LoPy pcb female connector
Hi folks,
I can't find the right pcb female connector for LoPy (14 pos, SIL, 2.54mm, Vertical, through hole).
The lopy's male pins are too short to stay firmly inserted in a standard 2.54mm sil connector.
I'm searching a low profile connector similar to the one used on Pycom Expansion board 2.0.
Someone can give me the Mouser or Digikey order code ?
Any help greatly appreciated.
@tcb Thank you!
Sorry just realized these were not 14 position.
I measured the header height on my Pysense and its 5mm
So feeling a tad guilty I did a Google for "Female header 14 2.54 mm 5.00" and found this item which I think should work.
https://www.gct.co/connector/bg095#.WdiHp2iCybg
There were a bunch of others as well but this one had good documentation and I did not know where you are geographically located.
If you get one let me us all know if it works
Cheers
@cocoa try these at Adafruit.
https://www.adafruit.com/product/2940
I have not used them but like you I was looking and could not find any others
