    [ARCHIVED] Downgrading firmware (advanced users)
    firmware
    24 Posts 16 Posters 19.0k Views 19 Watching
    • K Offline
      Knoahlr @sakis
      @sakis seem to be getting the same error code as @toribios_people
      I`m also doing this from a windows machine.
      Namespace(file=None, port='COM7', speed=115200, tar='1.1.0.b1-WiPy.tar.gz')
      Connecting...
      Uploading stub...
      Running stub...
      Stub running...
      Changing baud rate to 115200
      Changed.
      Exception: Error -3 while decompressing: invalid literal/length code, on line 124
        livius
        i try downgrade my wipy to version 1.3.0.b1 but - on Windows 10 64 bit:
        C:\Program Files (x86)\Pycom\Pycom Firmware Update\Python27\pyupgrade>"C:\Program Files (x86)\Pycom\Pycom Firmware Update\Python27\python" "bin\updater.py" -t WiPy.tar.gz -p COM3
        Namespace(file=None, port='COM3', speed=115200, tar='WiPy.tar.gz')
        Connecting...
        Uploading stub...
        Running stub...
        Stub running...
        Changed.
        Exception: Error -3 while decompressing: invalid stored block lengths, on line 131
          toribios_people @sakis
          @sakis I have tried with linux through VirtualBox and I don't get that error any more, althought the flashing process is not very stable. Took me 6 attempts to get the WiPy flashed, on the other 5 I got this error at ramdom completion percentages:
          Writing at 0x0009400... (80%) Exception: Failed to write compressed data to flash after seq 33 (result was 0xc1, 0x0), on line 132
          Maybe the problem is beacuse of flashing it through a virtual machine.
            sakis @toribios_people
            @toribios_people
            That could be the case (usage of VM). Thanks all for the testing, it seems that this is a Windows-specific issue. I'll report it to our firmware updater expert.
              abilio
              @toribios_people, @sakis, @Knoahlr, @livius, the problem for (up/downgrading) versions 1.0.0.b1 and higher under Windows should be fixed now.
              Can you please download the latest version of the tool, retry the procedure and post your feedbacks?
                Shaun @abilio
                @abilio
                The latest updater on Windows 7 worked for me.
                No more:
                  toribios_people
                  Works fine here as well, with Windows 10.
                    PCA @abilio
                    @abilio Where can we find 1.4.0 and 1.5.1.b1 releases ?
                    Pascal
                      abilio @PCA
                      @PCA, just upgraded the original list up to the last release :)
                        Colateral
                        Updater Version 1.1.1 on LopY doesn't work anymore
                        d:\Pycom>"c:\Program Files (x86)\Pycom\Pymakr\Python27\python.exe" pyupgrade/bin/updater.py -t 1.5.0.b1-LoPy_868.tar.gz -p COM14 -s 115200 flash
                        Connecting...........................................
                        Exception: Failed to connect to ESP32: Timed out waiting for packet header, on line 157
                        • Y Offline
                          yahia
                          To download higher firmware versions that are not present in the above list; use the below link with the firmware version of choice:
                          https://software.pycom.io/downloads/LoPy_868-1.6.7.b1.tar.gz
                          I am adding this here to keep downgrading related information in one place for future reference.
                            pjoerke
                            I want to downgrade my LoPy. Unfortunately I get an error when running
                            python bin/updater.py -t LoPy_868-1.9.2.b2.tar.gz -p COM12 -s 921600
                            I get the error: "updater.py: error: too few arguments"
                            What's going wrong?
                            Regards
                            Pascal
                            • X Offline
                              Xykon administrators @pjoerke
                              @pjoerke Please use python bin/updater.py -t LoPy_868-1.9.2.b2.tar.gz -p COM12 -s 921600 flash
                              Christian Ehlers
                              • rcolisteteR Offline
                                rcolistete
                                It is worth noting that LoPy4 has different firmware file from v1.13.0.b1 onwards, the diference is simply a '4' after 'LoPy'.
                                Links for direct download :
                                https://software.pycom.io/downloads/LoPy4_868-1.13.0.b1.tar.gz
                                https://software.pycom.io/downloads/LoPy4_915-1.13.0.b1.tar.gz
                                https://software.pycom.io/downloads/LoPy4_868-1.14.0.b1.tar.gz
                                https://software.pycom.io/downloads/LoPy4_915-1.14.0.b1.tar.gz
                                https://software.pycom.io/downloads/LoPy4_868-1.15.0.b1.tar.gz
                                https://software.pycom.io/downloads/LoPy4_915-1.15.0.b1.tar.gz
                                  Colateral
                                  Hello Abilio,
                                  If we building from git, we are getting appimg.bin, lopy_868.bin, also in upper folders bootloader.bin. and partitions bin. There is also a script file in exp32\boards <board> folder
                                  I noticed in your LoPy868 tar file lopy_868.bin bootloader.bin partitions.bin, script and ._script files.
                                  I can not find "._script" file. How you are generating this file?
                                  Thank you
                                    aevraewrvaervea
                                      semireg
                                      It'd be nice if https://software.pycom.io/downloads/ had directory listings... or better yet, create a page with all the firmwares along with release notes so we can see what has changed.
                                      • sebS Offline
                                        seb
                                        We will soon be uploading the firmware packages to: https://github.com/pycom/pycom-micropython-sigfox/releases
                                        They are not there yet but will be soon
                                        rcolisteteR 1 Reply Last reply Reply Quote 2
                                          rcolistete @seb
                                          @seb Thanks, from v1.17.0.b1 all firmwares are available at :
