    [ARCHIVED] Downgrading firmware (advanced users)
    firmware
    24 Posts 16 Posters 19.0k Views 19 Watching
      toribios_people @sakis
      @sakis I have tried with linux through VirtualBox and I don't get that error any more, althought the flashing process is not very stable. Took me 6 attempts to get the WiPy flashed, on the other 5 I got this error at ramdom completion percentages:
      Writing at 0x0009400... (80%) Exception: Failed to write compressed data to flash after seq 33 (result was 0xc1, 0x0), on line 132
      Maybe the problem is beacuse of flashing it through a virtual machine.
        sakis @toribios_people
        @toribios_people
        That could be the case (usage of VM). Thanks all for the testing, it seems that this is a Windows-specific issue. I'll report it to our firmware updater expert.
          abilio
          @toribios_people, @sakis, @Knoahlr, @livius, the problem for (up/downgrading) versions 1.0.0.b1 and higher under Windows should be fixed now.
          Can you please download the latest version of the tool, retry the procedure and post your feedbacks?
            Shaun @abilio
            @abilio
            The latest updater on Windows 7 worked for me.
            No more:
            Exception: Error -3 while decompressing: invalid literal/length code, on line 124
              toribios_people
              Works fine here as well, with Windows 10.
                PCA @abilio
                @abilio Where can we find 1.4.0 and 1.5.1.b1 releases ?
                Pascal
                  abilio @PCA
                  @PCA, just upgraded the original list up to the last release :)
                    Colateral
                    Updater Version 1.1.1 on LopY doesn't work anymore
                    d:\Pycom>"c:\Program Files (x86)\Pycom\Pymakr\Python27\python.exe" pyupgrade/bin/updater.py -t 1.5.0.b1-LoPy_868.tar.gz -p COM14 -s 115200 flash
                    Connecting...........................................
                    Exception: Failed to connect to ESP32: Timed out waiting for packet header, on line 157
                    • Y Offline
                      yahia
                      To download higher firmware versions that are not present in the above list; use the below link with the firmware version of choice:
                      https://software.pycom.io/downloads/LoPy_868-1.6.7.b1.tar.gz
                      I am adding this here to keep downgrading related information in one place for future reference.
                        pjoerke
                        I want to downgrade my LoPy. Unfortunately I get an error when running
                        python bin/updater.py -t LoPy_868-1.9.2.b2.tar.gz -p COM12 -s 921600
                        I get the error: "updater.py: error: too few arguments"
                        What's going wrong?
                        Regards
                        Pascal
                        • X Offline
                          Xykon administrators @pjoerke
                          @pjoerke Please use python bin/updater.py -t LoPy_868-1.9.2.b2.tar.gz -p COM12 -s 921600 flash
                          Christian Ehlers
                          • rcolisteteR Offline
                            rcolistete
                            It is worth noting that LoPy4 has different firmware file from v1.13.0.b1 onwards, the diference is simply a '4' after 'LoPy'.
                            Links for direct download :
                            https://software.pycom.io/downloads/LoPy4_868-1.13.0.b1.tar.gz
                            https://software.pycom.io/downloads/LoPy4_915-1.13.0.b1.tar.gz
                            https://software.pycom.io/downloads/LoPy4_868-1.14.0.b1.tar.gz
                            https://software.pycom.io/downloads/LoPy4_915-1.14.0.b1.tar.gz
                            https://software.pycom.io/downloads/LoPy4_868-1.15.0.b1.tar.gz
                            https://software.pycom.io/downloads/LoPy4_915-1.15.0.b1.tar.gz
                              Colateral
                              Hello Abilio,
                              If we building from git, we are getting appimg.bin, lopy_868.bin, also in upper folders bootloader.bin. and partitions bin. There is also a script file in exp32\boards <board> folder
                              I noticed in your LoPy868 tar file lopy_868.bin bootloader.bin partitions.bin, script and ._script files.
                              I can not find "._script" file. How you are generating this file?
                              Thank you
                                aevraewrvaervea
                                  semireg
                                  It'd be nice if https://software.pycom.io/downloads/ had directory listings... or better yet, create a page with all the firmwares along with release notes so we can see what has changed.
                                  • sebS Offline
                                    seb
                                    We will soon be uploading the firmware packages to: https://github.com/pycom/pycom-micropython-sigfox/releases
                                    They are not there yet but will be soon
                                    rcolisteteR 1 Reply Last reply Reply Quote 2
                                      rcolistete @seb
                                      @seb Thanks, from v1.17.0.b1 all firmwares are available at :
