Bluetooth services is not started
@nagarjuna-reddy
services = conn.services()
print("get service......") why its not printing -
hi livius iam checking what you said that but not working so please help me
programdef ble_reciever(self):
bluetooth = Bluetooth() print("Scanning 4509 client") bluetooth.start_scan(-1) while True: adv = bluetooth.get_adv() #if adv: #print("Found adv in 4509 client") # try to get the complete name #print(bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL)) # try to get the manufacturer data (Apple's iBeacon data is sent here) #print(binascii.hexlify(bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_MANUFACTURER_DATA))) if adv and bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'LoPy': print("connecting rr Lopy in 4509 client") print("connected Lopy in 4509 client") while True: conn = bluetooth.connect(adv.mac) services = conn.services() for service in services: #time.sleep(3) print("start reading..") if type(service.uuid()) == bytes: print('Reading chars from service = {}'.format(service.uuid())) else: print('Reading chars from service = %x' % service.uuid()) chars = service.characteristics() for char in chars: if (char.properties() & Bluetooth.PROP_READ): print('char {} value = {}'.format(char.uuid(), char.read())) conn.disconnect() print("Disconnected 4509 client") break else: time.sleep(0.050) def ble_transmitter(self): print('Advertising Bluetooth...') bluetooth = Bluetooth() bluetooth.set_advertisement(name='LoPy', service_uuid=b'1234567890abcdef') def conn_cb (bt_o): events = bt_o.events() if events & Bluetooth.CLIENT_CONNECTED: print("Client connected") elif events & Bluetooth.CLIENT_DISCONNECTED: print("Client disconnected") bluetooth.callback(trigger=Bluetooth.CLIENT_CONNECTED | Bluetooth.CLIENT_DISCONNECTED, handler=conn_cb) bluetooth.advertise(True) #Create service and characteristic srv1 = bluetooth.service(uuid='0000000000000000', isprimary=True) chr1 = srv1.characteristic(uuid='0000000000000002', properties=Bluetooth.PROP_INDICATE | Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value='InitialValue') #Create callback for read events on the characteristic def char1_cb(chr): events = chr.events() if events & Bluetooth.CHAR_READ_EVENT : print('Bluetooth.CHAR_READ_EVENT') chr1.callback(trigger=Bluetooth.CHAR_READ_EVENT, handler=char1_cb) #Update the characteristic value very few seconds #i=0 while True: val = 'Value{}'.format(i) print('Setting value: {}'.format(val)) chr1.value(val) #Set the characteristic value - should trigger notification is a client has registered for notifications time.sleep(3) i+=1 -
@nagarjuna-reddy
you removed it before loop but better here if you remove it from loop
only connect before (you have only one disconnect) -
I have the exact same problem.
I am trying to connect two Wipys via bluetooth.
I get the connection on both sides.
But the programm frezzes with the line services = connection.services()Is this a bug or is it a problem with my code?
from network import Bluetooth import binascii bluetooth = Bluetooth() bluetooth.start_scan(-1) adv = None while True: adv = bluetooth.get_adv() if adv and bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'WiPy': if bluetooth.isscanning(): bluetooth.stop_scan() try: connection = bluetooth.connect(adv.mac) while not connection.isconnected(): pass if connection.isconnected(): print("Connected to device with addr = {}".format( binascii.hexlify( adv.mac ) ) ) print("and name = ", bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL)) break except: # start scanning again bluetooth.start_scan(-1) continue print('test1') services = connection.services() print('test2') -
@livius
i cannot understand livius so edit my code and send to me please........ -
i only mean that you must connect only once and for one connect you need one disconnect
below "fixed" code in this matter
i have also added small sleep time - look if it help somehow with your problem (i do not tested this self)def ble_reciever(self): bluetooth = Bluetooth() print("Scanning 4509 client") bluetooth.start_scan(-1) while True: adv = bluetooth.get_adv() #if adv: #print("Found adv in 4509 client") # try to get the complete name #print(bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL)) # try to get the manufacturer data (Apple's iBeacon data is sent here) #print(binascii.hexlify(bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_MANUFACTURER_DATA))) if adv and bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'LoPy': print("connecting rr Lopy in 4509 client") conn = bluetooth.connect(adv.mac) print("connected Lopy in 4509 client") services = conn.services() for service in services: time.sleep(0.050) print("start reading..") if type(service.uuid()) == bytes: print('Reading chars from service = {}'.format(service.uuid())) else: print('Reading chars from service = %x' % service.uuid()) chars = service.characteristics() for char in chars: if (char.properties() & Bluetooth.PROP_READ): print('char {} value = {}'.format(char.uuid(), char.read())) conn.disconnect() print("Disconnected 4509 client") break else: time.sleep(0.050) def ble_transmitter(self): print('Advertising Bluetooth...') bluetooth = Bluetooth() bluetooth.set_advertisement(name='LoPy', service_uuid=b'1234567890abcdef') def conn_cb (bt_o): events = bt_o.events() if events & Bluetooth.CLIENT_CONNECTED: print("Client connected") elif events & Bluetooth.CLIENT_DISCONNECTED: print("Client disconnected") bluetooth.callback(trigger=Bluetooth.CLIENT_CONNECTED | Bluetooth.CLIENT_DISCONNECTED, handler=conn_cb) bluetooth.advertise(True) #Create service and characteristic srv1 = bluetooth.service(uuid='0000000000000000', isprimary=True) chr1 = srv1.characteristic(uuid='0000000000000002', properties=Bluetooth.PROP_INDICATE | Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value='InitialValue') #Create callback for read events on the characteristic def char1_cb(chr): events = chr.events() if events & Bluetooth.CHAR_READ_EVENT : print('Bluetooth.CHAR_READ_EVENT') chr1.callback(trigger=Bluetooth.CHAR_READ_EVENT, handler=char1_cb) #Update the characteristic value very few seconds #i=0 while True: val = 'Value{}'.format(i) print('Setting value: {}'.format(val)) chr1.value(val) #Set the characteristic value - should trigger notification is a client has registered for notifications time.sleep(3) i+=1 -
@livius said in Bluetooth services is not started:
transmitter run in one LoPy and reciever LoPy is connected but not get any values from transmitter side i want to
bolded texti=0
time.sleep(3)
i+=1
this is a transmitter side loop this loop values is getting to once connected reciever is recieved that for loop values but in their not iam getting so please solve my problem -
@nagarjuna-reddy
livius you already edit my code but same problem i am getting what iam expected output is sending before message so please check and replay it arguently. -
ivius
you already edit my code but same problem i am getting what iam expected output is sending before message so please check and replay it urgently. -
hi i am also have a same problem if you success to execute please send your code to me.
Thank you -
@nagarjuna-reddy said in Bluetooth services is not started:
conn.disconnect()
put a sleep time before service loop, that will make the services to read. I tried and it is working.time.sleep(1.0);
print('sleep resumed', conn.services())
print(services)
for service in conn.services(): -
