    Bluetooth services is not started
    Scheduled Pinned Locked Moved Pymakr
    bluetoothserviceslopynot started
    15 Posts 4 Posters 3.1k Views 4 Watching
    • Nagarjuna ReddyN Offline
      Nagarjuna Reddy @livius
      @livius
      hi livius iam checking what you said that but not working so please help me
      program
      def ble_reciever(self):
          bluetooth = Bluetooth()
          print("Scanning 4509 client")
          bluetooth.start_scan(-1)
              adv = bluetooth.get_adv()
              #if adv:
                  #print("Found adv in 4509 client")
                  # try to get the complete name
                  #print(bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL))
                  # try to get the manufacturer data (Apple's iBeacon data is sent here)
                  #print(binascii.hexlify(bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_MANUFACTURER_DATA)))
              if adv and bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'LoPy':
                  print("connecting rr Lopy in 4509 client")
                  print("connected Lopy in 4509 client")
                      conn = bluetooth.connect(adv.mac)
                      services = conn.services()
                      for service in services:
                          #time.sleep(3)
                          print("start reading..")
                          if type(service.uuid()) == bytes:
                              print('Reading chars from service = {}'.format(service.uuid()))
                              print('Reading chars from service = %x' % service.uuid())
                          chars = service.characteristics()
                          for char in chars:
                              if (char.properties() & Bluetooth.PROP_READ):
                                  print('char {} value = {}'.format(char.uuid(), char.read()))
                  conn.disconnect()
                  print("Disconnected 4509 client")
                  break
                  time.sleep(0.050)
      def ble_transmitter(self):
          print('Advertising Bluetooth...')
          bluetooth.set_advertisement(name='LoPy', service_uuid=b'1234567890abcdef')
          def conn_cb (bt_o):
              events = bt_o.events()
              if  events & Bluetooth.CLIENT_CONNECTED:
                  print("Client connected")
              elif events & Bluetooth.CLIENT_DISCONNECTED:
                  print("Client disconnected")
          bluetooth.callback(trigger=Bluetooth.CLIENT_CONNECTED | Bluetooth.CLIENT_DISCONNECTED, handler=conn_cb)
          bluetooth.advertise(True)
          #Create service and characteristic
          srv1 = bluetooth.service(uuid='0000000000000000', isprimary=True)
          chr1 = srv1.characteristic(uuid='0000000000000002', properties=Bluetooth.PROP_INDICATE | Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value='InitialValue')
          #Create callback for read events on the characteristic
          def char1_cb(chr):
              events = chr.events()
              if events & Bluetooth.CHAR_READ_EVENT :
                  print('Bluetooth.CHAR_READ_EVENT')
          chr1.callback(trigger=Bluetooth.CHAR_READ_EVENT, handler=char1_cb)
          #Update the characteristic value very few seconds
          #i=0
              val = 'Value{}'.format(i)
              print('Setting value: {}'.format(val))
              chr1.value(val) #Set the characteristic value - should trigger notification is a client has registered for notifications
              time.sleep(3)
              i+=1
      Ch.nagarjuna reddy
        livius @Nagarjuna Reddy
        @nagarjuna-reddy
        you removed it before loop but better here if you remove it from loop
        only connect before (you have only one disconnect)
        Nagarjuna ReddyN 1 Reply Last reply Reply Quote 0
          st3ty
          I have the exact same problem.
          I am trying to connect two Wipys via bluetooth.
          I get the connection on both sides.
          But the programm frezzes with the line services = connection.services()
          Is this a bug or is it a problem with my code?
          from network import Bluetooth
          import binascii
          adv = None
              if adv and bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'WiPy':
                  if bluetooth.isscanning():
                      bluetooth.stop_scan()
                  try:
                      connection = bluetooth.connect(adv.mac)
                      while not connection.isconnected():
                          pass
                      if connection.isconnected():
                          print("Connected to device with addr = {}".format( binascii.hexlify( adv.mac ) ) )
                          print("and name = ", bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL))
                          break
                  except:
                      # start scanning again
                      continue
          print('test1')
          print('test2')
            @livius
            i cannot understand livius so edit my code and send to me please........
            Ch.nagarjuna reddy
              i only mean that you must connect only once and for one connect you need one disconnect
              below "fixed" code in this matter
              i have also added small sleep time - look if it help somehow with your problem (i do not tested this self)
              			#if adv:
              					time.sleep(0.050)
              					for char in chars:
              				conn.disconnect()
              				break
              				time.sleep(0.050)
              		def conn_cb (bt_o):
              		def char1_cb(chr):
              		#i=0
              			time.sleep(3)
              			i+=1
              Nagarjuna ReddyN 2 Replies Last reply Reply Quote 0
                @livius said in Bluetooth services is not started:
                transmitter run in one LoPy and reciever LoPy is connected but not get any values from transmitter side i want to
                bolded text
                i=0
                time.sleep(3)
                i+=1
                this is a transmitter side loop this loop values is getting to once connected reciever is recieved that for loop values but in their not iam getting so please solve my problem
                Ch.nagarjuna reddy
                  Nagarjuna Reddy @Nagarjuna Reddy
                  @nagarjuna-reddy
                  livius you already edit my code but same problem i am getting what iam expected output is sending before message so please check and replay it arguently.
                  Ch.nagarjuna reddy
                    @livius
                    ivius
                    you already edit my code but same problem i am getting what iam expected output is sending before message so please check and replay it urgently.
                    Ch.nagarjuna reddy
                      Nagarjuna Reddy @st3ty
                      @st3ty
                      hi i am also have a same problem if you success to execute please send your code to me.
                      Thank you
                      Ch.nagarjuna reddy
                        jmahesh @Nagarjuna Reddy
                        @nagarjuna-reddy said in Bluetooth services is not started:
                        conn.disconnect()
                        put a sleep time before service loop, that will make the services to read. I tried and it is working.
                        time.sleep(1.0);
                        print('sleep resumed', conn.services())
                        print(services)
                        for service in conn.services():
                          st3ty @jmahesh
                          @jmahesh
                          I tried it too and it's working.
                          Thank You!
