    I2C sensor with WiPy2
    wipy2.0i2csensor
    28 Posts 8 Posters 11.7k Views 8 Watching
    • I Offline
      iotmaker
      I have it working like this
      VL53L0X_REG_IDENTIFICATION_MODEL_ID=0xc0
      VL53L0X_REG_IDENTIFICATION_REVISION_ID=0xc2
      VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD=  0x50
      VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD=0x70
      VL53L0X_REG_SYSRANGE_START=0x00
      VL53L0X_REG_RESULT_INTERRUPT_STATUS=0x13
      VL53L0X_REG_RESULT_RANGE_STATUS=0x14
      sensor= 0x29#I2C Address
      print("Revision ID ")
      print(i2c.readfrom_mem(sensor,VL53L0X_REG_IDENTIFICATION_REVISION_ID,1))
      print("")
      print("Device ID ")
      print(i2c.readfrom_mem(sensor,VL53L0X_REG_IDENTIFICATION_MODEL_ID,1))
      print("")
      print("Pre Range config Period")
      print(i2c.readfrom_mem(sensor,VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD,1))
      print("")
      print("Final  Period")
      print(i2c.readfrom_mem(sensor,VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD,1))
      #To read first check the status
      val=i2c.readfrom_mem(sensor,VL53L0X_REG_RESULT_RANGE_STATUS,1)
      #if val is equal to 64 then it read the distance
      #read the value
       datasensor=i2c.readfrom_mem(sensor,0x14,12)#Read sensor data
          distance=datasensor[10]*256+datasensor[11]#combine integers
      I have it working on the VL53L0X hope it helps
      C J 3 Replies Last reply Reply Quote 0
        SesamProductions @Eric24
        Thanks for the suggestions!
        YES! That is working! Thank you! I can now read data from registers in a controller way.
        Unfortunately I'm now very confused about this. If the writeto function is used to tell the device what register I want to read, how do I write things to the registers? For instance to tell the device I want it to start measuring range.
        @iotmaker
        To me it looks like you're doing the exakt same thing I'm doing, and according to the short datasheet I found for your sensor, it should work similar to mine.
        So why yours is working and mine is not is definitely beyond me.
        @Eric24
        When I've tried the sensor on the Arduino I've used the Adafruit library your linked code seem to be a python port of. I had myself not found that python version, so what I've done is my own python port of the Adafruit Arduino library. The problem is that in order to deal with all the complexities of the sensor and initialize it, I need to be able to read and write to registers, which is the part that isn't working.
        The python-version you're linking to is using a module called smbus to deal with everything I'm having problems with. Where do I get that from? I didn't find any links for that on the github page, and import smbus is not working on my WiPy. Where you using it on a WiPy, or some other Pycom device?
        I had not heard about smbus before and a quick google for it seem to indicate it's a different, but fairly similar, protocol than i2c. Was there a reason for using smbus instead of the builtin i2c?
        robert-hhR E 2 Replies Last reply Reply Quote 0
          robert-hh @SesamProductions
          @SesamProductions For writing to a register, just append the data for the register to the address in a single write.
          About @iotmaker's comment. The VL53L0X device he uses requires just an 1 byte address just like the memory devices.
          • E Offline
            Eric24 @SesamProductions
            @SesamProductions I'm afraid I don't have any more information on that library. But smbus is just the I2C library for whatever hardware platform it was written for. You should be able to substitute pycom's I2C functions readfrom_mem and writeto_mem for b.read_byte_data and b.write_byte_data, respectively. But note, I've never actually tried to access 16-bit addresses using pycom's I2C functions. If they don't work, please do submit a bug report, and in that case, you should be able to accomplish the same thing using the writeto and readfrom method that @robert-hh suggested earlier.
              SesamProductions
              Great! Now I'm starting to understand this a bit!
              I can read and write stuff using @robert-hh's suggestions, and the sensor seem to output correct data. Now I just have to modify my library with new read/write methods.
              Thanks a lot for the help!
                chumelnicu @iotmaker
                @iotmaker Hello , can u tell me please what is maximum distance range?
                  @iotmaker Hi , did u read distance using vl53l0x with this code? Wrking and long distance too? i mean 200cm?
                  Thx!
                  • ledbelly2142L Offline
                    ledbelly2142
                    @chumelnicu
                    It's in the specification of the sensor, see HERE that the VL6180X can measure up to 20 cm.
                    The VL53L0X will measure up to 2 Meters (6.6Ft) away. You can see it on a breakout board HERE
                      chumelnicu @ledbelly2142
                      @ledbelly2142 I know the diference between VL6180X and VL53L0X ! The question has target other response and was for @iotmaker
                      I did asked him if he managed to read the VL53L0X in long range mode (that mean 200cm)
                        chumelnicu @SesamProductions
                        @sesamproductions Did u manage to read VL53LX0 in long distance mode?
                        Thx!
                          JasonTimmins @iotmaker
                          @iotmaker Thanks for your code for the VL53L0X distance sensor. I've got the same configuration here and, although I can read the various registers you mention (Revision ID, Device ID, etc), I can't actually get a distance from the thing. VL53L0X_REG_RESULT_RANGE_STATUS is zero all the time and your 'distance' code gives zero too.
                          This looks like a fairly complex device, am I missing some kind of initialisation procedure?
                          Cheers
                          Jason.
                          • I Offline
                            iotmaker @SesamProductions
                            @JasonTimmins
                            This is my full code
                            just clean it up hehe
                            from machine import UART
                            from time import sleep_ms
                            from network import Sigfox
                            from machine import I2C
                            import re
                            import binascii
                            import ubinascii
                            from machine import Pin
                            import ustruct
                            ### Sigfox Stuff
                            sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ2)
                            # create a Sigfox socket
                            s = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW)
                            # print Sigfox Device ID
                            print("Sigfox ID")
                            print(binascii.hexlify(sigfox.id()))
                            # print Sigfox PAC number
                            print("Sigfox PAC")
                            print(binascii.hexlify(sigfox.pac()))
                            # make the socket blocking
                            s.setblocking(True)
                            # configure it as uplink only
                            s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
                            #Sigfox Stuff
                            pycom.heartbeat(False)
                            ##RGB Colors
                            red=0xff0000
                            yellow=0xffff00
                            green=0x00ff00
                            blue=0x0000ff
                            cyan=0x00feff
                            purple=0xc442a1
                            orange=0xff8b55
                            dark=0x000000
                            def ledtoggle(color):
                                pycom.rgbled(color)
                                sleep_ms(50)
                                pycom.rgbled(dark)
                                sleep_ms(50)
                            def i2c_w(reg,val):
                                i2c.writeto_mem(sensor,reg,bytes([val]))##Put device on standby mode
                                sleep_ms(1)
                            ## address 0x1D
                            i2c = I2C(0)                         # create on bus 0
                            i2c = I2C(0, I2C.MASTER)             # create and init as a master
                            i2c.init(I2C.MASTER, baudrate=400000) # init as a master
                            sleep_ms(30)
                            print("I2C Scan for devices")
                            print(i2c.scan())
                            print("")
                            print("Device ID ")
                            print("")
                            print("")
                            sleep_ms(30)
                            print("")
                            cnt=0
                            val=0
                            a=0
                                #print("Start Measuerment")
                                i2c_w(VL53L0X_REG_SYSRANGE_START, 0x02)
                                while (cnt < 100):
                                        #1 second waiting time max
                                    if val==64:
                                        cnt=200
                                    cnt=cnt+1
                                sleep_ms(30)
                                #print("distance")
                                print(distance)
                                if 100<=distance<=200:
                                        print('Sending Sigfox')
                                        s.send(bytes([datasensor[10], datasensor[11], 255, 255, 255, 255, 255, 255, 255, 255, 255, 255]))
                                        ledtoggle(blue)
                                        ledtoggle(blue)
                                        ledtoggle(blue)
                                        ledtoggle(blue)
                                        print("By law it will sleep 20 seconds")
                                        time.sleep(20)
                                ledtoggle(green)
                                # for x in range(0,12):
                                #     print(datasensor[x])
                                # print(datasensor)
                                # print(datasensor[10])
                                # print(datasensor[11])
                                # print("")
                                sleep_ms(1000)```
                              @iotmaker Thanks, that's got it working. I think I was missing...
                              It's now sitting here telling me how far my ceiling is above my desk!.. ~1690mm :-)
                              I see a distance reading on 20mm quite often (30% of the time), why do you suppose that would be?
                              Thanks again
                              Jason.
                              • I Offline
                                iotmaker @JasonTimmins
                                @jasontimmins
                                Yes thats a bug i have on the code, have not dig into it yet on how to fix it.. But if you figure it out, please share :)
                                  @iotmaker , @JasonTimmins Maybe that could help
                                  https://github.com/adafruit/Adafruit_CircuitPython_VL53L0X/blob/master/adafruit_vl53l0x.py
                                    JasonTimmins @chumelnicu
                                    @chumelnicu This looks like a great library but I'm struggling to convert it to work on the Pycom device. Python is not my strong point. How different are Adafruit and Pycom devices?
                                      chumelnicu @JasonTimmins
                                      @jasontimmins Hi , I dont know i suppose is not very hard ... try to find similar conversions for other sensors from Adafruit i2c mode and apply to pycom microphyton ...
                                      Or maybe u should try to use i2c workflow from @iotmaker and rest of code and registers from Adafruit
                                      The single difference that i see is the i2c addressing mode.
                                      I dont know Python programming ...
                                      If u have any result pls share :)
                                      thx!
                                        chumelnicu @chumelnicu
                                        @chumelnicu @JasonTimmins , @iotmaker Any update with VL53L0X library ?
                                        Thank you !
