    [SOLVED] How update LoPy firmware through PySense expansion board
    firmware updatelopypysense
    15 Posts 4 Posters 5.2k Views 4 Watching
      alvaroBT @jmarcelino
      @jmarcelino
      Thanks a lot.
      I'm going to buy a USB to TTL adapter (CP2104)
        @jmarcelino
        How do I conect the CP2104? Does the next picture is correct?
        0_1497268278386_upload-d1354a6a-dc6b-4e65-ac38-390924bf05c7
        The DTR pin Where I do conect it?
          livius @alvaroBT
          @alvaroBT
          No it is not correct
          DO not connect 5V and in the same time 3V3
          And also what is the level of signals from this CP2102 - have it some switch or jumper?
          e.g. this one have jumper
          alt text
          You need 3V3 level on TX/RX pins.
          DTR leave unconnected
            alvaroBT @livius
            @livius
            ok, thanks.
            This is a correct version:
            0_1497268885860_upload-50614d7c-3c57-4984-a2eb-8c4aa54625b9
            Features:
            1. The embedded USB transceiver, without external circuit
            2. It contains the clock circuit, without an external circuit
            3. Reset circuit embedded on electricity
            4. Output voltage regulation can be within 3.3 V voltage
            5. Accord with the requirement of USB2.0 specification
            6. SUSPEND pin support USB state hung
            7. Asynchronous serial data bus controller interface compatible with all shake hands and modulation signal
            8. Support data format for the data of 8, 1, 2, and stop bit parity bit
            9. The connotation of the 512 - byte receive buffer and 512 words
              livius @alvaroBT
              @alvaroBT
              Rx from CP2102 connect to TX
              Tx from CP2102 to Rx
              And connect 5V to 5V pin on Lopy
              But still do not know what signal level is on Rx/Tx.
              I do not see any jumper to change level on Tx/Rx to 3V3.
              Are you sure it is capable to 3V3 level signals output?
                jmarcelino @livius
                That module uses 3.3V levels (native to the CP2102 - modules with that chip that do 5V I/O have voltage translation like e.g. extra FET you can easily spot )
                @alvaroBT Connect 5V supply to LoPy 5V and RX/TX as @livius says.
                I'd still recommend the CP2104 and not the CP2102 because the CP2104 (or the new confusingly named CP2102N) will support faster programming rates, but just nitpicking and the CP2102 will do anyway.
                  @jmarcelino
                  Now only I have just one CP2102.
                  OK, then I use this connection:
                  CP2102 RX --> LoPy TX0 (P1)
                  CP2102 TX --> LoPy RX0 (P0)
                  CP2102 +5V --> LoPy 5V
                  CP2102 GND --> LoPy GND
                  0_1497274697587_upload-c277d745-408c-44c4-aa57-0e59aefbc7fd
                  0_1497274608635_upload-5c138cc6-8b3a-4890-ac94-31881b1b84db
                  Best Regards.
                    jmarcelino @alvaroBT
                    @alvaroBT
                    Yes that's it!
                      @jmarcelino
                      Thanks!!!
                      • F Offline
                        fkoran
                        This worked for me:
