    New firmware release v1.12.0.b1 (Sigfox and LoRa coexistency on the FiPy)
    firmware
    17 Posts 6 Posters 2.9k Views 6 Watching
      @naveen did you get the Sigfox ID and PAC printed on the screen after the updater tool completed?
      • N Offline
        naveen
        I am getting the message shown below but no id or pac info:
        Result:
        Your device was successfully updated!
        Please remove the wire and reset the board.
          After updating and doing:
          os.uname()
          What do you get?
          • N Offline
            naveen
            Everytime I run "os.uname()", FiPy disconnects and only gives partial output as below:
            (sysname='FiPy', nodename='FiPy', release='1.12.0.b1', version='v1.8.6-849-fcbbfe3 on 2018-01-03', machine='FiPy with ESP32' , lorawan=' > Failed to connect (Connection was reset)
              @naveen please let us know your WLAN mac address so that we can reset and you can get your Sigfox ID and PAC again.
              Please run:
              import binascii
              from network import WLAN
              print(binascii.hexlify(WLAN().mac()))
              And let us know your MAC address. Thanks.
              • N Offline
                naveen
                Mac address: <removed by admin>
                • X Offline
                  Xykon administrators @naveen
                  @naveen It seems your sigfox credentials haven't been properly generated during the initial upgrade/device registration.
                  I have removed your device... can you please try to upgrade/register again?
                  Christian Ehlers
                  • N Offline
                    naveen
                    OK, I am trying to upgrade/register again. Now I see an option "Country Selection" and I choose "Japan" where I live. Next is "SigFox region selection" but I do not find "Japan" in the available options.
                      @naveen we will add Japan with the next release of the updater tool. In the meantime, please select Europe as Sigfox region. Thanks.
                        livius @daniel
                        @daniel
                        Wipy2
                        I give another try with recent software compared to 1.7.2.b1 {which is stablest for me for wipy2}.
                        After flash (today):
                        1. connection to router give me timeout (30seconds) but if i ignore this i can connect to the socket in the network - i use static ip setting.
                        2. i2c (i2c=I2C(0, I2C.MASTER, baudrate=100000, pins=("P9", "P10")))
                        • bh1750 ok,
                        • pcf8574 ok
                        • read from bmp180 read only 0 for preasure but temperature is ok
                        flashed 3 times and tested 30 times with removing cables (5 times and also simple reset 5 for every flash).
                        downgraded to 1.7.2.b1 all work ok.
                        I must bring back my logic analyser to see issue on i2c but maybe you have some hint here?
                        And also what can be the reason of issue from point 1?
