    MQTT Client / subscriber
    mqttlopy
    6 Posts 4 Posters 3.2k Views 4 Watching
      Senna
      Hello
      I am a student and for my final project I use a LoPy.
      Great controller, lots of support, I/O, possibilities...
      But now I ran into a problem.
      I want to create an application that needs to send MQTT messages but also has to receive them.
      The first part, sending MQTT messages, is not a problem and is working as described in the examples but I can't figure out how I can receive them.
      I hope one of the more advanced users can help me.
      Thank you a lot
      This is my code:
      def t3_publication(topic, msg):
          print (topic, ':', msg)
          pycom.rgbled(0xff00)
      client = MQTTClient("d:j0y4ca:TestDevice:T04", "j0y4ca.messaging.internetofthings.ibmcloud.com", port=0,  user="use-token-auth", password="mytoken")
      client.settimeout = timeout
      client.connect()
      client.set_callback(t3_publication)
      client.subscribe("iot-2/evt/status")
      time.sleep(1)
      client.check_msg()
      • RobTuDelftR Offline
        RobTuDelft
        What is your full code (excluding sensitive details)?
        Also can you post the result of?
        os.uname()
        Hackster | About me
          Senna @RobTuDelft
          os.uname():
          (sysname='LoPy', nodename='LoPy', release='1.0.1.b1', version='v1.8.6-264-gadacebe on 2016-12-22', machine='LoPy with ESP32')
          main.py
          from simple import MQTTClient
          wlan = WLAN(mode=WLAN.STA)
          wlan.antenna(WLAN.EXT_ANT)
          wlan.connect("IoT", auth=(WLAN.WPA2, "MyPassword"), timeout=5000)
          while not wlan.isconnected():
               machine.idle()
          client = MQTTClient("d:j0y4ca:TestDevice:T04", "j0y4ca.messaging.internetofthings.ibmcloud.com", port=0,  user="use-token-auth", password="MyToken")
          client.settimeout = 5
          client.connect()
          time.sleep(1)
          client.check_msg()
          simple.py
          import ustruct as struct
          class MQTTException(Exception):
              pass
          class MQTTClient:
              def __init__(self, client_id, server, port=0, user=None, password=None, keepalive=0,
                           ssl=False, ssl_params={}):
                  if port == 0:
                      port = 8883 if ssl else 1883
                  self.client_id = client_id
                  self.sock = None
                  self.addr = socket.getaddrinfo(server, port)[0][-1]
                  self.ssl = ssl
                  self.ssl_params = ssl_params
                  self.pid = 0
                  self.cb = None
                  self.user = user
                  self.pswd = password
                  self.keepalive = keepalive
                  self.lw_topic = None
                  self.lw_msg = None
                  self.lw_qos = 0
                  self.lw_retain = False
              def _send_str(self, s):
                  self.sock.write(struct.pack("!H", len(s)))
                  self.sock.write(s)
              def _recv_len(self):
                  n = 0
                  sh = 0
                  while 1:
                      b = self.sock.read(1)[0]
                      n |= (b & 0x7f) << sh
                      if not b & 0x80:
                          return n
                      sh += 7
              def set_callback(self, f):
                  self.cb = f
              def set_last_will(self, topic, msg, retain=False, qos=0):
                  assert 0 <= qos <= 2
                  assert topic
                  self.lw_topic = topic
                  self.lw_msg = msg
                  self.lw_qos = qos
                  self.lw_retain = retain
              def connect(self, clean_session=True):
                  self.sock = socket.socket()
                  self.sock.connect(self.addr)
                  if self.ssl:
                      import ussl
                      self.sock = ussl.wrap_socket(self.sock, **self.ssl_params)
                  msg = bytearray(b"\x10\0\0\x04MQTT\x04\x02\0\0")
                  msg[1] = 10 + 2 + len(self.client_id)
                  msg[9] = clean_session << 1
                  if self.user is not None:
                      msg[1] += 2 + len(self.user) + 2 + len(self.pswd)
                      msg[9] |= 0xC0
                  if self.keepalive:
                      assert self.keepalive < 65536
                      msg[10] |= self.keepalive >> 8
                      msg[11] |= self.keepalive & 0x00FF
                  if self.lw_topic:
                      msg[1] += 2 + len(self.lw_topic) + 2 + len(self.lw_msg)
                      msg[9] |= 0x4 | (self.lw_qos & 0x1) << 3 | (self.lw_qos & 0x2) << 3
                      msg[9] |= self.lw_retain << 5
                  self.sock.write(msg)
                  #print(hex(len(msg)), hexlify(msg, ":"))
                  self._send_str(self.client_id)
                  if self.lw_topic:
                      self._send_str(self.lw_topic)
                      self._send_str(self.lw_msg)
                      self._send_str(self.user)
                      self._send_str(self.pswd)
                  resp = self.sock.read(4)
                  assert resp[0] == 0x20 and resp[1] == 0x02
                  if resp[3] != 0:
                      raise MQTTException(resp[3])
                  return resp[2] & 1
              def disconnect(self):
                  self.sock.write(b"\xe0\0")
                  self.sock.close()
              def ping(self):
                  self.sock.write(b"\xc0\0")
              def publish(self, topic, msg, retain=False, qos=0):
                  pkt = bytearray(b"\x30\0\0\0")
                  pkt[0] |= qos << 1 | retain
                  sz = 2 + len(topic) + len(msg)
                  if qos > 0:
                      sz += 2
                  assert sz < 2097152
                  i = 1
                  while sz > 0x7f:
                      pkt[i] = (sz & 0x7f) | 0x80
                      sz >>= 7
                      i += 1
                  pkt[i] = sz
                  #print(hex(len(pkt)), hexlify(pkt, ":"))
                  self.sock.write(pkt, i + 1)
                  self._send_str(topic)
                  if qos > 0:
                      self.pid += 1
                      pid = self.pid
                      struct.pack_into("!H", pkt, 0, pid)
                      self.sock.write(pkt, 2)
                  if qos == 1:
                      while 1:
                          op = self.wait_msg()
                          if op == 0x40:
                              sz = self.sock.read(1)
                              assert sz == b"\x02"
                              rcv_pid = self.sock.read(2)
                              rcv_pid = rcv_pid[0] << 8 | rcv_pid[1]
                              if pid == rcv_pid:
                                  return
                  elif qos == 2:
                      assert 0
              def subscribe(self, topic, qos=0):
                  assert self.cb is not None, "Subscribe callback is not set"
                  pkt = bytearray(b"\x82\0\0\0")
                  self.pid += 1
                  struct.pack_into("!BH", pkt, 1, 2 + 2 + len(topic) + 1, self.pid)
                  self.sock.write(pkt)
                  self.sock.write(qos.to_bytes(1, "little"))
                  while 1:
                      if op == 0x90:
                          #print(resp)
                          assert resp[1] == pkt[2] and resp[2] == pkt[3]
                          if resp[3] == 0x80:
                          return
              # Wait for a single incoming MQTT message and process it.
              # Subscribed messages are delivered to a callback previously
              # set by .set_callback() method. Other (internal) MQTT
              # messages processed internally.
              def wait_msg(self):
                  res = self.sock.read(1)
                  self.sock.setblocking(True)
                  print(res)
                  if res is None:
                      return None
                  if res == b"":
                      raise OSError(-1)
                  if res == b"\xd0":  # PINGRESP
                      sz = self.sock.read(1)[0]
                      assert sz == 0
                      return None
                  op = res[0]
                  if op & 0xf0 != 0x30:
                      return op
                  sz = self._recv_len()
                  topic_len = self.sock.read(2)
                  topic_len = (topic_len[0] << 8) | topic_len[1]
                  topic = self.sock.read(topic_len)
                  sz -= topic_len + 2
                  if op & 6:
                      pid = pid[0] << 8 | pid[1]
                      sz -= 2
                  msg = self.sock.read(sz)
                  self.cb(topic, msg)
                  if op & 6 == 2:
                      pkt = bytearray(b"\x40\x02\0\0")
                      struct.pack_into("!H", pkt, 2, pid)
                  elif op & 6 == 4:
                      assert 0
              # Checks whether a pending message from server is available.
              # If not, returns immediately with None. Otherwise, does
              # the same processing as wait_msg.
              def check_msg(self):
                  self.sock.setblocking(False)
                  return self.wait_msg()
          RobTuDelftR 1 Reply Last reply Reply Quote 0
            RobTuDelft @Senna
            @Senna
            Your firmware is outdated, please update to the latest v1.6.13.b1.
            Don't use simple.py anymore, it is also outdated.
            Instead go to mqtt and download the new library file there.
            Also check out week 4 of Alex's corner where he explains how to use it.
            Hackster | About me
              bucknall
              Hi @Senna,
              I'm waiting for the docs updates to be pushed live but you'll see an update made to the docs.pycom.io page for MQTT that matches my Alex's Corner video explaining how it all works!
              Might be useful to you!
              https://youtu.be/3NDPSbr5J14?list=PLS09TA19umCOavPeP_FoMHoCuCzjJUWQk
              Developer Evangelist - Pycom
                misterlisty
                Was this issue resolved? Having same issue, same code!
