    Set Cellular Access Point Name (APN)
    ltegpyfipycellular
    51 Posts 14 Posters 23.2k Views 15 Watching
    • benstrB Offline
      benstr
      @jmarcelino thanks for the additional information, appreciate it!
      One of the benefits of using Hologram.io is you can use uncertified modems on all the U.S. carrier networks. If we had the ability to change the APN to "hologram" the Sequans modem would have access to ATT and Verizon Cat-M networks as a roaming device.
      Debug mode sounds helpful too!
      Cheers
      J B 2 Replies Last reply Reply Quote 1
        jmarcelino @benstr
        @benstr
        Thanks Ben, that is surprising news on the uncertified modems/roaming but hey if it really works like that I'll take it :-)
        I've reached out by e-mail already but let me get a test firmware built for you, hopefully you can do some testing and we'll take it from there.
        Cheers
        benstrB 1 Reply Last reply Reply Quote 0
        • benstrB Offline
          benstr @jmarcelino
          @jmarcelino thanks! Looking forward to the test firmware.
          ...checking my email
            rskoniec
            @jmarcelino, @benstr I'm also interested in Hologram.io, so please give a feedback how the test firmware is doing. Thanx in advance. :)
              Denisslevi @jmarcelino
              @jmarcelino Yes, we also looking for set custom APN. Our company here in Canada has own private APN for all our devices. Would be nice to have function to direct control AT commands. (such as: return = sendAT('AT'), or return = sendAT('AT+CGDCONT=1.....') and etc.)
                @jmarcelino Thanks for quick replay,
                is may be it my case : on debug:
                " [..+CEREG: 2,4....OK..]C, restarting...AT COMMAND: [AT+CEREG?..]ATBAD RESPONSE: [..+CEREG: 2,4....OK..]C, restarting.."
                Do I need to talk to my networks provider for CAT1 different sim and etc?
                Thanks again!~
                Regards.
                  jmarcelino @Denisslevi
                  Hi @Denisslevi
                  Yes CEREG: 2,4 means the device can't reach a network (ie. you're out of coverage)
                  From their announcement I believe Bell Canada will only have a LTE-M (Cat M1, note the M it's not Cat1) network in the coming year (2018): http://www.bce.ca/news-and-media/releases/show/Bell-to-launch-LTE-M-network-to-transform-the-way-Canadians-use-the-Internet-of-Things-1
                  Telus and Rogers as far as I know will come later. If you find anything more please let me know.
                    @jmarcelino Thank you again. Yes, we are partner with Telus and other... all of them working on beta right now....
                    I am sorry for off-top: jmarcelino is any way you may contact me by email please.We would like get more information (include OEM) of your products but I sent email to sales - no response from there.
                    Regards,
                    Denis
                      bali
                      @jmarcelino
                      What's the ETA for the firmware that will support APN settings? Is the modem in the Gpy AT&T certified?
                      Thanks.
                        jmarcelino @bali
                        @bali
                        We'll have APN and other settings soon. The modem itself is certified with AT&T certified but that's not enough, AT&T in particular requires PTCRB and AT&T approval of the device too. These are in progress.
                        We're working with Verizon first.
                          bali @jmarcelino
                          @jmarcelino Can you please be a little bit more specific what "soon" means? Days, weeks? Thanks.
                            jmarcelino @bali
                            @bali
                            Days. It's not just the APN we're working on other things. Thanks for your patience.
                            May I know which network you're looking to connect to?
                            B L M 4 Replies Last reply Reply Quote 1
                              bali @jmarcelino
                              @jmarcelino
                              I'm planning on connecting to AT&T. I already have hundreds of devices on AT&T's network through LTE CAT 1 modems, but need better building propagation for remote monitoring assets deep inside buildings. Thanks
                                camdenkrupala
                                I'm in a similar situation to @bali. Excited to see the addition of APN coming so soon!
                                  bali @jmarcelino
                                  @jmarcelino
                                  Any updates on the release?
                                  • F Offline
                                    fkoran
                                    Also very interested in a configurable APN. In the US, intending to use the FiPy with hologram. io
                                    • ahaw021A Offline
                                      ahaw021 @jmarcelino
                                      @jmarcelino could you please let us know how to do this? I am happy to talk to the module directly and set up sockets at the modem end as needed
                                      @benstr - do you have a hologram LTE-M sim card? I thought they currently were only doing 2G/3G sim cards only
                                      Andrei
                                      • benstrB Offline
                                        benstr @ahaw021
                                        @ahaw021 all of our SIM cards are global 2G/3G/4G/Cat-M1 (and soon to be NB). If you’re having troubles connecting to an M1 network you may have an older SIM that requires manual upgrade. You can keep the SIM and request the upgrade by contacting success@hologram.io
                                        Again, this is pretty rare and nearly all of our SIMs are automatically upgraded as new service partners and cellular technology is released. This is one of the cool advantages of our software-defined network. 😀
                                        ahaw021A 1 Reply Last reply Reply Quote 1
                                        • ahaw021A Offline
                                          ahaw021 @benstr
                                          @benstr thanks for clarifying that our for me
                                          Do you have any Australian NB-IOT providers?
                                          • benstrB Offline
                                            benstr @ahaw021
                                            @ahaw021 Looks like we provide access to Optus and Telstra networks. Not sure if either have NB. I’m currently mobile and only have access to a partial list.
                                            More than happy to dig further if need be - when I’m in the office tomorrow.
                                            S 1 Reply Last reply Reply Quote 2
                                            • 1 / 3
