Now I just have to modify my library with new read/write methods.
                  Thanks a lot for the help!
                    chumelnicu @iotmaker
                    @iotmaker Hello , can u tell me please what is maximum distance range?
                      @iotmaker Hi , did u read distance using vl53l0x with this code? Wrking and long distance too? i mean 200cm?
                      Thx!
                      • ledbelly2142L Offline
                        ledbelly2142
                        @chumelnicu
                        It's in the specification of the sensor, see HERE that the VL6180X can measure up to 20 cm.
                        The VL53L0X will measure up to 2 Meters (6.6Ft) away. You can see it on a breakout board HERE
                          chumelnicu @ledbelly2142
                          @ledbelly2142 I know the diference between VL6180X and VL53L0X ! The question has target other response and was for @iotmaker
                          I did asked him if he managed to read the VL53L0X in long range mode (that mean 200cm)
                            chumelnicu @SesamProductions
                            @sesamproductions Did u manage to read VL53LX0 in long distance mode?
                            Thx!
                              JasonTimmins @iotmaker
                              @iotmaker Thanks for your code for the VL53L0X distance sensor. I've got the same configuration here and, although I can read the various registers you mention (Revision ID, Device ID, etc), I can't actually get a distance from the thing. VL53L0X_REG_RESULT_RANGE_STATUS is zero all the time and your 'distance' code gives zero too.
                              This looks like a fairly complex device, am I missing some kind of initialisation procedure?
                              Cheers
                              Jason.
                              • I Offline
                                iotmaker @SesamProductions
                                @JasonTimmins
                                This is my full code
                                just clean it up hehe
                                from machine import UART
                                from time import sleep_ms
                                from network import Sigfox
                                from machine import I2C
                                import re
                                import binascii
                                import ubinascii
                                from machine import Pin
                                import ustruct
                                ### Sigfox Stuff
                                sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ2)
                                # create a Sigfox socket
                                s = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW)
                                # print Sigfox Device ID
                                print("Sigfox ID")
                                print(binascii.hexlify(sigfox.id()))
                                # print Sigfox PAC number
                                print("Sigfox PAC")
                                print(binascii.hexlify(sigfox.pac()))
                                # make the socket blocking
                                s.setblocking(True)
                                # configure it as uplink only
                                s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
                                #Sigfox Stuff
                                pycom.heartbeat(False)
                                ##RGB Colors
                                red=0xff0000
                                yellow=0xffff00
                                green=0x00ff00
                                blue=0x0000ff
                                cyan=0x00feff
                                purple=0xc442a1
                                orange=0xff8b55
                                dark=0x000000
                                def ledtoggle(color):
                                    pycom.rgbled(color)
                                    sleep_ms(50)
                                    pycom.rgbled(dark)
                                    sleep_ms(50)
                                def i2c_w(reg,val):
                                    i2c.writeto_mem(sensor,reg,bytes([val]))##Put device on standby mode
                                    sleep_ms(1)
                                ## address 0x1D
                                i2c = I2C(0)                         # create on bus 0
                                i2c = I2C(0, I2C.MASTER)             # create and init as a master
                                i2c.init(I2C.MASTER, baudrate=400000) # init as a master
                                sleep_ms(30)
                                print("I2C Scan for devices")
                                print(i2c.scan())
                                print("")
                                print("Device ID ")
                                print("")
                                print("")
                                sleep_ms(30)
                                print("")
                                cnt=0
                                val=0
                                a=0
                                    #print("Start Measuerment")
                                    i2c_w(VL53L0X_REG_SYSRANGE_START, 0x02)
                                    while (cnt < 100):
                                            #1 second waiting time max
                                        if val==64:
                                            cnt=200
                                        cnt=cnt+1
                                    sleep_ms(30)
                                    #print("distance")
                                    print(distance)
                                    if 100<=distance<=200:
                                            print('Sending Sigfox')
                                            s.send(bytes([datasensor[10], datasensor[11], 255, 255, 255, 255, 255, 255, 255, 255, 255, 255]))
                                            ledtoggle(blue)
                                            ledtoggle(blue)
                                            ledtoggle(blue)
                                            ledtoggle(blue)
                                            print("By law it will sleep 20 seconds")
                                            time.sleep(20)
                                    ledtoggle(green)
                                    # for x in range(0,12):
                                    #     print(datasensor[x])
                                    # print(datasensor)
                                    # print(datasensor[10])
                                    # print(datasensor[11])
                                    # print("")
                                    sleep_ms(1000)```
                                  @iotmaker Thanks, that's got it working. I think I was missing...
                                  It's now sitting here telling me how far my ceiling is above my desk!.. ~1690mm :-)
                                  I see a distance reading on 20mm quite often (30% of the time), why do you suppose that would be?
                                  Thanks again
                                  Jason.
                                  • I Offline
                                    iotmaker @JasonTimmins
                                    @jasontimmins
                                    Yes thats a bug i have on the code, have not dig into it yet on how to fix it.. But if you figure it out, please share :)
                                      @iotmaker , @JasonTimmins Maybe that could help
                                      https://github.com/adafruit/Adafruit_CircuitPython_VL53L0X/blob/master/adafruit_vl53l0x.py
                                        JasonTimmins @chumelnicu
                                        @chumelnicu This looks like a great library but I'm struggling to convert it to work on the Pycom device. Python is not my strong point. How different are Adafruit and Pycom devices?
                                          chumelnicu @JasonTimmins
                                          @jasontimmins Hi , I dont know i suppose is not very hard ... try to find similar conversions for other sensors from Adafruit i2c mode and apply to pycom microphyton ...
                                          Or maybe u should try to use i2c workflow from @iotmaker and rest of code and registers from Adafruit
                                          The single difference that i see is the i2c addressing mode.
                                          I dont know Python programming ...
                                          If u have any result pls share :)
                                          thx!
                                            chumelnicu @chumelnicu
                                            @chumelnicu @JasonTimmins , @iotmaker Any update with VL53L0X library ?
                                            Thank you !
