    Set Cellular Access Point Name (APN)
    ltegpyfipycellular
    51 Posts 14 Posters 24.1k Views 15 Watching
      Denisslevi
      I have the same problem - need to set APN;
      How can I do that? direct AT command control - would be the best option.
      Please advice.
      Thanks.
      Regards,
        jmarcelino @benstr
        Hi @benstr,
        Thanks for the question but the main issue in your case is that LTE-M modem has not been approved (whitelisted) by Verizon yet, that process is currently underway (ETA on that is one to two weeks)
        We'll add configuration options and suggested connection "recipes" for our certified carriers as required.
        We can provide a "debug" AT command mode, but you won't be able to connect using that as the IP stack needs to tie in with the modem.
        L D ahaw021A 3 Replies Last reply Reply Quote 1
          livius @jmarcelino
          @jmarcelino
          I suppose that APN is definitly needed.
          think about private APN in GSM operator network with "custom" name.
            jmarcelino @livius
            @livius
            Yep, I'm not saying we won't have different APN configurations. We'll definitely have those - and more.
            The current LTE stack is more of a preview and will evolve as we get approved by the networks and also from feedback by networks and users.
            Also note LTE Cat M1 is slightly different from GSM, most carriers view it as a different service, require different SIM cards etc.
            • benstrB Offline
              benstr
              @jmarcelino thanks for the additional information, appreciate it!
              One of the benefits of using Hologram.io is you can use uncertified modems on all the U.S. carrier networks. If we had the ability to change the APN to "hologram" the Sequans modem would have access to ATT and Verizon Cat-M networks as a roaming device.
              Debug mode sounds helpful too!
              Cheers
              J B 2 Replies Last reply Reply Quote 1
                jmarcelino @benstr
                @benstr
                Thanks Ben, that is surprising news on the uncertified modems/roaming but hey if it really works like that I'll take it :-)
                I've reached out by e-mail already but let me get a test firmware built for you, hopefully you can do some testing and we'll take it from there.
                Cheers
                benstrB 1 Reply Last reply Reply Quote 0
                • benstrB Offline
                  benstr @jmarcelino
                  @jmarcelino thanks! Looking forward to the test firmware.
                  ...checking my email
                    rskoniec
                    @jmarcelino, @benstr I'm also interested in Hologram.io, so please give a feedback how the test firmware is doing. Thanx in advance. :)
                      Denisslevi @jmarcelino
                      @jmarcelino Yes, we also looking for set custom APN. Our company here in Canada has own private APN for all our devices. Would be nice to have function to direct control AT commands. (such as: return = sendAT('AT'), or return = sendAT('AT+CGDCONT=1.....') and etc.)
                        @jmarcelino Thanks for quick replay,
                        is may be it my case : on debug:
                        " [..+CEREG: 2,4....OK..]C, restarting...AT COMMAND: [AT+CEREG?..]ATBAD RESPONSE: [..+CEREG: 2,4....OK..]C, restarting.."
                        Do I need to talk to my networks provider for CAT1 different sim and etc?
                        Thanks again!~
                        Regards.
                          jmarcelino @Denisslevi
                          Hi @Denisslevi
                          Yes CEREG: 2,4 means the device can't reach a network (ie. you're out of coverage)
                          From their announcement I believe Bell Canada will only have a LTE-M (Cat M1, note the M it's not Cat1) network in the coming year (2018): http://www.bce.ca/news-and-media/releases/show/Bell-to-launch-LTE-M-network-to-transform-the-way-Canadians-use-the-Internet-of-Things-1
                          Telus and Rogers as far as I know will come later. If you find anything more please let me know.
                            @jmarcelino Thank you again. Yes, we are partner with Telus and other... all of them working on beta right now....
                            I am sorry for off-top: jmarcelino is any way you may contact me by email please.We would like get more information (include OEM) of your products but I sent email to sales - no response from there.
                            Regards,
                            Denis
                              bali
                              @jmarcelino
                              What's the ETA for the firmware that will support APN settings? Is the modem in the Gpy AT&T certified?
                              Thanks.
                                jmarcelino @bali
                                @bali
                                We'll have APN and other settings soon. The modem itself is certified with AT&T certified but that's not enough, AT&T in particular requires PTCRB and AT&T approval of the device too. These are in progress.
                                We're working with Verizon first.
                                  bali @jmarcelino
                                  @jmarcelino Can you please be a little bit more specific what "soon" means? Days, weeks? Thanks.
                                    jmarcelino @bali
                                    @bali
                                    Days. It's not just the APN we're working on other things. Thanks for your patience.
                                    May I know which network you're looking to connect to?
                                    B L M 4 Replies Last reply Reply Quote 1
                                      bali @jmarcelino
                                      @jmarcelino
                                      I'm planning on connecting to AT&T. I already have hundreds of devices on AT&T's network through LTE CAT 1 modems, but need better building propagation for remote monitoring assets deep inside buildings. Thanks
                                        camdenkrupala
                                        I'm in a similar situation to @bali. Excited to see the addition of APN coming so soon!
                                          bali @jmarcelino
                                          @jmarcelino
                                          Any updates on the release?
                                          • F Offline
                                            fkoran
                                            Also very interested in a configurable APN. In the US, intending to use the FiPy with hologram. io
                                            • 1 / 3
