    Lopy with pytrack, how connect/use GPS?
    gpslopypytrack
    76 Posts 5 Posters 35.6k Views 5 Watching
    • Z Offline
      zceld @livius
      @livius said in Lopy with pytrack, how connect/use GPS?:
      why do you modified those lines?
      better change this:
      Just remove them for testing because with the original I get this another error:0_1516123767559_3.PNG
      The suggested change is to add the 'if' no?
      It would be like this the file I suppose:
      • sebS Offline
        seb @zceld
        @zceld
        That error means that there is something wrong with /flash/lib/L76GNSS.py, Can you please reformat your device by running the following in the REPL:
        os.mkfs('/flash')
        And then download a fresh copy of all the files from git to make sure they are not currupt, you should have:
        main.py
        lib/L76GNSS.py
        lib/pytrack.py
        lib/pycoproc.py
          livius @zceld
          @zceld
          go to advice provided by @seb (remember that this clear your device flash completly)
          and if you need to use microGPS.py
          then you need to change line in L76GNSS.py
           nmea += self._read().lstrip(b'\n\n').rstrip(b'\n\n')
          and feed microGPS object with chars from nmea e.g.
          create first microGPS object somwhere in the file `L76GNSS.py` that it will be accessible (best is add it as property)
          mgps = MicropyGPS()
          nmea = self._read().lstrip(b'\n\n').rstrip(b'\n\n')
          for c in nmea:
             sentence = mgps.update(c)
             if sentence:
                 do_something_here
          • Z Offline
            zceld @seb
            @seb
            Hello again!
            I followed your steps and used 'os.mkfs (' / flash ')'
            I have copied again the codes of the page:
            https://github.com/pycom/pycom-libraries/tree/master/pytrack/lib
            From here I copied the three files and also the main.
            I tried to run and this error came out:
            So I went to download that library to see if that solved that.
            I copied it from here:
            https://github.com/pycom/pycom-libraries/tree/master/lib/pycoproc
            I have uploaded the library to the device and that problem seems to have
            been solved.
            Then he stopped in the following:
            There is something that I do not understand or that I do not do well, I do not think it is so difficult. Therefore I wanted to try to execute the code directly in the Atom console so following the example that you have put me:
            and neither.
            So, I do not know what exactly each program is for. That is to say for example this file:
            https://github.com/pycom/pycom-libraries/blob/master/pytrack/main.py
            I understand that it serves to run from Atom and I print on screen the data obtained from the GPS module ?. It would be more or less what I'm looking for since what I need is for this plate to be carried by a vehicle and while it is on, keep the GPS position every 30 seconds.
            For example, the microGPS file does not know what it is for. I was just testing everything I found to refer to the GPS to see if I could get data.
            But I have to admit that I'm stuck. I do not know what I do wrong or what else to try.
            • sebS Offline
              seb
              That error message means the library was not able to detect the Pytrack. Are you sure you have connected your module to your pytrack board properly, are all the pins pushed in fully? Have you updated the firmware on your Pytrack board to the latest available? (note: this is not the same as the firmware of the main pycom module)
              • Z Offline
                zceld @seb
                @seb
                Well, since you told me in the procedure to update it. Therefore I have the 'pytrack' and 'pycom' plate:
                I understand that the board is well connected because I connect with it by the usb from pytrack to Atom and it responds to all commands os. , for example pycom.heartbeat (False) and the LED goes off. I also upload a short video and show you the directory listings.
                video/gif:
                https://imgur.com/a/eQl9h
                Directory:
                Everything you need I'll show you to know or reach the solution.
                • sebS Offline
                  seb
                  Thanks for confirming all of that. To debug this further could you change the following two lines of code in pycoproc.py so we can see in more detail what error is occurring:
                  108        except Exception:
                  109            raise Exception('Board not detected')
                  to
                  108        except Exception as e:
                  109            print(e)
                  110            raise Exception('Board not detected')
                  • Z Offline
                    zceld
                    @seb
                    ok, I added the line of code you indicated and updated the file on the board:0_1516205098806_Captura de pantalla 2018-01-17 17.00.48.png
                    I check that the lines of code are in the uploaded file:
                    Bien, pues pruebo de nuevo a ejecutar el main.py:
                    Result:
                    • sebS Offline
                      seb
                      Thats odd, its showing that the firmware version is outdated but you showed me the screenshot of you updating it. Can you please run the following in the REPL after the error:
                      py.read_fw_version()
                      and post back what it returns?
                      • Z Offline
                        zceld @seb
                        true !, according to the console and the screenshot I answered that it had been updated successfully. I will also do it again from this pc that is different. For trying, I lose nothing.
                        • sebS Offline
                          seb
                          you typed that in wrong, its py not pycom
                          • Z Offline
                            zceld @seb
                            @seb yes! Sorry, as I gave an error I was trying and I sent you a test here you have the complete test.0_1516206577679_Captura de pantalla 2018-01-17 17.28.45.png
                            You will also have to apologize for taking a long time to answer the forum, it does not allow me to respond faster.:
                            • sebS Offline
                              seb
                              I upvoted some of your posts, the limit should now be much shorter.
                              ok sorry, can you try running this instead:
                              from pytrack import Pytrack
                              py = Pytrack()
                              • Z Offline
                                zceld @seb
                                @seb
                                Thank you very much for all the support, I have made the indicated and I keep saying the same.
                                • sebS Offline
                                  seb
                                  Ah, thats annoying, because the error happens when trying to create py and fails we cant then use it later. I am afraid you will have to edit the library some more:
                                              if self.read_fw_version() < 6:
                                                  raise ValueError('Firmware out of date')
                                  to
                                                  raise ValueError('Firmware out of date (Version: {})'.format(self.read_fw_version()))
                                  I will make some changes to the library on github once we solve this to make this easier in the future.
                                  • Z Offline
                                    zceld
                                    @seb
                                    I am also trying to update from this PC again as I mentioned and it is a Mac, but this command that indicates the guide does not accept it:
                                    I update this part above to show you that I finally got back to update the board through the Mac:
                                    <-------------- current topic: ------------------->
                                    Well I have made the changes, updated the file in the pycom.
                                    I have tried again the previous and even the main.py but it still fails. I will also try to update the pytrack with Mac.
                                    @seb said in Lopy with pytrack, how connect/use GPS?:
                                    • Z Offline
                                      zceld @zceld
                                      @zceld
                                      okay! it seems that the update of the pytrack was not effective for windows despite the screenshot showed that yes, because now at least we can call the class Pytrack ().
                                      The problem when running the main.py that in my case is called main3.py but that it is the same program as this one:
                                      Well now the fault is as follows:
                                      At least we have already advanced! ;-)
                                      • Z Offline
                                        zceld @zceld
                                        @zceld
                                        It seems that at least you have tried a couple of times, get the coordinates!
                                        After I forget this, I would not know how to fix it:
                                        Afterwards he does not let me try it anymore:
                                        • Z Offline
                                          zceld
                                          @zceld
                                          Well finally it seems that with this code at least try to get the GPS coordinates.
                                          On the other hand now comes another problem and it seems that it runs out of memory. What do you think? the idea of operation is to collect the signal from the gps of a vehicle and send it to LoRa. I understand that if it is due to lack of memory, it will be necessary to program something to clean the cache or something that increases when using the program, not?
                                          CODE:
                                          from L76GNSS import L76GNSS
                                          py = Pytrack()
                                          l76 = L76GNSS(py, timeout=30)
                                          while (True):
                                          coord = l76.coordinates()
                                          print(coord)
                                          time.sleep(1)
                                          I am waiting for new news. Thank you very much for your patience
                                          • Z Offline
                                            zceld
                                            @zceld
                                            I am happy to inform you that with this code I have at least managed to obtain coordinates without failure:
                                            Code:
                                            import math
                                            import network
                                            import utime
                                            from machine import RTC
                                            from machine import SD
                                            from machine import Timer
                                            # setup as a station
                                            import gc
                                            time.sleep(2)
                                            gc.enable()
                                            # setup rtc
                                            rtc = machine.RTC()
                                            rtc.ntp_sync("pool.ntp.org")
                                            utime.sleep_ms(750)
                                            utime.timezone(7200)
                                            py = Pytrack()
                                            chrono = Timer.Chrono()
                                            chrono.start()
                                            #sd = SD()
                                            #os.mount(sd, '/sd')
                                            #f = open('/sd/gps-record.txt', 'w')
                                            while (True):
                                            #f.write("{} - {}\n".format(coord, rtc.now()))
                                            print("{} - {} - {}".format(coord, rtc.now(), gc.mem_free()))
                                            Result:
                                            Thank you very much to all of you who have had to endure my clumsiness and have helped me especially: @seb and @livius, include @crumble ! :-)
                                            taking advantage of the post with the doubts and problems that I have had, I will shortly upload a guide in Spanish (since it is already in English) on the subject to facilitate other people.
                                            • 2 / 4
