    failed to set dtr/rts
    lopypysensepymakr
    25 Posts 6 Posters 17.5k Views 6 Watching
    • on4aaO Offline
      on4aa @on4aa
      I also tried disabling the Modem Manager service as this has been seen to interfere with other development boards. It did not cure the problem, though.
      $ sudo systemctl disable ModemManager.service
      • on4aaO Offline
        on4aa
        I made some progress. ModemManager is part of the problem as Pycom devices are not blacklisted in the following file:
        $ less /lib/udev/rules.d/77-mm-usb-device-blacklist.rules
        Editing this file is of no use since it will be overwritten with any update.
        One may file a bug report against ModemManager to have Pycom devices added to this system file.
        User device rules reside in /etc/udev/rules.d/. These device rule files take precedence over those located in /lib/udev/rules.d/ if their name is identical.
        Hence, a file under a different name was created, namely 77-mm-pycom.rules:
        $ sudo vim /etc/udev/rules.d/77-mm-pycom.rules
        which contains the following rule:
        # All devices from Pycom LTD
        ATTRS{idVendor}=="04d8", ENV{ID_MM_DEVICE_IGNORE}="1"
        If only the most recent Pysense devices are to be blacklisted, use:
        # Pycom Pysense
        ATTRS{idVendor}=="04d8", ATTRS{idProduct}=="f012", ENV{ID_MM_DEVICE_IGNORE}="1"
        Similarly for the most recent Pytrack devices:
        # Pycom Pytrack
        ATTRS{idVendor}=="04d8", ATTRS{idProduct}=="f013", ENV{ID_MM_DEVICE_IGNORE}="1"
        I do not own any other or earlier version expansion boards. These will undoubtedly carry another idProduct. Since Pycom is not producing any modems, it is safe to blacklist all Pycom LTD devices.
        RESULT
        Upon device connection, there is no longer a failed to set dtr/rts error in the dmesg listing.
        However, it reappears there when attempting a ./update, which still fails.
        The TCP: request_sock_TCP: Possible SYN flooding on port nnnnn. Sending cookies. Check SNMP counters. still appears in dmesg at device connection.
        CONCLUSION
        ModemManager was part of the problem. There is still another unresolved issue.
        PS: I find it hard to believe there are so few people developing on Pycom with Ubuntu.
        on4aaO 1 Reply Last reply Reply Quote 0
        • on4aaO Offline
          on4aa @on4aa
          In the ./update script, the error occurs at get_wmac.
          Manually running ./updater.py results in:
          $ ./updater.py --port "/dev/ttyACM0" --speed 115200 wmac
          Connecting...
          Exception: [Errno 32] Broken pipe, on line 161
          • on4aaO Offline
            on4aa @on4aa
            The same issue seems to affect any attempt to upgrade the firmware of the Pysense or Pytrack itself (instead of the plugged in LoPy): dfu-util: Cannot open DFU device 04d8:f014
            dfu-util -D pytrack_0.0.8.dfu
            dfu-util 0.8
            Copyright 2010-2014 Tormod Volden and Stefan Schmidt
            Please report bugs to dfu-util@lists.gnumonks.org
            Match product ID from file: f014
            dfu-util: No DFU capable USB device available
            • on4aaO Offline
              on4aa @on4aa
              (LoPy) module updates via the Pysense or Pytrack board is neither currently possible with other GNU/Linux distributions; for example Manjaro XFCE, which I tried.
              From what I am reading, GNU/Linux users can only install module firmware upgrades using the ordinary Expansion board, which I currently do not own.
                livius @on4aa
                @on4aa
                And also by any 3V3 UART/TTL converter
                • X Offline
                  Xykon administrators
                  It should also be possible to upgrade the esp32 firmware using the Pytrack / Pysense by disabling high speed transfer and connecting a jumper wire between Pin 1 and Pin 5 on the external IO header.
                  We're planning to release a new firmware update tool today (or very shortly) that will support updating via Pysense / Pytrack using high speed transfer and without needing a jumper wire.
                  This should work on all operating systems when using the GUI version of the firmware update tool. This will not initially work with the dialog based cli updater that is included in the Linux version of the firmware update tool, but I will post some workaround instructions when the software is released.
                  Christian Ehlers
                  on4aaO 2 Replies Last reply Reply Quote 0
                  • on4aaO Offline
                    on4aa @Xykon
                    @xykon
                    I could update the firmware of the Pysense & Pytrack boards, but still no luck with the ESP32 firmware.
                    $ sudo dfu-util -D pysense_0.0.8.dfu
                    $ sudo dfu-util -D pytrack_0.0.8.dfu
                    The sudo should be added to the documentation.
                    • on4aaO Offline
                      on4aa @Xykon
                      @xykon
                      At last, success! The ESP32 firmware update (GUI-version) succeeded now, after creating /etc/udev/rules.d/77-mm-pycom.rules containing:
                      # Since Pycom is not producing any modems, it is safe to blacklist all Pycom LTD devices.
                      and rebooting! (I probably forgot to do so late last night.)
                      I am not sure whether first upgrading the firmware of the Pysense or Pytrack board with sudo dfu-util is a necessary preceding step, but that is what I did first.
                      Anyhow, I filed a ModemManager bug report so that fellow Pycom developers on GNU/Linux will no longer be bothered with this issue in the future.
                      J 1 Reply Last reply Reply Quote 2
                        jmarcelino @on4aa
                        @on4aa
                        Thanks a lot for your investigation but I have to say 0x04d8 is Microchip's vendor ID (Pycom uses a Microchip PIC micro for the USB-serial interface and we sublicense their VID) so it's probably unwise to add it as a general rule for all ModemManager installs.
                        on4aaO 2 Replies Last reply Reply Quote 2
                        • X Offline
                          Xykon administrators @on4aa
                          @on4aa said in failed to set dtr/rts:
                          A better solution is to use sudo usermod -a -G dialout $USER once and then logout or reboot your PC. Then you can use dfu-util without sudo.
                          I will make sure this gets added to the documentation.
                          Christian Ehlers
                          on4aaO 1 Reply Last reply Reply Quote 1
                          • on4aaO Offline
                            on4aa @jmarcelino
                            @jmarcelino
                            Well, then a list of all of Pycom's current (and planned?) idProduct values is needed. See examples below.
                            Any future additions will have to be reported to freedesktop.org ModemManager maintainers.
                            • on4aaO Offline
                              on4aa @Xykon
                              @xykon Oddly enough, I have been a member of the dialout group long before this. This is why it also surprised me.
                              Either the python script is not getting full privileges or I was not trained at the beginning with pressing the buttons. This needs more testing.
                              PS: A reputation point or so is more than welcome. As a newbee I have nada ;-)
                              • on4aaO Offline
                                on4aa @jmarcelino
                                @jmarcelino The ModemManager bug report has been amended for the Pysense & Pytrack; which is all I have.
                                Can some good soul look up the idVendor and idProduct for the other boards (Expansionboard v1&2 etc.)?
                                Doing so allows the ModemManager maintainers to be correctly informed.
                                @xykon Today's new pycom_firmware_update_1.1.4.b1 GUI updater also works flawlessly!
                                PS: Reputation points, please, I have to wait 10 minutes between every post…
                                J 1 Reply Last reply Reply Quote 3
                                  jmarcelino @on4aa
                                  @on4aa
                                  Thanks a lot! That should cover all the current boards - the Expansion board (v1,v2) is based on the super popular FTDI USB-Serial chip - it's not PIC based - so it should have no problem.
                                  I'll make a note to submit new IDs to ModemManager as new products arise.
                                  • on4aaO Offline
                                    on4aa @jmarcelino
                                    @jmarcelino Because of the Microchip VID sublicensing, it will be not always clear if Pycom products are being dealt with. For this reason, the ModemManager maintainer has added the Pysense and Pytrack rules to 77-mm-usb-serial-adapters-greylist.rules.
                                    Neither is this bad, because ModemManager will try to make a connection only when run manually. Automatic annoyances will be a thing of the past over a month of 2­—3, when the ModemManager updates will roll into stable GNU/Linux releases.
                                    • on4aaO Offline
                                      on4aa
                                      What Removed Added
                                      Resolution --- FIXED
                                      Status REOPENED RESOLVED
                                      Comment # 5 on bug 104320 from Aleksander Morgado
                                      I've pushed the 2 blacklisted devices with rules including vid:pid, but I've
                                      also added the whole vid to the "usb adapters greylist", which are only probed
                                      if manually requested to do so, so should help to avoid interference with other
                                      Microchip-vid-tagged devices.
                                      https://cgit.freedesktop.org/ModemManager/ModemManager/commit/?id=c2b956aefce495865cbdcb9971e2b3cd99cd0e99
                                      All fine & dandy in the end…
