    VL6180X on LoPy I2C sensor driver
    lopyi2csensor
    13 Posts 3 Posters 3.8k Views 3 Watching
    • ledbelly2142L Offline
      ledbelly2142
      There were some examples of micropython 'drivers' (google it) for the VL6180X, I ran in circles for a while chasing what others did in examples. This gets nested in the subtle differences between CircuitPython and MicroPython as well as what works on the ESP8266 vs the ESP32... and of course what is (or is not) implemented in the LoPy firmware. The VL6180X uses 16 bit registers with Big endion. This means read/write requests must be specified with 'big', I think the default it 'little'. Also, the addrsize is set to 16, the default is set to 8. I think on the ESP8266 the addrsize is not enabled, so they have to use other ways to get reg values.
      Read and write for this sensor look something like this:
          def myWrite16(self, register, regValue):
              """ write a byte to specified 16 bit register """
              return self.i2c.writeto_mem(self._address, register, bytearray([regValue]), addrsize=16), 'big'
          def myRead16(self, register):
              """read 1 bit from 16 byte register"""
              # i2c.readfrom_mem(0x29, 0x0016, 1, addrsize=16)
              value = int.from_bytes(
                  self.i2c.readfrom_mem(self._address, register, 1, addrsize=16),
                  'big'
              return value & 0xFFFF
      So others can find this and benefit, here is an example for the VL6180 for the LoPy.
      Adafruit had a really good driver conversion tutorial located HERE. The only issue I had was it uses CircuitPython instead of MicroPython, they used some libraries we can't use withe the LoPy.
      To get the range import the lib I2C and other plus:
      import ustruct
      import struct
      from machine import I2C
      # i2c = I2C(0, I2C.MASTER, baudrate=100000, pins=('P8', 'P9'))
      class Sensor:
          def __init__(self, i2c, address=0x29):
              self.i2c = i2c
              self._address = address
              self.default_settings()
              self.init()
                  'big'
          def init(self):
              if self.myRead16(0x0016) != 1:
                  raise RuntimeError("Failure reset")
              # Recommended setup from the datasheet
              self.myWrite16(0x0207, 0x01)
              self.myWrite16(0x0208, 0x01)
              self.myWrite16(0x0096, 0x00)
              self.myWrite16(0x0097, 0xfd)
              self.myWrite16(0x00e3, 0x00)
              self.myWrite16(0x00e4, 0x04)
              self.myWrite16(0x00e5, 0x02)
              self.myWrite16(0x00e6, 0x01)
              self.myWrite16(0x00e7, 0x03)
              self.myWrite16(0x00f5, 0x02)
              self.myWrite16(0x00d9, 0x05)
              self.myWrite16(0x00db, 0xce)
              self.myWrite16(0x00dc, 0x03)
              self.myWrite16(0x00dd, 0xf8)
              self.myWrite16(0x009f, 0x00)
              self.myWrite16(0x00a3, 0x3c)
              self.myWrite16(0x00b7, 0x00)
              self.myWrite16(0x00bb, 0x3c)
              self.myWrite16(0x00b2, 0x09)
              self.myWrite16(0x00ca, 0x09)
              self.myWrite16(0x0198, 0x01)
              self.myWrite16(0x01b0, 0x17)
              self.myWrite16(0x01ad, 0x00)
              self.myWrite16(0x00ff, 0x05)
              self.myWrite16(0x0100, 0x05)
              self.myWrite16(0x0199, 0x05)
              self.myWrite16(0x01a6, 0x1b)
              self.myWrite16(0x01ac, 0x3e)
              self.myWrite16(0x01a7, 0x1f)
              self.myWrite16(0x0030, 0x00)
      #  writeReg System__Fresh_OUT_OF_Reset
              # self.myWrite16(0x0016, 0x00),
          def default_settings(self):
              # Enables polling for ‘New Sample ready’ when measurement completes
              self.myWrite16(0x0011, 0x10)
              self.myWrite16(0x010A, 0x30)  # Set Avg sample period
              self.myWrite16(0x003f, 0x46)  # Set the ALS gain
              self.myWrite16(0x0031, 0xFF)  # Set auto calibration period
              # (Max = 255)/(OFF = 0)
              self.myWrite16(0x0040, 0x63)  # Set ALS integration time to 100ms
              # perform a single temperature calibration
              self.myWrite16(0x002E, 0x01)
              # Optional settings from datasheet
              self.myWrite16(0x001B, 0x09)  # Set default ranging inter-measurement
              # period to 100ms
              self.myWrite16(0x003E, 0x0A)  # Set default ALS inter-measurement
              # period to 100ms
              self.myWrite16(0x0014, 0x24)  # Configures interrupt on ‘New Sample
              # Ready threshold event’
              # Additional settings defaults from community
              self.myWrite16(0x001C, 0x32)  # Max convergence time
              self.myWrite16(0x002D, 0x10 | 0x01)  # Range check enables
              self.myWrite16(0x0022, 0x7B)  # Eraly coinvergence estimate
              self.myWrite16(0x0120, 0x01)  # Firmware result scaler
          def identify(self):
              """Retrieve identification information of the sensor."""
              return {
                  'model': self.myRead16(0x0000),
                  'revision': (self.myRead16(0x0001), self.myRead16(0x0002)),
                  'module_revision': (self.myRead16(0x0003),
                                      self.myRead16(0x0004)),
                  'date': self.myRead16(0x006),
                  'time': self.myRead16(0x008),
          def address(self, address=None):
              """Change the I2C address of the sensor."""
              if address is None:
                  return self._address
              if not 8 <= address <= 127:
                  raise ValueError("Wrong address")
              self._set_reg8(0x0212, address)
          def range(self):
              """Measure the distance in millimeters. Takes 0.01s."""
              self.myWrite16(0x0018, 0x01)  # Sysrange start
              time.sleep(0.01)
              return self.myRead16(0x0062)  # Result range valueimport ustruct
      You can import the above as a lib and in the main.py add the import statements plus something like:
      vl61b = vl6180xb.Sensor(i2c)
      print("Getting sensor range...")
      print(vl61b.range())
      K 1 Reply Last reply Reply Quote 2
      • K Offline
        kdehmelt @ledbelly2142
        @ledbelly2142 Hey, thank you for your detailed post. I've got it running with a SiPy, but there is a problem: I can only measure ranges up to approx. 70cm. Above this value I just get "255". With an arduino the range was much higher (with the same sensor module and same conditions). Does anyone know how to solve this? Thanks!
          ledbelly2142 @kdehmelt
          @kdehmelt I'm not sure what the max distance the 6180X will read. The only thing I saw in the datasheet was:
          Ranging beyond 100 mm is possible with certain target reflectances and ambient conditions but not
          guaranteed.
          Anything over 10cm is gold, apparently. In this presentation by ST HERE the 6180X ranges up to 40cm and the 53L0X ranges up to 2 meters. The 53L0X has 3 API modes, one of which is long distance, it may be a better option for you.
            ledbelly2142
            By the way, both the 6180X and 53L0X will be significantly influenced by whatever optical window you 'may' use to cover the IR emitter. There are application notes from ST HERE
            Basically it says no more tan 2mm including air gap.
            K 2 Replies Last reply Reply Quote 0
            • K Offline
              @ledbelly2142 Thank you! You are right, that's written in the datasheet. But I just tried it again with a simple Arduino Nano and under same conditions: The range goes up to 200mm and above. There is no cover material used and the reflection works on wood, paper, plastic and even my hand. It also doesnt matter, if VIN is 3.3V or 5V.
              Unfortunately, the 53L0X is not an option, because I need the range less than 50mm as well.
              Could it be, that there is a problem with micropython reading 32bit registers? I tried to read all 'data relevant' registers with the SiPy, but especially convergence time and signal count is zero at all time (32bit register).
              With 0x66 register adress I get values above 10cm, but it is inverted and not linear. Application Note from page 9 onwards.
              • K Offline
                @ledbelly2142 ...for your interest: I've got it working now constantly with the SiPy, 20cm are no problem. If anyone is interested I can post the code.
                ledbelly2142L C 2 Replies Last reply Reply Quote 1
                  @kdehmelt What did you do different? Please paste code.
                  • K Offline
                    @ledbelly2142 I transcribed the python lib from Adafruit into Micropython mixed with your version. Not quite sure where the difference is but I think the read_range routine must be exactly like this. Also an error handling is included.
                    This could be the lib:
                    VL6180X_DEFAULT_I2C_ADDR = 0x29
                    VL6180X_REG_IDENTIFICATION_MODEL_ID = 0x000
                    VL6180X_REG_SYSTEM_INTERRUPT_CONFIG = 0x014
                    VL6180X_REG_SYSTEM_INTERRUPT_CLEAR = 0x015
                    VL6180X_REG_SYSTEM_FRESH_OUT_OF_RESET = 0x016
                    VL6180X_REG_SYSRANGE_START = 0x018
                    VL6180X_REG_SYSALS_START = 0x038
                    VL6180X_REG_SYSALS_ANALOGUE_GAIN = 0x03F
                    VL6180X_REG_SYSALS_INTEGRATION_PERIOD_HI = 0x040
                    VL6180X_REG_SYSALS_INTEGRATION_PERIOD_LO = 0x041
                    VL6180X_REG_RESULT_ALS_VAL = 0x050
                    VL6180X_REG_RESULT_RANGE_VAL = 0x062
                    VL6180X_REG_RESULT_RANGE_STATUS = 0x04d
                    VL6180X_REG_RESULT_INTERRUPT_STATUS_GPIO = 0x04f
                    VL6180X_ALS_GAIN_1 = 0x06
                    VL6180X_ALS_GAIN_1_25 = 0x05
                    VL6180X_ALS_GAIN_1_67 = 0x04
                    VL6180X_ALS_GAIN_2_5 = 0x03
                    VL6180X_ALS_GAIN_5 = 0x02
                    VL6180X_ALS_GAIN_10 = 0x01
                    VL6180X_ALS_GAIN_20 = 0x00
                    VL6180X_ALS_GAIN_40 = 0x07
                    VL6180X_ERROR_NONE = 0
                    VL6180X_ERROR_SYSERR_1 = 1
                    VL6180X_ERROR_SYSERR_5 = 5
                    VL6180X_ERROR_ECEFAIL = 6
                    VL6180X_ERROR_NOCONVERGE = 7
                    VL6180X_ERROR_RANGEIGNORE = 8
                    VL6180X_ERROR_SNR = 11
                    VL6180X_ERROR_RAWUFLOW = 12
                    VL6180X_ERROR_RAWOFLOW = 13
                    VL6180X_ERROR_RANGEUFLOW = 14
                    VL6180X_ERROR_RANGEOFLOW = 15
                    class VL6180X(object):
                        def __init__(self, i2c):
                            self.i2c = i2c
                            self._addr = VL6180X_DEFAULT_I2C_ADDR
                            self.setup()
                        def write_byte_data(self, register, regValue):
                            return self.i2c.writeto_mem(self._addr, register, bytearray([regValue]), addrsize=16), 'big'
                        def read_byte_data(self, register):
                                self.i2c.readfrom_mem(self._addr, register, 1, addrsize=16),
                                'big'
                            return value
                        def setup(self):
                            if self.read_byte_data(VL6180X_REG_IDENTIFICATION_MODEL_ID) != 0xB4:
                                return False
                            self.load_settings()
                            self.write_byte_data(VL6180X_REG_SYSTEM_FRESH_OUT_OF_RESET, 0x00)
                            return True
                        def load_settings(self):
                            # private settings from page 24 of app note
                            self.write_byte_data(0x0207, 0x01)
                            self.write_byte_data(0x0208, 0x01)
                            self.write_byte_data(0x0097, 0xfd)
                            self.write_byte_data(0x0096, 0x00)
                            self.write_byte_data(0x00e3, 0x00)
                            self.write_byte_data(0x00e4, 0x04)
                            self.write_byte_data(0x00e5, 0x02)
                            self.write_byte_data(0x00e6, 0x01)
                            self.write_byte_data(0x00e7, 0x03)
                            self.write_byte_data(0x00f5, 0x02)
                            self.write_byte_data(0x00d9, 0x05)
                            self.write_byte_data(0x00db, 0xce)
                            self.write_byte_data(0x00dc, 0x03)
                            self.write_byte_data(0x00dd, 0xf8)
                            self.write_byte_data(0x009f, 0x00)
                            self.write_byte_data(0x00a3, 0x3c)
                            self.write_byte_data(0x00b7, 0x00)
                            self.write_byte_data(0x00bb, 0x3c)
                            self.write_byte_data(0x00b2, 0x09)
                            self.write_byte_data(0x00ca, 0x09)
                            self.write_byte_data(0x0198, 0x01)
                            self.write_byte_data(0x01b0, 0x17)
                            self.write_byte_data(0x01ad, 0x00)
                            self.write_byte_data(0x00ff, 0x05)
                            self.write_byte_data(0x0100, 0x05)
                            self.write_byte_data(0x0199, 0x05)
                            self.write_byte_data(0x01a6, 0x1b)
                            self.write_byte_data(0x01ac, 0x3e)
                            self.write_byte_data(0x01a7, 0x1f)
                            self.write_byte_data(0x0030, 0x00)
                            # Recommended : Public registers - See data sheet for more detail
                            self.write_byte_data(0x0011, 0x10)  # Enables polling for 'New Sample ready' when measurement
                            # completes
                            self.write_byte_data(0x010a, 0x30)  # Set the averaging sample period (compromise between
                            # lower noise and increased execution time)
                            self.write_byte_data(0x003f, 0x46)  # Sets the light and dark gain (upper nibble). Dark gain
                            # should not be changed.
                            self.write_byte_data(0x0031, 0xFF)  # sets the # of range measurements after which auto
                            # calibration of system is performed
                            self.write_byte_data(0x0040, 0x63)  # Set ALS integration time to 100ms
                            self.write_byte_data(0x002e, 0x01)  # perform a single temperature calibration of the ranging
                            # sensor
                            # Optional: Public registers - See data sheet for more detail
                            self.write_byte_data(0x001b, 0x09)  # Set default ranging inter-measurement period to 100ms
                            self.write_byte_data(0x003e, 0x31)  # Set default ALS inter-measurement period to 500ms
                            self.write_byte_data(0x0014, 0x24)  # Configures interrupt on 'New Sample Ready threshold event'
                        def read_range(self):
                            # wait for device to be ready for range measurement
                            while not (self.read_byte_data(VL6180X_REG_RESULT_RANGE_STATUS) & 0x01): pass
                            # Start a range measurement
                            self.write_byte_data(VL6180X_REG_SYSRANGE_START, 0x01)
                            # Poll until bit 2 is set
                            while not (self.read_byte_data(VL6180X_REG_RESULT_INTERRUPT_STATUS_GPIO) & 0x04): pass
                            # read range in mm
                            range = self.read_byte_data(VL6180X_REG_RESULT_RANGE_VAL)
                            # clear interrupt
                            self.write_byte_data(VL6180X_REG_SYSTEM_INTERRUPT_CLEAR, 0x07)
                            return range
                        def read_range_status(self):
                            return self.read_byte_data(VL6180X_REG_RESULT_RANGE_STATUS) >> 4
                        def read_lux(self, gain):
                            reg = self.read_byte_data(VL6180X_REG_SYSTEM_INTERRUPT_CONFIG)
                            reg &= ~0x38
                            reg |= (0x4 << 3)  # IRQ on ALS ready
                            self.write_byte_data(VL6180X_REG_SYSTEM_INTERRUPT_CONFIG, reg)
                            # 100 ms integration period
                            self.write_byte_data(VL6180X_REG_SYSALS_INTEGRATION_PERIOD_HI, 0)
                            self.write_byte_data(VL6180X_REG_SYSALS_INTEGRATION_PERIOD_LO, 100)
                            # analog gain
                            if gain > VL6180X_ALS_GAIN_40:
                                gain = VL6180X_ALS_GAIN_40
                            self.write_byte_data(VL6180X_REG_SYSALS_ANALOGUE_GAIN, 0x40 | gain)
                            # start ALS
                            self.write_byte_data(VL6180X_REG_SYSALS_START, 0x1)
                            # Poll until "New Sample Ready threshold event" is set
                            while 4 != ((self.read_byte_data(VL6180X_REG_RESULT_INTERRUPT_STATUS_GPIO) >> 3) & 0x7): pass
                            # read lux!
                            lux = self.read_word_data(VL6180X_REG_RESULT_ALS_VAL)
                            # clear interrupt
                            lux *= 0.32  # calibrated count/lux
                            if gain == VL6180X_ALS_GAIN_1:
                                pass
                            elif gain == VL6180X_ALS_GAIN_1_25:
                                lux /= 1.25
                            elif gain == VL6180X_ALS_GAIN_1_67:
                                lux /= 1.76
                            elif gain == VL6180X_ALS_GAIN_2_5:
                                lux /= 2.5
                            elif gain == VL6180X_ALS_GAIN_5:
                                lux /= 5
                            elif gain == VL6180X_ALS_GAIN_10:
                                lux /= 10
                            elif gain == VL6180X_ALS_GAIN_20:
                                lux /= 20
                            elif gain == VL6180X_ALS_GAIN_40:
                                lux /= 20
                            lux *= 100
                            lux /= 100  # integration time in ms
                            return lux
                    and the main.py:
                    import vl6180xb
                    i2c = I2C(0, I2C.MASTER, baudrate=100000, pins=('P11', 'P10'))
                    vl61b = vl6180xb.VL6180X(i2c)
                    print(vl61b.read_range())
                    ledbelly2142L 1 Reply Last reply Reply Quote 1
                      @kdehmelt Looks good, did you get the read_lux to work?
                      • K Offline
                        @ledbelly2142 Yes, it seems to work. Maybe it must be calibrated.
                        You just have to change:
                        to
                        lux = self.read_byte_data(VL6180X_REG_RESULT_ALS_VAL)
                        and call it with read_lux(gain in hex).
                          chumelnicu @kdehmelt
                          @kdehmelt Hello
                          Do you have a working code for VL53L0x to rich 200 cm ?
                          if yes ...could you share?
                          Thank you !
                          H
                          • K Offline
                            kdehmelt @chumelnicu
                            @chumelnicu Hey, you can look it up here (scroll down) or try to transcribe the Adafruit library
