    New firmware release v1.12.0.b1 (Sigfox and LoRa coexistency on the FiPy)
    firmware
    17 Posts 6 Posters 2.9k Views 6 Watching
      robert-hh @daniel
      @daniel uos.uname causes a core dump on FiPy. See https://github.com/pycom/pycom-micropython-sigfox/issues/118
        @robert-hh thanks. Found the cause. Will fix ASAP.
          danielm
          @Xykon
          Can this currently developed upgrade/downgrade tool be used to flash custom image as well?
          • X Offline
            Xykon administrators @danielm
            @danielm You can do that with the command line version of the tool. I will post some more details about that with the next beta release.
            Christian Ehlers
            • N Offline
              naveen
              Why am I getting sigfox.id() and sigfox.pac() as b'ffffffff' and b'ffffffffffffffff' respectively?
                @naveen did you get the Sigfox ID and PAC printed on the screen after the updater tool completed?
                • N Offline
                  naveen
                  I am getting the message shown below but no id or pac info:
                  Result:
                  Your device was successfully updated!
                  Please remove the wire and reset the board.
                    After updating and doing:
                    os.uname()
                    What do you get?
                    • N Offline
                      naveen
                      Everytime I run "os.uname()", FiPy disconnects and only gives partial output as below:
                      (sysname='FiPy', nodename='FiPy', release='1.12.0.b1', version='v1.8.6-849-fcbbfe3 on 2018-01-03', machine='FiPy with ESP32' , lorawan=' > Failed to connect (Connection was reset)
                        @naveen please let us know your WLAN mac address so that we can reset and you can get your Sigfox ID and PAC again.
                        Please run:
                        import binascii
                        from network import WLAN
                        print(binascii.hexlify(WLAN().mac()))
                        And let us know your MAC address. Thanks.
                        • N Offline
                          naveen
                          Mac address: <removed by admin>
                          • X Offline
                            Xykon administrators @naveen
                            @naveen It seems your sigfox credentials haven't been properly generated during the initial upgrade/device registration.
                            I have removed your device... can you please try to upgrade/register again?
                            Christian Ehlers
                            • N Offline
                              naveen
                              OK, I am trying to upgrade/register again. Now I see an option "Country Selection" and I choose "Japan" where I live. Next is "SigFox region selection" but I do not find "Japan" in the available options.
                                @naveen we will add Japan with the next release of the updater tool. In the meantime, please select Europe as Sigfox region. Thanks.
                                  livius @daniel
                                  @daniel
                                  Wipy2
                                  I give another try with recent software compared to 1.7.2.b1 {which is stablest for me for wipy2}.
                                  After flash (today):
                                  1. connection to router give me timeout (30seconds) but if i ignore this i can connect to the socket in the network - i use static ip setting.
                                  2. i2c (i2c=I2C(0, I2C.MASTER, baudrate=100000, pins=("P9", "P10")))
                                  • bh1750 ok,
                                  • pcf8574 ok
                                  • read from bmp180 read only 0 for preasure but temperature is ok
                                  flashed 3 times and tested 30 times with removing cables (5 times and also simple reset 5 for every flash).
                                  downgraded to 1.7.2.b1 all work ok.
                                  I must bring back my logic analyser to see issue on i2c but maybe you have some hint here?
                                  And also what can be the reason of issue from point 1?
