    LoPy HTTP POST request: OSError!
    http postoserrorssllopyurequest.py
    11 Posts 6 Posters 3.1k Views 7 Watching
      Devang Sharma
      Hello, I'm using LoPy and I was trying to send data to my variables at ubidots web server which has HTTPS protocol. I am using urequests.py library.
      But I am getting below error:
      File "main.py", line 24, in <module>
      File "/flash/lib/urequest.py", line 96, in request
      File "/flash/lib/urequest.py", line 60, in request
      OSError: -32512
      This is the line in which I'm having this error:
      s = ssl.wrap_socket(s, server_hostname=host)
      How can it be solved?
      Thanks.
        livius @Devang Sharma
        @devang-sharma
        which firmware version?
        os.uname()
          Devang Sharma
          @livius, I've recently updated the firmware.
          os.uname()
          (sysname='LoPy', nodename='LoPy', release='1.10.1.b1', version='v1.8.6-839-g536c958c on 2017-11-15', machine='LoPy withESP32', lorawan='1.0.0')
            Devang Sharma
            @livius, I've tried doing it without SSL and it works. But there is still an issue with using SSL.
            RobTuDelftR 1 Reply Last reply Reply Quote 0
            • RobTuDelftR Offline
              RobTuDelft @Devang Sharma
              @devang-sharma have you found a fix in the meanwhile for the -32512 error?
              I'm running into this error too now.
              Hackster | About me
                Devang Sharma @RobTuDelft
                @robtudelft Not yet. But till then what you could do is use the IP address instead of DNS which can be written as HTTP and it will work perfectly fine. It's the secondary thing if you require secure establishment. But this issue should be taken into consideration.
                  ahmedkalnaggar
                  Try using gc after each request
                  gc.collect()
                  V 1 Reply Last reply Reply Quote 1
                    this.wiederkehr
                    @robtudelft said in LoPy HTTP POST request: OSError!:
                    Whenever you get os errors with strange numbers which might be related to sockets and tls you have to do:
                    • translate the number without the sign to hex hex(32512) which is 0x7f00
                    • search for mbedtls and that number. google will come up with https://tls.mbed.org/api/ssl_8h.html
                    • on that page you'll find the reason for the error:
                    #define MBEDTLS_ERR_SSL_ALLOC_FAILED   -0x7F00
                    Memory allocation failed.
                    RobTuDelftR 1 Reply Last reply Reply Quote 2
                      RobTuDelft @this.wiederkehr
                      @this-wiederkehr Thanks, that is very useful. For now I'll just go with the solution of @Devang-Sharma. Any idea why this error might pop up?
                      Hackster | About me
                        Devang Sharma
                        @RobTuDelft Try closing the socket after each request you make as @this-wiederkehr suggested here. It worked for me.
                        • V Offline
                          Valentin Pedrosa @ahmedkalnaggar
                          Same problem happened to me. @ahmedkalnaggar solution solved, memory is not being freed properly.
