    Lopy with pytrack, how connect/use GPS?
    gpslopypytrack
    76 Posts 5 Posters 33.6k Views 5 Watching
    • Z Offline
      zceld @livius
      @livius said in Lopy with pytrack, how connect/use GPS?:
      use simple fix for this
      This solution and you told me about it and the thing is that you have to replace lines 74 and 75 with the lines that are in green, right?
        livius @zceld
        @zceld
        Yes, but you have indentation problem
        remember that python work on proper indentation.
        nmea line must be indented
        • Z Offline
          zceld @livius
          @zceld
          I suppose you mean this:
          But then how do I fix it?
            livius @zceld
            @zceld
            • Z Offline
              zceld @livius
              @livius
              Perfect!. working correctly again. I do not understand how a tabulation can give an error. XDD it shows that I am new? Thank you very much again, although I'll probably come back with something else. But good Thanks to your patience as always.
                crumble @zceld
                @zceld
                Is there anything I can do ?
                You can try to call the garbage collector before and after you read the coordinates.
                The better solution. Implement the GPS stuff by your own and share the code with us. You have to read the stream from the GPS chip into fix allocated buffers and parse them by your own. If you need only the coordinates, it is simple, you will need around 100 lines of code. I stuck with my version :-(. Had no time to work on it.
                • Z Offline
                  zceld @zceld
                  @livius
                  Well, I have another doubt. I am trying to send the coordinates by LoRa and it gives me the following problem that I do not know how to solve.
                  Other questions more:
                  print("{} - {} - {}".format(coord, rtc.now(), gc.mem_free()))
                  This returns (latitude, longitude) - (Real time clock) - free ram
                  But and the altitude?
                  The time can be updated?
                  L C 2 Replies Last reply Reply Quote 0
                    livius @zceld
                    @zceld said in Lopy with pytrack, how connect/use GPS?:
                    touple is not buffered
                    you need bytes you can try to cast this as bytes() but for lora better is using pack.
                    look at samples about lora in official docs https://docs.pycom.io/
                    Time you can update from wifi connection
                    by e.g.
                    rtc.ntp_sync("pool.ntp.org")
                    or retrive it from GPS
                    or some external device for DCF or MSF
                      crumble @zceld
                      @zceld
                      If you look into the code of the library you will see, that only the coordinates are read from the GPS. No altitude and no dateTime.
                      The time information is read from WiFi. You will need access to an NTP server.
                      The sentence which is used to get the coordinates contains the time as well, but not the date. If you need only the time, you can simply add this to the library.
                      For date and time you have to add support for parsing additional NMEA sentences.
                        livius @crumble
                        @crumble
                        better use existing one
                        https://github.com/livius2/micropyGPS
                        and exctend it if needed
                        • Z Offline
                          zceld @livius
                          @livius
                          Thank you very much for the recommendation but using 'microGPS' gives me a lack of memory again.
                          On the other hand I do not know if to take advantage of this post or open another one. It is on the subject LoRa that I do not understand very well the programming examples. I am using this one.
                          Using a board in sending mode, and another in receiver mode, I do not understand why there are messages sent by LoRa that are lost or not picked up by the receiver.
                          This captur reciver:
                          print:
                          identifier-identifier-counter-longitude-latitude
                          As you can see in the image of the receiver, it goes from counter 7 to 10 and has lost message 8 and 9
                          • issuer code:
                          import math
                          import network
                          import utime
                          from machine import RTC
                          from machine import SD
                          from machine import Timer
                          from L76GNSS import L76GNSS
                          from pytrack import Pytrack
                          from network import LoRa
                          lora = LoRa(mode=LoRa.LORA)
                          # setup as a station
                          import gc
                          time.sleep(2)
                          gc.enable()
                          # setup rtc
                          rtc = machine.RTC()
                          utime.sleep_ms(750)
                          utime.timezone(7200)
                          py = Pytrack()
                          l76 = L76GNSS(py, timeout=30)
                          chrono = Timer.Chrono()
                          chrono.start()
                          j=0 #accountant
                          while (True):
                              coord = l76.coordinates()
                              #Codigo Personalizado para enviar por LoRa Posicon:
                              x = "witeklab-"+"12345678Z-"+str(j)+"-"+str(coord[0]) + "-"+str(coord[1])
                              s.setblocking(True)
                              s.send(x)
                              print(x)
                              time.sleep(2) #Pausa entre toma de coordenadas.
                              j=1+j
                          receiver code:
                          # initialize LoRa in LORA mode
                          # more params can also be given, like frequency, tx power and spreading factor
                          # create a raw LoRa socket
                              # send some data
                              for x in range(5):
                                s.setblocking(False)
                                data = s.recv(64)
                                time.sleep(0.1)
                                print(data)
                            crumble @zceld
                            @zceld LoRa is like a radio in citizen band. Anyone can send messages around and all have to listen to them. So you may receive data from other devices as well.
                            Too solve your specific problem you shall set in your receiver blocking to true. This will wait until you reveived a message. If it is false it will not wait to receive a message in line `data = s.recv(64)
                            So it will continue with an empty string, because it has not received a message.
                            Setting blocking mode to false is useful, if you want to run your loop until you received a certain message. Setting it to true is useful if you want to start the loop after you received a message.
                            If you have only nonblocking calls and you want to wait for a message, you have to call it in a loop until something receives. This will need a lot of battery power.
                            If you want to run a loop until you receive a certain message and you have only blocking calls, you have to use multi threading to solve this problem. This will not consume much battery power, but it makes your code more complex.
                              livius @zceld
                              When and where do you create microGPS object instance?
                              • Z Offline
                                zceld @crumble
                                @crumble
                                I am very interested in what you say, because what really interests me is that the Lora system is in a listening mode until I receive a message, when we receive a message we can do something specific.
                                So a possible solution would be changing s.setblocking (True) like this?:
                                      s.setblocking(True)
                                      data = s.recv(64)
                                      print(data)
                                • Z Offline
                                  zceld @livius
                                  @livius
                                  Well no, I just ran microGPS as if it were the main. So you want to say that microGPS is a library and that to give me the coordinates I should develop a code like this one but with the library 'microGPS'?
                                  Example code:
                                  import math
                                  import network
                                  import utime
                                  #send with LoRa:
                                  import gc
                                  gc.enable()
                                  # setup rtc
                                  rtc = machine.RTC()
                                  utime.sleep_ms(750)
                                  py = Pytrack()
                                  chrono.start()
                                  while (True):
                                    crumble @zceld
                                    Yes. You need to set it only once outside the loop:
                                    s.setblocking(True)
                                       data = s.recv(64)
                                       print(data)
                                    • Z Offline
                                      zceld @crumble
                                      @crumble
                                      Great! thank you very much. Now I just need to be able to connect via Wi-Fi directly to Lopy, I do not know what the password is:
                                        crumble @zceld
                                        @zceld
                                        here you will find the passowrd
                                        https://docs.pycom.io/chapter/toolsandfeatures/repl/telnet.html
                                        • Z Offline
                                          zceld
                                          good morning everyone
                                          I already have a question in the ink, I've been looking and I have not seen anything clear about the plate. Therefore I take my post of doubts.
                                          Someone could explain to me what changes if you have write the function:
                                          #or
                                          s.setblocking (False)
                                          Thanks, greetings in advance!
                                          By the way, I already managed to connect via wifi @crumble
                                          • Z Offline
                                            zceld
                                            On the other hand, I have the insecurity that I never know how long it will take to find GPS the pytrack ... sometimes they connect in 2 minutes, other times in 15 and then cases like today that I have been without signal for the whole afternoon...
                                            Code:
                                            import math
                                            import network
                                            import utime
                                            #send with LoRa:
                                            import gc
                                            gc.enable()
                                            # setup rtc
                                            rtc = machine.RTC()
                                            utime.sleep_ms(750)
                                            py = Pytrack()
                                            chrono.start()
                                            while (True):
                                            Result:
                                            • 3 / 4
