    LoPy Nano-Gateway
    62 Posts 27 Posters 52.0k Views 31 Watching
      brotherdust
      @Roberto, thanks so much! I was brainstorming how to do this exact thing this week and you've done it better than I could have. =) Do you think adding a checksum function would be useful here or is the underlying protocol ensuring data integrity?
      • bmarkusB Offline
        bmarkus
        There is a CRC used on the physical leyer.
          gertjanvanhethof Pybytes Beta @Roberto
          @Roberto Thanks for the example code!
          Question: Is there a way to use the LoPy as LoRaWAN Gateway (OTAA or ABP)?
          I have a LoRa Node from Elsys (Model ESM5k) which is able to send temperature data.
          I can configure key's on this device using a NFC App on my mobile phone.
          So I want to setup a LoRaWAN connection from that device to the LoPy Gateway.
          How can the LoPy being programmed doing this?
          Is it possible to do this with the LoPy?
          bmarkusB R F 3 Replies Last reply Reply Quote 1
          • bmarkusB Offline
            bmarkus @gertjanvanhethof
            @gertjanvanhethof said in LoPy Nano-Gateway:
            You can not make a LoRaWAN GW with LoPy nor any other SX127x cip based bords which can meet the LoRaWAN specification.
              gertjanvanhethof Pybytes Beta @bmarkus
              @bmarkus
              Thanks for the answer.
              Is it possible to read LoRaWAN data on LoRA level (not WAN level)?
              So building micropython code to get the encrypted data and use the network key to decrypt it and the app key to decrypt the app payload myself.
              Is this an opportunity?
              • bmarkusB Offline
                @bmarkus
                LoRaWAN specification is public, you can decode LoRaWAN packets and if you know the keys you can decrypt. The main issue is the radio layer, you can listen on single frequency and you can decode only a fixed preselected SF.
                  brotherdust
                  @Roberto, both the gateway and node code crash my LoPy's. I did a factory reset on them thinking maybe my code was involved. Nope.
                  Here's the console log:
                  configsip: 0, SPIWP:0x00
                  mode:QIO, clock div:2
                  load:0x3fff9010,len:8
                  load:0x3fff9018,len:312
                  load:0x40078000,len:2348
                  ho 0 tail 12 room 4
                  load:0x4009f000,len:1364
                  entry 0x4009f2f8
                  ˜øXTAL 40Mep 26 2016 22:32:10
                  frc2_timer_task_hdl:3ffda618, prio:22, stack:2048
                  tcpip_task_hdlxxx : 3ffdede4, prio:18,stack:2048
                  phy_version: 123, Sep 13 2016, 20:01:58, 0
                  pp_task_hdl : 3ffea6b4, prio:23, stack:8192
                  mode : softAP(24:0a:c4:00:b6:41)
                  dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1)
                  MicroPython d78a5a3 on 2016-11-05; LoPy with ESP32
                  paste mode; Ctrl-C to cancel, Ctrl-D to finish
                  === import socket
                  === import struct
                  === from network import LoRa
                  === # A basic package header, B: 1 byte for the deviceId, B: 1 byte for the pkg size, %ds: Formated string for string
                  === _LORA_PKG_FORMAT = "!BB%ds"
                  === # A basic ack package, B: 1 byte for the deviceId, B: 1 bytes for the pkg size, B: 1 byte for the Ok (200) or error messages
                  === _LORA_PKG_ACK_FORMAT = "BBB"
                  === # Open a LoRa Socket, use rx_iq to avoid listening to our own messages
                  === lora = LoRa(mode=LoRa.LORA, rx_iq=True)
                  === lora_sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
                  === lora_sock.setblocking(False)
                  === while (True):
                  ===     recv_pkg = lora_sock.recv(512)
                  ===     if (len(recv_pkg) > 2):
                  ===         recv_pkg_len = recv_pkg[1]
                  ===         device_id, pkg_len, msg = struct.unpack(_LORA_PKG_FORMAT % recv_pkg_len, recv_pkg)
                  === # If the uart = machine.UART(0, 115200) and os.dupterm(uart) are set in the boot.py this print should appear in the serial port
                  ===         print('Device: %d - Pkg:  %s' % (device_id, msg))
                  ===         ack_pkg = struct.pack(_LORA_PKG_ACK_FORMAT, device_id, 1, 200)
                  ===         lora_sock.send(ack_pkg)
                  Task watchdog got triggered. The following tasks did not feed the watchdog in time:
                  Tasks currently running:
                  CPU 0: MicroPy
                  Aborting.
                  Guru Meditation Error: Core   0 panic'ed (Unhandled debug exception)
                  Register dump:
                  PC      :  400e7078  PS      :  00060036  A0      :  800f221e  A1      :  3ffd5440
                  A2      :  0000000a  A3      :  0000000a  A4      :  00000004  A5      :  00000000
                  A6      :  00000000  A7      :  fffffff8  A8      :  00000000  A9      :  3ffd53b0
                  A10     :  00000000  A11     :  3ffdd923  A12     :  3ffd537f  A13     :  00000030
                  A14     :  00000000  A15     :  00000200  SAR     :  00000013  EXCCAUSE:  00000001
                  EXCVADDR:  00000000  LBEG    :  4000c46c  LEND    :  4000c477  LCOUNT  :  00000000
                  CPU halted.
                  R 2 Replies Last reply Reply Quote 0
                  • K Offline
                    KDHeard
                    @Roberto @daniel I have the same issue as brotherdust.
                    Reading up about the 'struct' I found a commen that in ypython the name if the module has changed - refer point 11:
                    https://github.com/micropython/micropython/wiki/Differences
                    I changed the code to reflect 'ustruct' and the LoPys no longer crash and I can still see them with my Pymakr - however they are not connecting..
                    Kind regards
                    Kevin Heard - Founder
                    DLI Systems
                    www.dli.systems| Do - Learn - Improve
                      Roberto @brotherdust
                      Hi @brotherdust,
                      A CRC its not required as it is included in the protocol. You can still implement it if you want. I tried this in a project we have running just to make sure and all the checksums are positive
                        Roberto @gertjanvanhethof
                        Hi @gertjanvanhethof
                        I'll provide a new code example this week on the blog section that might answer your question.
                        Best,
                        Roberto
                          Hi @brotherdust
                          This issue is not related to the nano-gateway code, it is a known issue regarding the WatchDog and we will be addressing it soon, i'll keep you informed with a fix for this.
                            Hi @brotherdust,
                            The watchdog problem was fixed in the new firamware version, please download it since this is important not only for the nano-gateway but for all the other apps you want to run as well.
                            The update is here:
                            https://www.pycom.io/support/supportdownloads/
                            Please test the nano-gateway code afterwards to make sure that everything is working
                            Best,
                            Roberto
                            • K Offline
                              kgadeshi
                              @Roberto
                              Is it possible to implement some kind of ranging algorithm in LoRa. So that one can calculate the distance between the nodes to the gateway or something along those lines? Thanks.
                                livius
                                time measurement should be then in nanoseconds i believe
                                you can send signal and wait for receive and calc distance divide time by two ;-)
                                  @kgadeshi with the RSSI of the received packet and knowing the amount of power that was used to transmit it, the free space loss formula can be used to estimate the distance between the 2 nodes.
                                    Batilan
                                    You might also have a look at these resources:
                                    • An extensive discussion on the TTN forum
                                    • An article by Linklabs stating the issues especially for LoRa (they do have competing products, but the reasoning seems sound)
                                    • X Offline
                                      Xykon administrators
                                      After quite a bit of trial and error I have managed to get the LoPy to "talk" in P2P mode to a Dragino LoRa/GPS hat (which uses the same SX1272 chip that's in the LoPy.
                                      For anyone interested I have posted some more details here and have made the source code for the LoPy and Raspberry Pi available on github.
                                      Christian Ehlers
                                      A 1 Reply Last reply Reply Quote 4
                                        arista @Xykon
                                        This is extremely exiting, since I have exactly the same hardware! I hope I'll have some time this month to test your code, @Xykon, and make the bits fly.
                                          angel.imaz
                                          Hello.
                                          It would be great to get a proper tutorial on how to do a http request from a lora through a nano gateway.
                                          I backed you in KS because you made a big point of making this possible. It is great to have the device. But really not very user friendly at all. And you are already launching a new one with more radios. Yet you still have not make LoPy work as promised.
                                          Please help!
                                          Thank you!
                                          Angel
                                            bioagbob @angel.imaz
                                            Ditto. What's LoRa without a gateway!? Time for proper documentation on this product feature.
                                            • 1 / 4
