    [ARCHIVED] Downgrading firmware (advanced users)
    firmware
    24 Posts 16 Posters 18.7k Views 19 Watching
      abilio
      @toribios_people, @sakis, @Knoahlr, @livius, the problem for (up/downgrading) versions 1.0.0.b1 and higher under Windows should be fixed now.
      Can you please download the latest version of the tool, retry the procedure and post your feedbacks?
        Shaun @abilio
        @abilio
        The latest updater on Windows 7 worked for me.
        No more:
        Exception: Error -3 while decompressing: invalid literal/length code, on line 124
          toribios_people
          Works fine here as well, with Windows 10.
            PCA @abilio
            @abilio Where can we find 1.4.0 and 1.5.1.b1 releases ?
            Pascal
              abilio @PCA
              @PCA, just upgraded the original list up to the last release :)
                Colateral
                Updater Version 1.1.1 on LopY doesn't work anymore
                d:\Pycom>"c:\Program Files (x86)\Pycom\Pymakr\Python27\python.exe" pyupgrade/bin/updater.py -t 1.5.0.b1-LoPy_868.tar.gz -p COM14 -s 115200 flash
                Connecting...........................................
                Exception: Failed to connect to ESP32: Timed out waiting for packet header, on line 157
                • Y Offline
                  yahia
                  To download higher firmware versions that are not present in the above list; use the below link with the firmware version of choice:
                  https://software.pycom.io/downloads/LoPy_868-1.6.7.b1.tar.gz
                  I am adding this here to keep downgrading related information in one place for future reference.
                    pjoerke
                    I want to downgrade my LoPy. Unfortunately I get an error when running
                    python bin/updater.py -t LoPy_868-1.9.2.b2.tar.gz -p COM12 -s 921600
                    I get the error: "updater.py: error: too few arguments"
                    What's going wrong?
                    Regards
                    Pascal
                    • X Offline
                      Xykon administrators @pjoerke
                      @pjoerke Please use python bin/updater.py -t LoPy_868-1.9.2.b2.tar.gz -p COM12 -s 921600 flash
                      Christian Ehlers
                      • rcolisteteR Offline
                        rcolistete
                        It is worth noting that LoPy4 has different firmware file from v1.13.0.b1 onwards, the diference is simply a '4' after 'LoPy'.
                        Links for direct download :
                        https://software.pycom.io/downloads/LoPy4_868-1.13.0.b1.tar.gz
                        https://software.pycom.io/downloads/LoPy4_915-1.13.0.b1.tar.gz
                        https://software.pycom.io/downloads/LoPy4_868-1.14.0.b1.tar.gz
                        https://software.pycom.io/downloads/LoPy4_915-1.14.0.b1.tar.gz
                        https://software.pycom.io/downloads/LoPy4_868-1.15.0.b1.tar.gz
                        https://software.pycom.io/downloads/LoPy4_915-1.15.0.b1.tar.gz
                          Colateral
                          Hello Abilio,
                          If we building from git, we are getting appimg.bin, lopy_868.bin, also in upper folders bootloader.bin. and partitions bin. There is also a script file in exp32\boards <board> folder
                          I noticed in your LoPy868 tar file lopy_868.bin bootloader.bin partitions.bin, script and ._script files.
                          I can not find "._script" file. How you are generating this file?
                          Thank you
                            aevraewrvaervea
                              semireg
                              It'd be nice if https://software.pycom.io/downloads/ had directory listings... or better yet, create a page with all the firmwares along with release notes so we can see what has changed.
                              • sebS Offline
                                seb
                                We will soon be uploading the firmware packages to: https://github.com/pycom/pycom-micropython-sigfox/releases
                                They are not there yet but will be soon
                                rcolisteteR 1 Reply Last reply Reply Quote 2
                                  rcolistete @seb
                                  @seb Thanks, from v1.17.0.b1 all firmwares are available at :
