    Lopy and Matchx usage
    matchxgatewaylorawan server
    37 Posts 2 Posters 12.7k Views 2 Watching
      misterlisty @jmarcelino
      @jmarcelino
      from network import LoRa
      lora = LoRa()
      lora.frequency()
      doesn't return anything...
      My firmware is MicroPython v1.8.6-834-g5677703c on 2017-11-13; FiPy with ESP32
        jmarcelino @misterlisty
        @misterlisty
        Did you try it on the REPL?
        Try print(lora.frequency())
          @jmarcelino The result is 868000000
          Appears like it isn't Australia..i assume i have to reapply firmware?
            @misterlisty
            Yes that’s set to EU868. We need to reset the device in Pycom’s database before you do a firmware upgrade to change the location. Please send me the MAC address of the WLAN via chat or email a request to support@pycom.io.
            import binascii
            binascii.hexlify(network.WLAN().mac(),':').decode()
              @jmarcelino Here is my Mac <removed>
              How do you know what setting my fopy has? DO you sedn this during firmware update?
                We have no record of your board, so I guess you never updated it?
                We really recommend always updating all our boards first. The factory firmware tends to be very old - or set to the wrong region as yours was.
                In any case if you run the upgrade tool and choose Australia, then it should set to 915Mhz correctly and you can use the code I posted.
                The firmware update instructions are at: https://docs.pycom.io/chapter/gettingstarted/installation/firmwaretool.html
                  @jmarcelino I have connected a wire from GND to G23 and the fopy will not go into upgrade mode. Its connected to a pysense board while i atempt this. It just running my normal code...can i upgrade while connected to the pysense board? Instructions suggest yes.
                    @misterlisty
                    Yes you can use the PySense and you don't need the wire anymore.
                    Make sure you update the Pysense firs, follow the steps here:
                    When you have the new firmware on the Pysense load the the Pycom Firmware Update tool and tick the box which says Pytrack/Pysense:
                    With this setup you don't need the jumper wire as the tool will use the Pysense to put the FiPy into programming mode.
                      @jmarcelino Will atempt update through pysense board shortly but it not upgrading the firmware if i use an USB adapter, connect G23 & GND...its running the normal code instead of going in upgrade mode..any suggestion here?
                        @misterlisty
                        It has to go into flash programming mode, it's a very low level hardware feature.
                        Are you sure you are connecting GND and G23 (also called P2 on the pin map https://docs.pycom.io/chapter/datasheets/downloads/fipy-pinout.pdf )
                        Also when you use an USB adapter what exactly is your setup?
                        In any case I think it will be easier to use the Pysense.
                          misterlisty
                          OK..here is my status..have updated Fopy to latest firmware ie 1.1.12b
                          Here is my OTTA code..it appears to work if you look at the logs of MatchX but code says not yet joined still.
                          import binascii
                          import struct
                          print("Lora send::-3")
                          print("DevEUI[",binascii.hexlify(lora.mac()).upper().decode('utf-8'),"]")
                          # create an OTAA authentication parameters
                          dev_eui = binascii.unhexlify('70 B3 D5 49 97 E4 4C 6E'.replace(' ',''))
                          app_eui = binascii.unhexlify('70 B3 D5 7E D0 00 81 BD'.replace(' ',''))
                          app_key = binascii.unhexlify('77 E7 AE FA 56 67 78 3D 5C 2F 4A E0 B9 F2 E3 FC'.replace(' ',''))
                          print("Lora send::-1")
                          for i in range(0, 72):
                              lora.remove_channel(i)
                          # set the 8 channels for MatchX configuration
                          for channel in range(0,8):
                              lora.add_channel(channel, frequency=915200000+channel*200000, dr_min=0, dr_max=3)
                          lora.join(activation=LoRa.OTAA, auth=(dev_eui,app_eui, app_key), timeout=0)
                          print("Lora send::0")
                          while not lora.has_joined():
                              time.sleep(5)
                              print('Not yet joined...')
                          print('Finally joined...')
                          # remove all the non-default channels
                          for i in range(3, 16):
                          # create a LoRa socket
                          print("Lora send::1")
                          i = 0
                              # set the LoRaWAN data rate
                              print("Lora send::2")
                              # make the socket blocking
                              s.setblocking(True)
                              print("Lora send::3")
                              # send some data
                              count = s.send(bytes([i % 256]))
                              print('Sent %s bytes' % count)
                              print("Lora send::4")
                              s.setblocking(False)
                              print("Lora send::5")
                              data = s.recv(64)
                              print("Lora send::",data)
                              i += 1
                            @misterlisty
                            You're removing channels twice unnecessarily, remove your second part:
                            Also you're sill using RX2, there are two places for this configuration, I think you missed under Application Configuration -> Network Settings. Please set it to RX1 there.
                              @jmarcelino its set to to RX1 as suggested. I now have ABP working :), OTTA is yet to work...its definitely getting a lora_accept signal but the code doesn't acknowledge this.
                                @misterlisty
                                OK glad ABP is working, for OTAA you need to get the downlinks working.
                                If you see the JoinResponse on frequency 923.3Mhz that means it's still RX2. Make sure it's set to RX1 in both places, there's a configuration for the Application and another for the device.
                                --If it's correctly set to RX1 you'll see that the frequency of the JoinResponse matches the JoinRequest.
                                M 2 Replies Last reply Reply Quote 0
                                  @jmarcelino Thanks, what will the frequency be for RX1? I will try your suggestion.
                                    @jmarcelino Its definitely set to RX1 in application settings and node settings..i suspect they have a bug and not replying to my support requests.
                                      misterlisty
                                      @jmarcelino Not sure if i have it right but according to MatchX
                                      "As stated in the instructions 1883 is not correct, the downlink is not the same as the uplink frequency, this is due and in accordance with the LoraWAN Australian specifications.
                                      We advise to use the RX at the correct frequency to receive the OTAA join response.
                                        misterlisty
                                        Any advice on my current setup, a bit confused on how to proceed further, MtachX is definetly using RX1, MatchX are saying the up/down frequencies should be different but i think you are saying they should be the same. The LoRaWan spec appears to specify they shouldbe different. Hoope i'm on the right track.
                                          My apologies, I made a mistake and missed there are different start frequencies corresponding to the transmit and receive channels in that region. MatchX is correct: Uplink Channel 1 (915.2) corresponds to an RX1 in Downlink Channel 1 (923.2)
                                          The data rate is also correct. DR2 in uplink corresponds to DR10 in downlink window.
                                          Since the channel and data rate are correct I'm not sure why the LoPy doesn't accept the JoinResponse. I'll try to investigate on our end if there's anything that could cause this. Again sorry for the confusion.
                                            @jmarcelino Thanks, we are doing field trials of a product using your Fopy devices and hoping for solution in short time. Let me know if you need anything else...
                                            • 2 / 2
