    Lopy with pytrack, how connect/use GPS?
    gpslopypytrack
    76 Posts 5 Posters 35.6k Views 5 Watching
      crumble @zceld
      @zceld said in Lopy with pytrack, how connect/use GPS?:
      the problem is that I do not know how it is done or something fails me. Because for example when I run this:
      Have a look in the example:
      you have to get an instance of the libraries object and initilaize it.
      The timer is mportant, so if you ask for a coordinate and you are at a place where you cannot receive signals, your program continous.
      py = Pytrack()
      l76 = L76GNSS(py, timeout=30)
      chrono = Timer.Chrono()
      chrono.start()
      Than you simply call this function
      coord = l76.coordinates()
      which returns a tupel with the coordinate. If you get not enough signals inbetween 30 seconds it will return (null, null). So at best you go outside on a sunny day on an iopen field or you place the pytrack at a window and hope for the best.
      Sometimes it fails on a LoPy. The example (the library is an example as well) do a lot of string manipulation which uses a lot of RAM. The LoPy has not much of it. So you will run every now and than in an out of memory problem. So either you look into the library how you communicate with the GNSS chip and write your own library, or you reduce the string size used in the library. I think @livius dicovered the string length which will work. LoPys will have around 30-64kB free RAM after booting with the pytrack library. Newer versions with 3MB shall not run into this problem during boot.
      But all this is wild guessing. Please provide us more details about the failures ;)
      • Z Offline
        zceld @livius
        @livius
        First thank you again, but I put your patience to the test again.
        I have managed to upload the libraries that L76GNSS.py and pytrack.py in their respective directory. That has already cost me a lot since I did not let myself use the shutil library. alt text 0_1516035369502_3.PNG
        Anyway, having done this, I tried some example codes to connect with the GPS and now it gives me a memory error.
        This is the executed file: https://github.com/inmcm/micropyGPS/blob/master/micropyGPS.py!alt text(/assets/uploads/files/1516035348953-3.png)
        • Z Offline
          zceld @livius
          @livius
          I also tried to execute this code and it gives me an error.
          but I do not know what it means?
          code: prueba1.py
          0_1516035880488_prueba1.py
            livius @zceld
            @zceld
            I do not use it self then can not talking if it is easy ;-)
            but - try to use modified file L76GNSS.py
            https://github.com/pycom/pycom-libraries/pull/43/files
            change
            from L76GNSS import L76GNSS to import L76GNSS
            and also
            l76 = L76GNSS(py, timeout=30) to l76 = L76GNSS.L76GNSS(py, timeout=30)
              crumble @zceld
              @zceld is the micropythnGPS library written for the pytrack? First lines of your screenshot let me assume that it was written for another board. So if you cannot simply configure it to use the pytrack, you have to rewrite some parts.
              You should not use L76Gnss.py and this MicropythonGPS library at the same time. They may not interfere each other, but compiling them will need some RAM, which you need for other stuff.
              • sebS Offline
                seb
                You also now have to include the pycoproc.py file from here: https://github.com/pycom/pycom-libraries/tree/master/lib/pycoproc
                This contains common code between the pysense and pytrack and was refactored into its own library to reduce duplication of code.
                • Z Offline
                  zceld @crumble
                  @crumble Hi, thanks for your recommendations. I really do not know how micropyGPS is for my chip which is a pycom Lopey 1.0 with the pytrack board. I am new in this world of plates. Then use both libraries I do not think it happens, because at the moment my procedure to prove it is having the board connected by USB to ATOM executing code like the one that I attached "micropyGPS" with the hope of obtaining coordinates. I have added in the directory '/ lib' the files L76GNSS.py, pycoproc.py and Pytrack.py. I understand that I complete the necessary libraries to get coordinates with the GPS chip, right? So now I would have to do a small program that connects with the GPS chip and get the coordinates of the location.
                  0_1516113906139_microGPS.py
                  • Z Offline
                    zceld
                    @seb I have already added the file to the directori '/ lib' now I would need to know how to get the gps position using the libraries.
                    • Z Offline
                      zceld @livius
                      @livius
                      Good afternoon, I followed your steps to the detail.
                      I have updated the pytrack.
                      I updated the pycom Lopy.
                      I have added the libraries within the directory '/ lib' as they are in this post:
                      https://github.com/pycom/pycom-libraries/tree/master/pytrack
                      Then the main file has not been modified because I run it from Atom connected by usb and execute it like this:
                      this main.py : 0_1516121243856_main1.py
                      The original is extracted from here:
                      https://github.com/pycom/pycom-libraries/blob/master/pytrack/main.py
                      but modifying the lines 8,10,11;
                      He always tells me the same thing:
                      I run out of ideas to make it work. :-(
                      • sebS Offline
                        seb
                        Here is a simplified version of that main.py file, does this work for you:
                        from pytrack import Pytrack
                        py = Pytrack()
                        while (True):
                            print(coord)
                            time.sleep(1)
                        • Z Offline
                          zceld @seb
                          @seb
                          I'm sorry, but it does not work:
                            livius @zceld
                            why do you modified those lines?
                            better change this:
                            • Z Offline
                              zceld @livius
                              @livius said in Lopy with pytrack, how connect/use GPS?:
                              better change this:
                              Just remove them for testing because with the original I get this another error:0_1516123767559_3.PNG
                              The suggested change is to add the 'if' no?
                              It would be like this the file I suppose:
                              • sebS Offline
                                seb @zceld
                                @zceld
                                That error means that there is something wrong with /flash/lib/L76GNSS.py, Can you please reformat your device by running the following in the REPL:
                                os.mkfs('/flash')
                                And then download a fresh copy of all the files from git to make sure they are not currupt, you should have:
                                main.py
                                lib/L76GNSS.py
                                lib/pytrack.py
                                lib/pycoproc.py
                                  livius @zceld
                                  @zceld
                                  go to advice provided by @seb (remember that this clear your device flash completly)
                                  and if you need to use microGPS.py
                                  then you need to change line in L76GNSS.py
                                   nmea += self._read().lstrip(b'\n\n').rstrip(b'\n\n')
                                  and feed microGPS object with chars from nmea e.g.
                                  create first microGPS object somwhere in the file `L76GNSS.py` that it will be accessible (best is add it as property)
                                  mgps = MicropyGPS()
                                  nmea = self._read().lstrip(b'\n\n').rstrip(b'\n\n')
                                  for c in nmea:
                                     sentence = mgps.update(c)
                                     if sentence:
                                         do_something_here
                                  • Z Offline
                                    zceld @seb
                                    @seb
                                    Hello again!
                                    I followed your steps and used 'os.mkfs (' / flash ')'
                                    I have copied again the codes of the page:
                                    https://github.com/pycom/pycom-libraries/tree/master/pytrack/lib
                                    From here I copied the three files and also the main.
                                    I tried to run and this error came out:
                                    So I went to download that library to see if that solved that.
                                    I copied it from here:
                                    I have uploaded the library to the device and that problem seems to have
                                    been solved.
                                    Then he stopped in the following:
                                    There is something that I do not understand or that I do not do well, I do not think it is so difficult. Therefore I wanted to try to execute the code directly in the Atom console so following the example that you have put me:
                                    and neither.
                                    So, I do not know what exactly each program is for. That is to say for example this file:
                                    I understand that it serves to run from Atom and I print on screen the data obtained from the GPS module ?. It would be more or less what I'm looking for since what I need is for this plate to be carried by a vehicle and while it is on, keep the GPS position every 30 seconds.
                                    For example, the microGPS file does not know what it is for. I was just testing everything I found to refer to the GPS to see if I could get data.
                                    But I have to admit that I'm stuck. I do not know what I do wrong or what else to try.
                                    • sebS Offline
                                      seb
                                      That error message means the library was not able to detect the Pytrack. Are you sure you have connected your module to your pytrack board properly, are all the pins pushed in fully? Have you updated the firmware on your Pytrack board to the latest available? (note: this is not the same as the firmware of the main pycom module)
                                      • Z Offline
                                        zceld @seb
                                        @seb
                                        Well, since you told me in the procedure to update it. Therefore I have the 'pytrack' and 'pycom' plate:
                                        I understand that the board is well connected because I connect with it by the usb from pytrack to Atom and it responds to all commands os. , for example pycom.heartbeat (False) and the LED goes off. I also upload a short video and show you the directory listings.
                                        video/gif:
                                        https://imgur.com/a/eQl9h
                                        Directory:
                                        Everything you need I'll show you to know or reach the solution.
                                        • sebS Offline
                                          seb
                                          Thanks for confirming all of that. To debug this further could you change the following two lines of code in pycoproc.py so we can see in more detail what error is occurring:
                                          108        except Exception:
                                          109            raise Exception('Board not detected')
                                          to
                                          108        except Exception as e:
                                          109            print(e)
                                          110            raise Exception('Board not detected')
                                          • Z Offline
                                            zceld
                                            @seb
                                            ok, I added the line of code you indicated and updated the file on the board:0_1516205098806_Captura de pantalla 2018-01-17 17.00.48.png
                                            I check that the lines of code are in the uploaded file:
                                            Bien, pues pruebo de nuevo a ejecutar el main.py:
                                            Result:
                                            • 1 / 4
