    lopybluetoothblebeaconibeacon
    123 Posts 15 Posters 89.1k Views 14 Watching
      alanm101 @alanm101
      No code change. No power supply change. At the hotel, no problems. The hypothesis that the chip can't handle technologically complex environments appears to have some merit.
      Hopefully a community member will highlight a solution.
        jmarcelino @alanm101
        @alanm101
        I'm afraid it's impossible to highlight any correct solution based on so little information.
        You're saying that the module - mounted on the expansion board, not a breadboard or something custom - stops scanning BLE beacons in "complex technological environments"?
        Can you post what appears in the serial output (from the Expansion Board USB port) from the module when this happens? This is crucial to understanding - and potentially fixing - the problem.
          jcaron
          I wouldn't be too surprised if some specific advertisements could break the scanning code. However without an idea of what that advertisement could be, it might be difficult to find out.
          If you have some other device that can capture all BLE advertisements, it could be useful to get that capture so that each advertisement could then be tested again the BLE code to see how it handles it.
            alanm101
            @jcaron @jmarcelino Thanks for the comments guys. I will be spending quality time on this and will give feedback sometime. No problems when it ran all night at the hotel. Only my 4 iBeacons in range though.
              alanm101 @papasmurph
              @papasmurph Please help me understand how you posted the code? When I try pasting inline, it's a mess. I don't have permission to upload a file.
              papasmurphP 1 Reply Last reply Reply Quote 2
              • papasmurphP Offline
                papasmurph @alanm101
                @alanm101 Three left apostrophs (```) on separate lines before and after the code.
                  @papasmurph Thanks!
                    alanm101 @jmarcelino
                    @jmarcelino My goodness j, I'm embarrassed. Somehow I concluded that the expansion board has a separate debug serial output. So I hooked up on pins G1, G2 and GND as per other posts and found it's the exact same serial output as via the MicroUSB serial output. I'm seeing no extra output other than my own debug print statements. I will post the full source code and the serial output a little later.
                      alanm101 @alanm101
                      @jcaron @jmarcelino Here's the code and the serial output. You will notice that, without warning or raised exception, the scanning becomes unsuccessful at around 3450 seconds (58 minutes). That's indicated by the repeated beacon ID and rssi, despite having moved that beacon out of range when the repetition started. As always, advice greatly appreciated. Options: a) repeat test on Lopy using standard espessif's standard firmware, b) repeat test with a standard ESP32.
                      from network import Bluetooth
                      import gc
                      import binascii
                      mybeaconids = ['d3e0f6cd4ca9','eea068fa3738','f51e1bced835','ea204c29bb1f','e9f1db4814ef']
                      enditall = False
                      pycom.heartbeat(False)
                      timeSleep = 0.01
                      bluetooth = Bluetooth()
                      starttime = time.time()
                      devid = ''
                      rssi = ''
                      def new_adv_event(event):
                          global devid, rssi
                          if event.events() == Bluetooth.NEW_ADV_EVENT:
                              anydata = True
                              while anydata:
                                  adv = bluetooth.get_adv()
                                  if adv != None:
                                      devid = binascii.hexlify(adv[0]).decode('utf-8')
                                      rssi = str(adv[3]*-1)
                                      anydata = False
                      bluetooth.callback(trigger = Bluetooth.NEW_ADV_EVENT, handler = new_adv_event)
                      print('Starting BLE scan')
                      bluetooth.init()
                      bluetooth.start_scan(-1)
                      p_in = machine.Pin("G17",machine.Pin.IN, pull=machine.Pin.PULL_UP)
                      loopcnt = 0
                          loopcnt += 1
                          if not bluetooth.isscanning():
                              print('--------- Restarting BLE scan')
                              bluetooth.deinit()
                              bluetooth.init()
                          # to keep the log manageable, print details only every 500 loops.
                          if loopcnt%500 == 0:
                              print(time.time() - starttime, devid, rssi)
                          if p_in() == 0:
                              print('pin')
                              break
                          time.sleep(0.05)
                      bluetooth.callback(None)
                      bluetooth.stop_scan()
                      bluetooth.deinit()
                      print('Run time in seconds ', time.time() - starttime)
                      ------  Serial output.
                      ets Jun  8 2016 00:22:57
                      configsip: 0, SPIWP:0xee
                      mode:DIO, clock div:1
                      load:0x3fff9010,len:12
                      ho 0 tail 12 room 4
                      load:0x3fff9020,len:388
                      load:0x40078000,len:11584
                      load:0x4009fb00,len:848
                      entry 0x4009fc9c
                      Starting BLE scan
                      25 f51e1bced835 74
                      50 6c8009ac5ece 71
                      75 d5e2f8cf4eab 76
                      100 7e0504d53526 51
                      125 e9f1db4814ef 73
                      150 7e0504d53526 49
                      175 7e0504d53526 52
                      200 730088c7c467 49
                      225 6c8009ac5ece 78
                      250 6c8009ac5ece 72
                      275 d5e2f8cf4eab 75
                      300 d5e2f8cf4eab 75
                      325 d3e0f6cd4ca9 67
                      350 7e0504d53526 49
                      <snip>
                      </snip>
                      2850 6c28333b9548 52
                      2875 73bc08769bce 62
                      2900 d5e2f8cf4eab 66
                      2925 f7201dd0da37 76
                      2950 73bc08769bce 61
                      2975 6c28333b9548 50
                      3000 73bc08769bce 59
                      3025 d5e2f8cf4eab 63
                      3050 73bc08769bce 62
                      3075 ea204c29bb1f 69
                      3100 73bc08769bce 58
                      3125 73bc08769bce 58
                      3150 73bc08769bce 58
                      3175 6c28333b9548 51
                      3200 6c28333b9548 51
                      3225 73bc08769bce 62
                      3250 d3e0f6cd4ca9 63
                      3275 6c28333b9548 50
                      3300 73bc08769bce 58
                      3325 d5e2f8cf4eab 63
                      3350 6c28333b9548 51
                      3375 d5e2f8cf4eab 63
                      3400 6c28333b9548 50
                      3425 6c28333b9548 51
                      3450 73bc08769bce 62
                      3475 73bc08769bce 62
                      3500 73bc08769bce 62
                      3525 73bc08769bce 62
                      3550 73bc08769bce 62
                      3575 73bc08769bce 62
                      3600 73bc08769bce 62
                      3625 73bc08769bce 62
                      3650 73bc08769bce 62
                      3675 73bc08769bce 62
                      3700 73bc08769bce 62
                      3725 73bc08769bce 62
                      pin
                      Run time in seconds  3743
                      MicroPython v1.8.6-776-gd01a46cd on 2017-09-29; LoPy with ESP32
                      J J 2 Replies Last reply Reply Quote 0
                        @alanm101
                        Thank you, that information is very helpful.
                        Yes it would be interesting to compare with the C level ESP-IDF code on the ESP32.
                        I'll look into it in the coming days.
                          jcaron @alanm101
                          @alanm101 What's the advertising interval of your beacons? If you change the advertising interval or the number of beacons, does the time scanning fails change?
                            alanm101 @jcaron
                            @jcaron Time to failure is random. Just ran another test in same controlled environment (home). Failed after 13 minutes.
                            Unfortunately I'm using Estimotes that cannot be transferred to me so frequency is a) fixed, b) unknown. The Estimote app refuses to divulge the info. Nordic's app can't list it either. If it will help, I can move them out of range and turn my phone into an iBeacon for a new test.
                            Update: Can't seem to set update frequency for virtual beacon. At least not with the software I have.
                              jcaron @alanm101
                              @alanm101 AFAIK there’s no frequency selection in BLE, it uses frequency hopping on predefined frequencies.
                                jcaron @jcaron
                                @jcaron ah sorry you meant the frequency of the advertisements. It’s usually not possible to find on the receiver side (as it does not necessarily listen all the time), but there are often ways to change it on the beacon (it’s a matter of compromise between time to discovery and power consumption)
                                  alanm101 @jcaron
                                  @jcaron Yes, I meant broadcast rate/frequency. Apologies. Sadly I can't configure these.
                                    jcaron
                                    @alanm101 this: https://community.estimote.com/hc/en-us/articles/204100806-What-are-the-default-settings-of-Estimote-Beacons-How-to-edit-settings- says you should be able to adjust them.
                                    Alternatively you may want to try to see if varying the number of beacons has an influence on the time to failure. Just in case it’s a simple matter of the code failing after receiving a given number of advertisements (which would also explain the issue you had at the exhibition).
                                      alanm101 @jcaron
                                      @jcaron Sadly, you have to "own" the Estimotes to make changes. The ones I have were allocated to someone else who now has no access to the registered email.
                                      I'm running a test with the native IDF on a DOIT ESP32 board. Hacked the gatt_client.c code. No problems so far (58 minutes).
                                        jcaron @alanm101
                                        @alanm101 haven’t checked the whole thread to see if you already explored this option, but it might be interesting to log free memory and/or call the garbage collector periodically...
                                          alanm101 @jcaron
                                          @jcaron In a past experiment, I called the gc every few cycles. No difference. Free mem. Hmm. That's a good call. Btw, it's now 3 hours with native IDF on a DOIT ESP32 board. No problems.
                                          @all (Edited for clarity) Question: is it safe to flash the native IDF onto a Lopy? That would potentially eliminate hardware and IDF. I suspect flashing the standard IDF won't brick the Lopy, but opinions welcome before I try that.
                                          • FridaF Offline
                                            Frida
                                            20000 then I made a keyboard interrupt, on the latest software.
                                            I have Ruuvi tags running in the other end of my house and recieve from them.
                                            20000 ~ 5.55... hours.
                                            20000 10edb0e93366 74
                                            • 5
                                            • 6
                                            • 7
                                            • 4 / 7
