    Update - Pybytes Closed Beta is Live!
    pybytesmiddlewareiotgoinventdata
    12 Posts 6 Posters 4.2k Views 7 Watching
      bucknall @rskoniec
      @rskoniec Can you please attach the main.py from your LoPy?
      Developer Evangelist - Pycom
        rskoniec @bucknall
        @bucknall said in Update - Pybytes Closed Beta is Live!:
          bucknall @rskoniec
          @rskoniec I believe the server might be down for maintenance at the moment - I'm try to work out why you can't send a message to mqtt.pycom.io - please bear with me! Thanks!
            rskoniec @bucknall
            Yeap, could be, because mqtt.pycom.io is not replying for ping requests at the moment.
              jmarcelino @rskoniec
              @rskoniec
              It doesn't respond to ping but the MQTT connection is working fine for me here.
                rskoniec
                Ok. It's working. The problem was that my WiFi network is hidden and that is the issue for default boot.py script.
                  rskoniec @jmarcelino
                  @jmarcelino said in Update - Pybytes Closed Beta is Live!:
                  @rskoniec
                  For me too. Thanks for reply. ;o)
                    robmarkcole @Bettina
                    @Bettina Can I get an invite?
                      Devang Sharma
                      Hello Everyone,
                      I'm working on LoPy. I've tried to register to pybytes beta using the docs given. But, I didn't get any email after following instructions. Please help me with this problem!
                      Thank you.
                        rskoniec @Devang Sharma
                        @devang-sharma When did you try to register? Maybe the first sentence from your link would be helpful: "As Pybytes is being currently run as a Closed Beta, invitations are no longer being given out."
