    Loading pyc Files
    lopymemory
    14 Posts 4 Posters 3.7k Views 4 Watching
      ssmith @robert-hh
      @robert-hh Thanks for the info but that creates another problem. We have units in the field running different FW versions from 1.7.3 on up. Any way to allow those units to load mpy files or is that an RMA?
        robert-hh @ssmith
        @ssmith Sorry no, you need the new firmware. Maybe another advantage of the newer firmware is the option to do OTA updates with it.
          ssmith @robert-hh
          @robert-hh I tried this and am getting this error when running 1.9.0.b1
          >>> import test
          ValueError: invalid .mpy file
          I compiled it using you mpy-cross.exe
          test.py
          def hello_world():
          	print('Hello World from precompile')
          hello_world()
          When I import the .py file it ran.
          Any ideas?
            robert-hh @ssmith
            @ssmith did you use mpy-cross_pycom.exe?
            mpy-cross.exe is for the micropython.org branch, and they are not compatible.
              ssmith @robert-hh
              @robert-hh I did try that but maybe something was out of sync. Just started over and it did work. Thanks! What about OTA? That's is something we're going to need. Can you point me to any info on using that?
              B robert-hhR 2 Replies Last reply Reply Quote 0
                BetterAuto Pybytes Beta @ssmith
                @ssmith said in Loading pyc Files:
                What about OTA?
                https://forum.pycom.io/topic/518/ota-or-not-ota-that-is-the-question
                Also I just posted a tutorial for compiling a custom image for frozen bytecode. MUCH faster and no more out of memory errors.
                https://forum.pycom.io/topic/1919/how-i-built-a-custom-firmware-for-frozen-bytecode
                  robert-hh @ssmith
                  @ssmith In addtion to what @BetterAuto said, a few comments:
                  OTA (Over The Air) stands for firmware update by WiFi.
                  The initial method was simply storing the appimg.bin into /flash/sys with ftp. appimg.bin is created by the build process or extracted from the pycom file package. It requires at least version 1.8.0 to be loaded initially by USB.
                  The primitives used by ftp upload are available in the 'pycom' module. You'll find it in the docs at https://docs.pycom.io/chapter/firmwareapi/pycom/pycom.html. These allow to create your own method for downloading and flashing the image, e.g. using a protocol which ios more secure than non-encrpyted ftp.
                  At the moment, there is a little hiccup involved when you mix OTA and USB flashing.
                  OTA uses two memory areas for the firmware and toggles these. Let's call these A and B. On bootup, the bootloader checks a flag which area is active and starts this one. The USB flash always puts the image in area A and does NOT set the "active" flag accordingly. So, if the active area is B, and you do a firmware update by USB, the new firmware will NOT be excecuted. At the moment you have two options:
                  a) erase flash, which will also clear the file system (not nice)
                  b) do another OTA, which will set again A as the acitve area. Obviously you can use the new image.
                  There is another unrelated hiccup when alternating between firmware images downloaded from Pycom.io and self-built images. The partition maps seem incompatible, leading to either "Red LED frozen devices" or a corrrupted file system. In that case one has to erase flash and reload with the intended method.
                  Both hiccups will be fixed in one of the next versions.
                    ssmith @robert-hh
                    @robert-hh Thank you for all your help. I can now build the code and even managed to write it to flash. Unfortunately, now I think I hit the double buffered code bug. My device boots up but the LED is just solid red. I only get the boot messages on the console and then nothing. How can I erase the flash?
                    Steve
                      robert-hh @ssmith
                      @ssmith To erase flash, just issue the command:
                      make erase
                      in the PC command window. Like flashing it requires the joint between GP3 and GND, and a Reset. After that, you can reflash the device with
                      make BOARD=LOPY flash
                      P.S.: This RED led state happens when you load a self-built image over the Pycom images. This IS a bug, and not fixed since several releases. But as long a you stick with either version, it will not hit you.
                        ssmith @robert-hh
                        @robert-hh That worked great. I'm now able to build the FW with our frozen bytecode. Next step is to figure out the OTA
